2999|1
67
uClinux编译的make image时出错了,急救…… [复制链接]
make image时出错,下面是出错提示:
arm-linux-objcopy -O binary --remove-section=.romvec \
                        --remove-section=.text --remove-section=.ramvec \
                        --remove-section=.init \
                        --remove-section=.bss --remove-section=.eram \
                        /home/yuxiaohua/uClinux-dist/linux-2.4.x/linux /home/yuxiaohua/uClinux-dist/images/linux.data
arm-linux-objcopy: '/home/yuxiaohua/uClinux-dist/linux-2.4.x/linux': No such file
make[2]: *** [image] 错误 1
make[2]: Leaving directory `/home/yuxiaohua/uClinux-dist/vendors/Samsung/4510B'
make[1]: *** [image] 错误 2
make[1]: Leaving directory `/home/yuxiaohua/uClinux-dist/vendors'
make: *** [image] 错误 2
此帖出自Linux开发论坛
arm-linux-arm-linux-objcopy: '/home/yuxiaohua/uClinux-dist/linux-2.4.x/linux': No such file 文件不存在,可能是一个无效的链接文件,检查看看吧   详情 回复 发表于 2009-10-22 12:41
78
此帖出自Linux开发论坛
