gsymichael ,你好。我的卡就是sdhc的4G卡。在微软网站上知道要加Response7,可是具体要修改那个源代码,我不是很了解。我所知道的微软提供的源代码有:
C:\WINCE500\PUBLIC\COMMON\OAK\DRIVERS\SDCARD\SDHCDRIVERS\SDIOSTDHC\BASE
中的sdhcslot.cpp里BusRequestHandler( PSD_BUS_REQUEST pRequest)函数有
case ResponseR7:
wRegCommand |= CMD_RESPONSE_R1_R5_R6_R7;
break;
C:\WINCE500\PUBLIC\COMMON\OAK\CSP\ARM\SAMSUNG\S3C2410X\SDHC\SDHCBASE
中的sdiocontrollerbase.cpp里SendCommand(UINT16 Cmd, UINT32 Arg, UINT16 respType, BOOL bDataTransfer)函数里有
//----- 4. Send the command to the MMC controller -----
switch(respType)
case NoResponse: // Response is not required, but make sure the command was sent
DEBUGMSG (SDHC_RESPONSE_ZONE,(TEXT("SendCommand no response required")));
vm_pSDIReg->SDICCON = START_COMMAND | COMMAND_START_BIT | (Cmd & MAX_CMD_VALUE);
while(!(vm_pSDIReg->SDICSTA & COMMAND_SENT))
dwWaitCount++;
if( dwWaitCount > WAIT_TIME )
DEBUGMSG(SDCARD_ZONE_ERROR, (TEXT("SDHCD:SendCommand() - timeout waiting for command completion!\r\n")));
return SD_API_STATUS_RESPONSE_TIMEOUT;
if( !IsCardPresent() )
DEBUGMSG(SDCARD_ZONE_ERROR, (TEXT("SDHCD:SendCommand() - Card ejected!\r\n")));
return SD_API_STATUS_DEVICE_REMOVED;
if(vm_pSDIReg->SDICSTA & COMMAND_TIMED_OUT)
DEBUGMSG(SDCARD_ZONE_ERROR, (TEXT("SDHCD:SendCommand() - Command 0x%04x timed out!\r\n"), Cmd));
vm_pSDIReg->SDICSTA = COMMAND_TIMED_OUT; // Clear the error
vm_pSDIReg->SDICSTA = COMMAND_SENT; // Clear the status
break;
case ResponseR1: // Short response required
case ResponseR1b:
case ResponseR3:
case ResponseR4:
case ResponseR5:
case ResponseR6:
DEBUGMSG (SDHC_RESPONSE_ZONE,(TEXT("sendSDICommand short response required")));
// vm_pSDIReg->SDICCON = uiNewCmdRegVal | WAIT_FOR_RESPONSE | START_COMMAND | COMMAND_START_BIT | (Cmd & MAX_CMD_VALUE);
vm_pSDIReg->SDICCON = WAIT_FOR_RESPONSE | START_COMMAND | COMMAND_START_BIT | (Cmd & MAX_CMD_VALUE);
break;
case ResponseR2: // Long response required
DEBUGMSG (SDHC_RESPONSE_ZONE,(TEXT("sendSDICommand long response required")));
// vm_pSDIReg->SDICCON = uiNewCmdRegVal | LONG_RESPONSE | WAIT_FOR_RESPONSE | START_COMMAND | COMMAND_START_BIT | (Cmd & MAX_CMD_VALUE);
vm_pSDIReg->SDICCON = LONG_RESPONSE | WAIT_FOR_RESPONSE | START_COMMAND | COMMAND_START_BIT | (Cmd & MAX_CMD_VALUE);
break;
default:
DEBUGMSG(SDCARD_ZONE_ERROR, (TEXT("SDHCD:sendSDICommand() - Invalid response type. Command not sent!\r\n")));
return SD_API_STATUS_NOT_IMPLEMENTED;
break;
}中没有ResponseR7,应该如何加?
函数GetCommandResponse(PSD_BUS_REQUEST pRequest)中有
//----- 2. Copy the response information to our "response buffer" -----
// NOTE: All START_BIT and TRANSMISSION_BIT bits ='0'. All END_BIT bits ='0'. All RESERVED bits ='1'
respBuff = pRequest->CommandResponse.ResponseBuffer;
switch(pRequest->CommandResponse.ResponseType)
case NoResponse:
break;
case ResponseR1:
case ResponseR1b:
//--- SHORT RESPONSE (48 bits total)---
// Format: { START_BIT(1) | TRANSMISSION_BIT(1) | COMMAND_INDEX(6) | CARD_STATUS(32) | CRC7(7) | END_BIT(1) }
// NOTE: START_BIT and TRANSMISSION_BIT = 0, END_BIT = 1
*(respBuff ) = (BYTE)(START_BIT | TRANSMISSION_BIT | pRequest->CommandCode);
*(respBuff + 1) = (BYTE)(vm_pSDIReg->SDIRSP0 );
*(respBuff + 2) = (BYTE)(vm_pSDIReg->SDIRSP0 >> 8 );
*(respBuff + 3) = (BYTE)(vm_pSDIReg->SDIRSP0 >> 16);
*(respBuff + 4) = (BYTE)(vm_pSDIReg->SDIRSP0 >> 24);
*(respBuff + 5) = (BYTE)(END_RESERVED | END_BIT);
break;
case ResponseR3:
case ResponseR4:
// Format: { START_BIT(1) | TRANSMISSION_BIT(1) | RESERVED(6) | CARD_STATUS(32) | RESERVED(7) | END_BIT(1) }
*(respBuff ) = (BYTE)(START_BIT | TRANSMISSION_BIT | START_RESERVED);
break;
case ResponseR5:
case ResponseR6:
// Format: { START_BIT(1) | TRANSMISSION_BIT(1) | COMMAND_INDEX(6) | RCA(16) | CARD_STATUS(16) | CRC7(7) | END_BIT(1) }
*(respBuff + 5) = (BYTE)(vm_pSDIReg->SDIRSP1 >> 24);
break;
case ResponseR2:
//--- LONG RESPONSE (136 bits total)---
// Format: { START_BIT(1) | TRANSMISSION_BIT(1) | RESERVED(6) | CARD_STATUS(127) | END_BIT(1) }
// NOTE: In this implementation, the caller doesn't require the upper 8 bits of reserved data.
// Consequently, these bits aren't included and the response info is copied directly into
// the beginning of the supplied buffer.
//*(respBuff ) = (BYTE)(START_BIT | TRANSMISSION_BIT | START_RESERVED);
*(respBuff + 0) = (BYTE)(vm_pSDIReg->SDIRSP3 );
*(respBuff + 1) = (BYTE)(vm_pSDIReg->SDIRSP3 >> 8 );
*(respBuff + 2) = (BYTE)(vm_pSDIReg->SDIRSP3 >> 16);
*(respBuff + 3) = (BYTE)(vm_pSDIReg->SDIRSP3 >> 24);
*(respBuff + 4) = (BYTE)(vm_pSDIReg->SDIRSP2 );
*(respBuff + 5) = (BYTE)(vm_pSDIReg->SDIRSP2 >> 8 );
*(respBuff + 6) = (BYTE)(vm_pSDIReg->SDIRSP2 >> 16);
*(respBuff + 7) = (BYTE)(vm_pSDIReg->SDIRSP2 >> 24);
*(respBuff + 8) = (BYTE)(vm_pSDIReg->SDIRSP1 );
*(respBuff + 9) = (BYTE)(vm_pSDIReg->SDIRSP1 >> 8 );
*(respBuff + 10)= (BYTE)(vm_pSDIReg->SDIRSP1 >> 16);
*(respBuff + 11)= (BYTE)(vm_pSDIReg->SDIRSP1 >> 24);
*(respBuff + 12)= (BYTE)(vm_pSDIReg->SDIRSP0 );
*(respBuff + 13)= (BYTE)(vm_pSDIReg->SDIRSP0 >> 8 );
*(respBuff + 14)= (BYTE)(vm_pSDIReg->SDIRSP0 >> 16);
*(respBuff + 15)= (BYTE)(vm_pSDIReg->SDIRSP0 >> 24);
break;
default:
DEBUGMSG(SDCARD_ZONE_ERROR, (TEXT("SDHCD:GetCmdResponse(): Unrecognized response type!\r\n")));
break;
}这里也没有ResponseR7。
我想要修改就是要修改这两处吧,应该怎么改呢?
