3417|1
659
ESP32灯光特效——点亮WS2812炫彩灯带; [复制链接]
    1. 下载附件  保存到相册
      2022-10-24 15:38 上传
      35下载附件  保存到相册
      2022-10-24 15:38 上传
      36  blink例程运行结果截图
      从代码中中可知采用RMT的通道1,通过IO-MUX连接到GPIO48,观察ESP32-S3-DevKitC,GPIO48在排针上引出,刚好手头有WS2812的LED灯带,接入GPIO48排针引脚,并利用网上的一个比较炫酷的WS2812-LED-Strip光效程序,因略作修改代码后,生成绚丽的颜色,传输到灯带显示,代码如下:
      #define LED_COUNTS 32
      static uint8_t showType = 0;
      void delay(uint8_t n)
      vTaskDelay(n/portTICK_PERIOD_MS);
      int numPixels()
      return LED_COUNTS;
      void show()
      pStrip_a->refresh(pStrip_a, 100);
      void setPixelColor(int led_index, uint32_t c)
      // WS2812 is in the order of GRB
      if(led_index < LED_COUNTS) {
      uint8_t g = (uint8_t)(c >> 8 & 0xFF);
      uint8_t r = (uint8_t)(c >> 16 & 0xFF);
      uint8_t b = (uint8_t)(c >> 0 & 0xFF);
      pStrip_a->set_pixel(pStrip_a, led_index, r, g, b);
      return ;
      uint32_t Color(uint8_t r, uint8_t g, uint8_t b)
      uint32_t retVal;
      retVal = (( uint32_t)r<< 16)
      + ( (uint32_t)g << 8)
      + (uint32_t)b ;
      return retVal;
      // Fill the dots one after the other with a color
      void colorWipe(uint32_t c, uint8_t wait) {
        for(uint16_t i=0; i<numPixels(); i++) {
          setPixelColor(i, c);
          show();
          delay(wait);
      // Input a value 0 to 255 to get a color value.
      // The colours are a transition r - g - b - back to r.
      uint32_t Wheel(uint8_t WheelPos) {
        WheelPos = 255 - WheelPos;
        if(WheelPos < 85) {
          return Color(255 - WheelPos * 3, 0, WheelPos * 3);
        if(WheelPos < 170) {
          WheelPos -= 85;
          return Color(0, WheelPos * 3, 255 - WheelPos * 3);
        WheelPos -= 170;
        return Color(WheelPos * 3, 255 - WheelPos * 3, 0);
      void rainbow(uint8_t wait) {
        uint16_t i, j;
        for(j=0; j<256; j++) {
          for(i=0; i<numPixels(); i++) {
            setPixelColor(i, Wheel((i+j) & 255));
          show();
          delay(wait);
      // Slightly different, this makes the rainbow equally distributed throughout
      void rainbowCycle(uint8_t wait) {
        uint16_t i, j;
        for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
          for(i=0; i< numPixels(); i++) {
            setPixelColor(i, Wheel(((i * 256 / numPixels()) + j) & 255));
          show();
          delay(wait);
      //Theatre-style crawling lights.
      void theaterChase(uint32_t c, uint8_t wait) {
        for (int j=0; j<10; j++) {  //do 10 cycles of chasing
          for (int q=0; q < 3; q++) {
            for (int i=0; i < numPixels(); i=i+3) {
              setPixelColor(i+q, c);    //turn every third pixel on
            show();
            delay(wait);
              setPixelColor(i+q, 0);        //turn every third pixel off
      //Theatre-style crawling lights with rainbow effect
      void theaterChaseRainbow(uint8_t wait) {
        for (int j=0; j < 256; j++) {     // cycle all 256 colors in the wheel
              setPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel on
            show();
            delay(wait);
      void startShow(int i) {
        switch(i){
          case 0: colorWipe(Color(0, 0, 0), 50);    // Black/off
                  break;
          case 1: colorWipe(Color(255, 0, 0), 50);  // Red
                  break;
          case 2: colorWipe(Color(0, 255, 0), 50);  // Green
                  break;
          case 3: colorWipe(Color(0, 0, 255), 50);  // Blue
                  break;
          case 4: theaterChase(Color(127, 127, 127), 50); // White
                  break;
          case 5: theaterChase(Color(127,   0,   0), 50); // Red
                  break;
          case 6: theaterChase(Color(  0,   0, 127), 50); // Blue
                  break;
          case 7: rainbow(20);
                  break;
          case 8: rainbowCycle(5);
                  break;
          case 9: theaterChaseRainbow(10);
                  break;
      效果如图/视频
      https://www.bilibili.com/video/BV1wN4y157cM/
看了效果视频,很酷炫 [attach]651192[/attach]     详情 回复 发表于 2022-10-25 08:37
6917
看了效果视频,很酷炫
快来报名!
