167879|3
7056
【国民技术N32WB031_STB开发板评测】驱动HS3003 [复制链接]
目的
驱动hs3003温湿度计
步骤
  1. 在原来墨水屏的工程基础上添加HS3003的驱动。
  2. 新建hs3003.c/hs3003.h,并打hs3003.c加入工程。
  3. 我偿试用硬件驱动i2c,但scl即使使用了上位电阻,也不起振,用逻辑分析仪检测如下图:
  4. 周转了半天,还得改回来用软件i2c来驱动。hs3003.c驱动程序如下:
#include "hs3003.h"
#include "software_i2c.h"
#include "log.h"
#define I2CT_FLAG_TIMEOUT ((uint32_t)0x1000)
#define I2CT_LONG_TIMEOUT ((uint32_t)(20 * I2CT_FLAG_TIMEOUT))
#define SI2C_SDA_GPIOx  GPIOB
#define SI2C_SCL_GPIOx  GPIOB
#define SI2C_SDA_Pin    GPIO_PIN_8
#define SI2C_SCL_Pin    GPIO_PIN_9
static SI2C_HANDLE SI2C_handle;
void i2c_master_init(){
    log_info("n this is a software i2c master demorn");
  if(SI2C_Init(&SI2C_handle,SI2C_SDA_GPIOx, SI2C_SCL_GPIOx, SI2C_SDA_Pin, SI2C_SCL_Pin, 5) == false)
    log_info("software i2c init fail rn");
        while(1);
uint32_t Humiture_HS3003_ReadData_Raw(void )
    uint8_t rx_buf[4] = {0};
    uint16_t humi, temp;
    float    tmp_f   = 0.0;
        float humi_f,temp_f;
    SI2C_MasterWrite(&SI2C_handle,I2C_SLAVE_ADDR, NULL, 0);
    //8bit->1.2ms
    //10bit->2.72ms
    //12bit->9.10ms
    //14bit->33.90ms
      Delay_ms(40);
__retry:
    SI2C_MasterRead(&SI2C_handle, I2C_SLAVE_ADDR, rx_buf, 4);
//      log_info("%x,%x,%x,%xn", rx_buf[0], rx_buf[1], rx_buf[2], rx_buf[3]);
//    log_info("state:%xn", rx_buf[0] & RM_HS300X_MASK_STATUS_0XC0);
        if ((rx_buf[0] & RM_HS300X_MASK_STATUS_0XC0) != RM_HS300X_DATA_STATUS_VALID)
            Delay_ms(100);
            goto __retry;
        humi = (rx_buf[0] & RM_HS300X_MASK_HUMIDITY_UPPER_0X3F) << 8 | rx_buf[1];
        temp = (rx_buf[2] << 8 | (rx_buf[3] & RM_HS300X_MASK_TEMPERATURE_LOWER_0XFC)) >> 2;
        humi_f = (float)humi;
        humi_f = (humi_f * RM_HS300X_CALC_HUMD_VALUE_100) / RM_HS300X_CALC_STATIC_VALUE;
        temp_f = (float)temp;
        temp_f = ((temp_f * RM_HS300X_CALC_TEMP_C_VALUE_165) / RM_HS300X_CALC_STATIC_VALUE) - RM_HS300X_CALC_TEMP_C_VALUE_40;
        log_info("Temp:%d.%d   ",(int)temp_f,(int)(temp_f*100)%100);
        log_info("HUMI:%d.%drn",(int)humi_f,(int)(humi_f*100)%100);
    return 1;
bool Humiture_HS3003_init(void)
    i2c_master_init();
  1. hs3003.h:
#ifndef __HS3003_H__
#define __HS3003_H__
#include "n32wb03x.h"
#define I2C_MASTER_ADDR   0x30
#define I2C_SLAVE_ADDR        0x44<<1
#define HS300X_HUMD_MULTY           0.00006163516
#define HS300X_TEMP_MULTY           0.00006163516
/* Definitions of Mask Data for A/D data */
#define RM_HS300X_MASK_HUMIDITY_UPPER_0X3F       (0x3F)
#define RM_HS300X_MASK_TEMPERATURE_LOWER_0XFC    (0xFC)
#define RM_HS300X_MASK_STATUS_0XC0               (0xC0)
/* Definitions for Status Bits of A/D Data */
#define RM_HS300X_DATA_STATUS_VALID              (0x00) // Status-bit: Valid data
/* Definitions for Calculation */
#define RM_HS300X_CALC_STATIC_VALUE              (16383.0F)
#define RM_HS300X_CALC_HUMD_VALUE_100            (100.0F)
#define RM_HS300X_CALC_TEMP_C_VALUE_165          (165.0F)
#define RM_HS300X_CALC_TEMP_C_VALUE_40           (40.0F)
#define RM_HS300X_CALC_DECIMAL_VALUE_100         (100.0F)
bool Humiture_HS3003_init(void);
uint32_t Humiture_HS3003_ReadData_Raw(void );
#endif
7、在主程序中调用一下:
#include "main.h"
#include "led.h"
#include "key.h"
#include "log.h"
#include "hs3003.h"
unsigned char BlackImage[4736];//Define canvas space
int main(void)
     unsigned char fen_L,fen_H,miao_L,miao_H;
      log_init();
        Humiture_HS3003_init();
        Humiture_HS3003_ReadData_Raw();
    while (1)
            Delay_ms(1000);
实验效果
总结
不知道是不是硬件i2c的驱动是不是有问题,反正我的浪费了半天的时间,各种工具用上,最后还是得用软件才搞定。
此帖出自无线连接论坛
写的不错,学习了。加油使自己更优秀!!!   详情 回复 发表于 2023-11-29 18:51
6828
N32WB031_STB开发板哪里有
国民技术的资料好像不多
此帖出自无线连接论坛
论坛里评测申请到的。国民技术官网也有卖,不过价格不便宜呀。  详情 回复 发表于 2023-5-2 22:23
7056
Jacktang 发表于 2023-5-2 21:49 N32WB031_STB开发板哪里有 国民技术的资料好像不多
此帖出自无线连接论坛
419
此帖出自无线连接论坛
