2823|10
2640
RT1052 (7) 驱动SPI-DAC [复制链接]
       首先在Bsp文件夹新建DAC目录,如下所示,因为是基于第4篇的工程文件,所以直接从第4篇下载工程文件即可。
图1:BSP文件夹
图2:放入DAC驱动
Dac .c文件
#include "AD5668.h"
    Channel Selection Range 1~16
    Value Range 0~65535
void DAC_Write(uint8_t channel,uint16_t Value)
    uint16_t Date,temp;
    if(channel<=8)
        DAC_CS1_L;
        /* Select Channel */
        Date=WriteAndUpDateCh;
        Date<<=4;
        Date|=channel-1;
        Date<<=4;
        temp=Value>>12;
        Date|=temp;
        Soft_SPI_Write(Date);
        Date=Value<<4;
        DAC_CS1_H;
    else
        DAC_CS2_L;
        Date<<=4;
        Date|=channel-9;
        Date<<=4;
        temp=Value>>12;
        Date|=temp;
        Date=Value<<4;
        DAC_CS2_H;
    Initial DAC GPIO
void DAC_Init(void)
    GPIO_InitTypeDef GPIO_InitStruct;
    __HAL_RCC_GPIOC_CLK_ENABLE();
    GPIO_InitStruct.Pin = DAC_CLR_PIN;
    GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
    GPIO_InitStruct.Pull = GPIO_PULLDOWN;
    GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
    HAL_GPIO_Init(DAC_CLR_PORT,&GPIO_InitStruct);
    DAC_CLR_L;
    /* OPEN INTERANL REFERENCE */
    DAC_CS1_L;
    Soft_SPI_Write(0x08f0);
    Soft_SPI_Write(0x0001);
    DAC_CS1_H;
    DAC_CS2_L;
    DAC_CS2_H;
Dac.h文件
#ifndef __AD5668_H
#define __AD5668_H
#include "main.h"
#include "STM32_SPI.h"
    AD5668 COMMAND AND ADDRESS
    MSB
    31 30 29 28  27 26 25 24
    X   X  X  X  C3 C2 C1 C0
    23 22 21 20  19         ->      5
    A3 A2 A1 A0  Data Msb-> DataLSB
    4 3 2 1
    X X X X
    COMMAND
#define  UpdateDacReg               0X01
#define  WriteAndUpDateCh       0x03
#define  ResetDac                       0x07
#define  SetUpRef                       0x80
    ADDRESS
#define  ChannelA                       0X00
#define  ChannelB                       0X01
#define  ChannelC                       0X02
#define  ChannelD                       0X03
#define  ChannelE                       0X04
#define  ChannelF                       0X05
#define  ChannelG                       0X06
#define  ChannelH                       0X07
#define  ChannelAll                 0X0F
    Ctrl GPIO redefine
#define  DAC_CS1_L          SF_NSS1_L
#define  DAC_CS1_H          SF_NSS1_H
#define  DAC_CS2_L          SF_NSS2_L
#define  DAC_CS2_H          SF_NSS2_H
#define  DAC_CLR_PORT       GPIOC
#define  DAC_CLR_PIN        GPIO_PIN_13
#define  DAC_CLR_H          HAL_GPIO_WritePin(DAC_CLR_PORT,DAC_CLR_PIN,GPIO_PIN_SET)
#define  DAC_CLR_L          HAL_GPIO_WritePin(DAC_CLR_PORT,DAC_CLR_PIN,GPIO_PIN_RESET)
    Channel Selection Range 1~8
    Value Range 0~65535
void DAC_Init(void);
void DAC_Write(uint8_t channel,uint16_t Value);
#endif
       因为是拷贝之前STM32的驱动,所以还要进行一些修改,先不管。
图3:在User里面添加驱动
图4:添加头文件路径1
图5:添加头文件路径2
因为是修改STM32的驱动,其本质没有啥差别,从RT1052(2)工具生成代码 那个章节直接copy代码过来就行。
Bsp_lpspi.c文件
#include "fsl_iomuxc.h"
#include "fsl_gpio.h"
#include "fsl_lpspi.h"
#include "pad_config.h"
#include "bsp_lpspi.h"
static void LPSPI_GPIO_Init(void);
     IOMUXC_SetPinMux(
      IOMUXC_GPIO_AD_B0_00_LPSPI3_SCK,        /* GPIO_AD_B0_00 is configured as LPSPI3_SCK */
      0U);                                    /* Software Input On Field: Input Path is determined by functionality */
  IOMUXC_SetPinMux(
      IOMUXC_GPIO_AD_B0_01_LPSPI3_SDO,        /* GPIO_AD_B0_01 is configured as LPSPI3_SDO */
  IOMUXC_SetPinMux(
      IOMUXC_GPIO_AD_B0_02_LPSPI3_SDI,        /* GPIO_AD_B0_02 is configured as LPSPI3_SDI */
  IOMUXC_SetPinMux(
      IOMUXC_GPIO_AD_B0_03_LPSPI3_PCS0,       /* GPIO_AD_B0_03 is configured as LPSPI3_PCS0 */
      0U);
void LPSPI_Init(void)
    //config Lpspi clock
    CLOCK_SetMux(kCLOCK_LpspiMux, 3);
    CLOCK_SetDiv(kCLOCK_LpspiDiv, 7U);
    //initial Gpio config
    LPSPI_GPIO_Init();
    //initial lpspi config
    lpspi_master_config_t config;
    LPSPI_MasterGetDefaultConfig(&config);
    //config lpspi cs pin
    config.whichPcs=kLPSPI_Pcs0;
    LPSPI_MasterInit(LPSPI3, &config, LPSPI3_CLOCK_FREQ);
void Lpspi_Write(uint8_t datasize,uint8_t *data)
    lpspi_transfer_t spi_tranxfer;
    spi_tranxfer.configFlags=kLPSPI_MasterPcs0|kLPSPI_MasterPcsContinuous | kLPSPI_MasterByteSwap;
    spi_tranxfer.txData=data; //要发送的数据
    spi_tranxfer.rxData=NULL;
    spi_tranxfer.dataSize=datasize; //数据长度
    LPSPI_MasterTransferBlocking(LPSPI3, &spi_tranxfer);
Bsp_lpspi.h文件
#ifndef __BSP_LPSPI_H
#define __BSP_LPSPI_H
#include "fsl_common.h"
#define LPSPI3_CLOCK_FREQ 6000000UL
void LPSPI_Init(void);
#endif /* __BSP_LPSPI_H */
Github 地址:
https://github.com/xutong-analog/fantasy/tree/main/RT1052/lpspi
测试下驱动波形
图6:lpspi驱动波形
再给AD5668套层壳
AD5668.C
#include "AD5668.h"
#include "board.h"
       Value Range 0~65535
        uint8_t data[4];
        data[0]=WriteAndUpDateCh;
        data[1]=(Value>>12)|channel;
        data[2]=(Value>>4)&0x00ff;
        data[3]=(Value&0x000f)<<4;
        Lpspi_Write(4,data);
       Initial DAC GPIO
void DAC_Init(void)
       //DAC_CLR_L;
        uint8_t data[4]={0x08,0xf0,0x00,0x01};
AD5668.H
#ifndef __AD5668_H
#define __AD5668_H
       MSB
       X   X  X  X  C3 C2 C1 C0
       23 22 21 20  19         ->         5
       4 3 2 1
       X X X X
       COMMAND
       ADDRESS
#define  ChannelB                                         0X10
#define  ChannelC                                        0X20
#define  ChannelD                                        0X30
#define  ChannelE                                         0X40
#define  ChannelF                                         0X50
#define  ChannelG                                        0X60
#define  ChannelH                                        0X70
#define  ChannelAll                                0XF0
       Ctrl GPIO redefine
       Value Range 0~65535
#endif
掏出开发板
图7:DAC开发板
图8:DAC输出结果
图9:测试环境
参考文档:
Eeworld 10*10的洞洞板—xutong
Eeworld RT1052(2)工具生成代码 —xutong
Adi ad5668 datasheet
此帖出自NXP MCU论坛
哈哈,好吧   详情 回复 发表于 2023-4-24 09:24
希望做一些大家觉得好用的东西!
2640
RTT NANO.7z (20.82 MB, 下载次数: 6)
此帖出自NXP MCU论坛
希望做一些大家觉得好用的东西!
2640
github地址
此帖出自NXP MCU论坛
希望做一些大家觉得好用的东西!
2640
更新驱动代码:
#include "AD5668.h"
#include "board.h"
	Value Range 0~65535
    uint8_t data[4];
     //command modify
    data[0]=WriteToReg;
    //WriteAndUpDateCh
    // command modify
void DAC_Command_Write(uint8_t Command,uint8_t channel,uint16_t Value)
    uint8_t data[4];
     //command modify
    data[0]=Command;
    //WriteAndUpDateCh
    // command modify
	Initial DAC GPIO
void DAC_Init(void)
    //DAC_CLR_L;
void DAC_Reset(void)
    // no significance data
    uint8_t data[4]={0x00,0xf0,0x00,0x01};
     //command modify
    data[0]=ResetDac;
void SoftLdac(void)
    uint8_t data[4]={0x06,0x00,0x00,0xFF};
#ifndef __AD5668_H
#define __AD5668_H
	MSB
	X   X  X  X  C3 C2 C1 C0
	23 22 21 20  19 		-> 		5
	4 3 2 1
	X X X X
	COMMAND
#define  WriteToReg			        0X00
#define  WriteAndUpDateAll			0X02
#define  PowerDownAndPowerUpDac		        0x04
#define  loadClearReg		                0x05
#define  loadLdacReg		                0x06
	ADDRESS
	Ctrl GPIO redefine
	Value Range 0~65535
void DAC_Command_Write(uint8_t Command,uint8_t channel,uint16_t Value);
void DAC_Reset(void);
void SoftLdac(void);
#endif
此帖出自NXP MCU论坛
希望做一些大家觉得好用的东西!
2640
再次更新驱动代码:
     IOMUXC_SetPinMux(
  IOMUXC_SetPinMux(
  IOMUXC_SetPinMux(
  IOMUXC_SetPinMux(
      0U);
    LPSPI_GPIO_Init();
   // config.cpol=kLPSPI_ClockPolarityActiveLow;
    // 使用ADX112 直接使用此配置
    config.cpha=kLPSPI_ClockPhaseSecondEdge;
//写数据
//读写数据
void Lpspi_Read(uint8_t datasize,uint8_t *data,uint8_t *Rxdata)
    spi_tranxfer.rxData=Rxdata; //要接收的数据
//xue
void Lpspi_Write(uint8_t datasize,uint8_t *data);
void Lpspi_Read(uint8_t datasize,uint8_t *data,uint8_t *Rxdata);
可以直接驱动ADX112
  * [url=home.php?mod=space&uid=1307177]@File[/url] main.c
  * [url=home.php?mod=space&uid=1315547]@author[/url] fire
  * [url=home.php?mod=space&uid=252314]@version[/url] V1.0
  * [url=home.php?mod=space&uid=311857]@date[/url] 2018-xx-xx
  * [url=home.php?mod=space&uid=159083]@brief[/url] GPIO输入—按键中断检测
  * [url=home.php?mod=space&uid=1020061]@attention[/url] *
  * 实验平台:野火  i.MXRT1052开发板
  * 论坛    :http://www.firebbs.cn
  * 淘宝    :http://firestm32.taobao.com
#include "board.h"
#include "fsl_debug_console.h"
#include "fsl_gpt.h"
#include "pin_mux.h"
#include "clock_config.h"
#include "fsl_lpi2c.h"
#include "./bsp/nvic/bsp_nvic.h"
#include "./bsp/led/bsp_led.h"
#include "./bsp/key/bsp_key_it.h"
#include "ad5668.h"
#include "fsl_adc.h"
#include "rtthread.h"
#include "bsp_lpi2c.h"
#include "AnalogysemiCSD.h"
// 添加adc的返回值用于打印
volatile uint16_t ADC_Value;
uint8_t datas[]={0x04,0x9A,0x04,0X9A};
uint8_t Rdatas[2];
/*******************************************************************kkokkkkkkkkkkk
 * Prototypes
 * @brief 延时一段时间
void delay(uint32_t count);
 * Code
 * @note 本函数在不同的优化模式下延时时间不同,
 *       如flexspi_nor_debug和flexspi_nor_release版本的程序中,
 *       flexspi_nor_release版本的延时要短得多
    volatile uint32_t i = 0;
    for (i = 0; i < count; ++i)
        __asm("NOP"); /* 调用nop空指令 */
// 步骤2:新建ADC初始化函数
void RT1052_ADC_Init(void)
   adc_config_t adcConfigStruct;
   adc_channel_config_t adcChannelConfigStruct;
     *  config->enableAsynchronousClockOutput = true;
     *  config->enableOverWrite =               false;
     *  config->enableContinuousConversion =    false;
     *  config->enableHighSpeed =               false;
     *  config->enableLowPower =                false;
     *  config->enableLongSample =              false;
     *  config->referenceVoltageSource =        kADC_ReferenceVoltageSourceVref;
     *  config->samplePeriodMode =              kADC_SamplePeriod2or12Clocks;
     *  config->clockSource =                   kADC_ClockSourceAD;
     *  config->clockDriver =                   kADC_ClockDriver1;
     *  config->resolution =                    kADC_Resolution12Bit;
    ADC_GetDefaultConfig(&adcConfigStruct);
    //最大resolution 12bit 只有外部参考
    //adcConfigStruct.referenceVoltageSource=kADC_ReferenceVoltageSourceAlt0;
    //开启连续转换模式
    adcConfigStruct.enableContinuousConversion=true;
    ADC_Init(ADC1, &adcConfigStruct);
    //开启ADC中断
    EnableIRQ(ADC1_IRQn);
    //开启ADC1 自动校准
    ADC_DoAutoCalibration(ADC1);
    //关闭硬件触发
    ADC_EnableHardwareTrigger(ADC1, false);
    //读取通道0
    adcChannelConfigStruct.channelNumber                        = 0;
    adcChannelConfigStruct.enableInterruptOnConversionCompleted = true;
    // Channe_group  0 用于软件或者硬件出发
    ADC_SetChannelConfig(ADC1, 0u /*ADC_CHANNEL_GROUP*/, &adcChannelConfigStruct);
// ADC 中断入口函数
void  ADC1_IRQHandler(void)
  ADC_Value= ADC_GetChannelConversionValue(ADC1, 0U);
  rt_kprintf("ADC_Value :%d\r\n",ADC_Value);
  * @brief  主函数
  * @param  无
  * @retval 无
int main(void)
   // uint16_t BusVoltage;
    rt_kprintf("hello analogysemi \r\n");
    User_GPIO_Init();
    LPSPI_Init();
    Lpspi_Read(4,datas,Rdatas);
    while(1)
        rt_thread_mdelay(10);
/*********************************************END OF FILE**********************/
ADX112 测温结果输出
此帖出自NXP MCU论坛
希望做一些大家觉得好用的东西!
2640
#include "board.h"
#include "ad5668.h"
// 添加adc的返回值用于打印
 * Prototypes
 * @brief 延时一段时间
 * Code
// 步骤2:新建ADC初始化函数
    //开启连续转换模式
    //开启ADC中断
    //开启ADC1 自动校准
    //关闭硬件触发
    //读取通道0
// ADC 中断入口函数
  * @brief  主函数
  * @param  无
  * @retval 无
 int main(void)
    User_GPIO_Init();
    LPSPI_Init();
//    RT1052_ADC_Init();
//        //读取通道0
//    adc_channel_config_t adcChannelConfigStruct;
//    adcChannelConfigStruct.channelNumber                        = 0;
//    adcChannelConfigStruct.enableInterruptOnConversionCompleted = true;
     DAC_Init();
     rt_thread_mdelay(1);
    while(1)
//      RGB_RED_LED_ON;
    DAC_Write(ChannelA,0x55aa);
     DAC_Write(ChannelA,0xaa55);
//       ADC_SetChannelConfig(ADC1, 0u /*ADC_CHANNEL_GROUP*/, &adcChannelConfigStruct);
//      rt_thread_mdelay(500);
主程序
此帖出自NXP MCU论坛
希望做一些大家觉得好用的东西!
7608
这个波形看起来不太干净呢?
此帖出自NXP MCU论坛
线飞来飞去,接地没夹好  详情 回复 发表于 2023-4-22 09:33
默认摸鱼,再摸鱼。2022、9、28
2640
freebsder 发表于 2023-4-21 23:19 这个波形看起来不太干净呢?
线飞来飞去,接地没夹好
此帖出自NXP MCU论坛
希望做一些大家觉得好用的东西!
7608
xutong 发表于 2023-4-22 09:33 线飞来飞去,接地没夹好
哈哈,好吧
此帖出自NXP MCU论坛
快速验下,快速搞下个东西  详情 回复 发表于 2023-4-24 11:05
默认摸鱼,再摸鱼。2022、9、28
2640
快速验下,快速搞下个东西
此帖出自NXP MCU论坛
希望做一些大家觉得好用的东西!
2640
  analogysemi
  xutong 2023/10/19
#include "stm32h7xx_hal.h"
#define SPIx                             SPI1
#define SPIx_CLK_ENABLE()                __HAL_RCC_SPI1_CLK_ENABLE()
#define SPIx_SCK_GPIO_CLK_ENABLE()       __HAL_RCC_GPIOB_CLK_ENABLE()
#define SPIx_MISO_GPIO_CLK_ENABLE()      __HAL_RCC_GPIOB_CLK_ENABLE()
#define SPIx_MOSI_GPIO_CLK_ENABLE()      __HAL_RCC_GPIOB_CLK_ENABLE()
#define SPIx_CS_GPIO_CLK_ENABLE()      __HAL_RCC_GPIOB_CLK_ENABLE()
/* Definition for SPIx Pins */
#define SPIx_SCK_PIN                     GPIO_PIN_3
#define SPIx_SCK_GPIO_PORT               GPIOB
#define SPIx_SCK_AF                      GPIO_AF5_SPI1
#define SPIx_MISO_PIN                    GPIO_PIN_4
#define SPIx_MISO_GPIO_PORT              GPIOB
#define SPIx_MISO_AF                     GPIO_AF5_SPI1
#define SPIx_MOSI_PIN                    GPIO_PIN_5
#define SPIx_MOSI_GPIO_PORT              GPIOB
#define SPIx_MOSI_AF                     GPIO_AF5_SPI1
#define SPIx_CS_PIN                      GPIO_PIN_6
#define SPIx_CS_GPIO_PORT                GPIOB
SPI_HandleTypeDef SpiHandle;
void Spi_delay(uint32_t count)
    /* Enable SPI1 clock */
    SPIx_CLK_ENABLE();
    SPIx_SCK_GPIO_CLK_ENABLE();
    SPIx_MISO_GPIO_CLK_ENABLE();
    SPIx_MOSI_GPIO_CLK_ENABLE();
    SPIx_CS_GPIO_CLK_ENABLE();
    /* 初始化GPIO 配置*/
    /*##-1- Configure peripheral GPIO ##########################################*/
    /* SPI SCK GPIO pin configuration  */
    GPIO_InitStruct.Pin       = SPIx_SCK_PIN;
    GPIO_InitStruct.Mode      = GPIO_MODE_AF_PP;
    GPIO_InitStruct.Speed     = GPIO_SPEED_FREQ_HIGH;
    GPIO_InitStruct.Alternate = SPIx_SCK_AF;
    HAL_GPIO_Init(SPIx_SCK_GPIO_PORT, &GPIO_InitStruct);
    /* SPI MISO GPIO pin configuration  */
    GPIO_InitStruct.Pin = SPIx_MISO_PIN;
    GPIO_InitStruct.Alternate = SPIx_MISO_AF;
    HAL_GPIO_Init(SPIx_MISO_GPIO_PORT, &GPIO_InitStruct);
    /* SPI MOSI GPIO pin configuration  */
    GPIO_InitStruct.Pin = SPIx_MOSI_PIN;
    GPIO_InitStruct.Alternate = SPIx_MOSI_AF;
    HAL_GPIO_Init(SPIx_MOSI_GPIO_PORT, &GPIO_InitStruct);
   /* SPI CS GPIO pin configuration  */
    GPIO_InitStruct.Pin = SPIx_CS_PIN;
    HAL_GPIO_Init(SPIx_CS_GPIO_PORT, &GPIO_InitStruct);
      /* 初始化SPI 配置*/
     /*##-2- Configure the SPI peripheral #######################################*/
    /* Set the SPI parameters */
    SpiHandle.Instance               = SPIx;
    SpiHandle.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_256;
    SpiHandle.Init.Direction         = SPI_DIRECTION_2LINES;
    SpiHandle.Init.CLKPhase          = SPI_PHASE_1EDGE;
    SpiHandle.Init.CLKPolarity       = SPI_POLARITY_HIGH;
    SpiHandle.Init.DataSize          = SPI_DATASIZE_8BIT;
    SpiHandle.Init.FirstBit          = SPI_FIRSTBIT_MSB;
    SpiHandle.Init.TIMode            = SPI_TIMODE_DISABLE;
    SpiHandle.Init.CRCCalculation    = SPI_CRCCALCULATION_DISABLE;
    SpiHandle.Init.CRCPolynomial     = 7;
    SpiHandle.Init.NSS               = SPI_NSS_SOFT;
    SpiHandle.Init.Mode              = SPI_MODE_MASTER;
    //初始化SPI
    HAL_SPI_Init(&SpiHandle);
    //默认拉高CS引脚
    HAL_GPIO_WritePin(SPIx_CS_GPIO_PORT,SPIx_CS_PIN,GPIO_PIN_SET);
  //写数据
  HAL_GPIO_WritePin(SPIx_CS_GPIO_PORT,SPIx_CS_PIN,GPIO_PIN_RESET);
  HAL_SPI_Transmit(&SpiHandle,data, datasize, 5000);
  Spi_delay(30);
//  读写数据
  HAL_SPI_TransmitReceive(&SpiHandle,data,Rxdata, datasize, 5000);
  Spi_delay(30);
转换为STM32能用的头文件
此帖出自NXP MCU论坛
希望做一些大家觉得好用的东西!
