求大神:怎么把电子锁的密码长度由6位数改成16位的啊
各位大神,小白在此向你们跪求了!我想把这个红外遥控的电子密码锁的密码长度从原来的6位改成16位的,却没有成功。原程序如下
#include <REG52.h>
#include<intrins.h> //包含头文件
#define LCM_Data P0 //宏定义P0口为LCM_Data
#define uchar unsigned char
#define uint unsigned int //宏定义
//时间计算
#define Imax 14000 //此处为晶振为11.0592时的取值,
#define Imin 8000 //如用其它频率的晶振时,
#define Inum1 1450 //要改变相应的取值。
#define Inum2 700
#define Inum3 3000
sbit lcd1602_rs=P2^5;
sbit lcd1602_rw=P2^6;
sbit lcd1602_en=P2^7; //定义液晶的控制引脚
sbit Scl=P3^4; //24C02串行时钟
sbit Sda=P3^5; //24C02串行数据
sbit ALAM = P2^1; //报警
sbit KEY = P3^6; //开锁
bit pass=0; //密码正确标志
bit ReInputEn=0; //重置输入充许标志
bit s3_keydown=0; //3秒按键标志位
bit key_disable=0; //锁定键盘标志
unsigned char countt0,second; //t0中断计数器,秒计数器
//解码变量
unsigned char Im[4]={0x00,0x00,0x00,0x00};
//全局变量
uchar f;
unsigned long m,Tc;
unsigned char IrOK;
unsigned char code a[]={0xFE,0xFD,0xFB,0xF7}; //控盘扫描控制表
unsigned char code start_line[] = {"password: "};//输入密码界面
unsigned char code name[] = {"===Coded Lock==="};//显示名称
unsigned char code Error[] = {" error "};//输入错误
unsigned char code LockOpen[] = {" open "};//OPEN开锁显示
unsigned char code SetNew[] = {"SetNewWordEnable"};//设置新密码界面
unsigned char code Input[] = {"input: "};//INPUT输入密码界面
unsigned char code ResetOK[] = {"ResetPasswordOK "};//重置密码成功
unsigned char code initword[] = {"Init password..."};//初始化中
unsigned char code Er_try[] = {"error,try again!"};//输入错误请重新输入
unsigned char code again[] = {"input again "};//再输入一次
unsigned char InputData[6]; //输入密码暂存区
unsigned char CurrentPassword[6]={0,0,0,0,0,0}; //存储密码数组
unsigned char TempPassword[6];
unsigned char N=0; //密码输入位数记数
unsigned char ErrorCont; //错误次数计数
unsigned char CorrectCont; //正确输入计数
unsigned char ReInputCont; //重新输入计数
unsigned char code initpassword[6]={0,0,0,0,0,0}; //输入管理员密码后的初始开锁密码
//=====================5ms延时==============================
void Delay5Ms()
unsigned int TempCyc = 5552;
while(TempCyc--);
//===================400ms延时==============================
void Delay400Ms()
unsigned char TempCycA = 5;
unsigned int TempCycB;
while(TempCycA--)
TempCycB=7269;
while(TempCycB--);
//================================24C02========================================================
void mDelay(uint t) //延时
uchar i;
while(t--)
for(i=0;i<125;i++)
void Nop() //空操作
_nop_();
_nop_();
_nop_();
_nop_();
/*起始条件*/
void Start(void)
Sda=1;
Scl=1;
Nop();
Sda=0;
Nop();
/*停止条件*/
void Stop(void)
Sda=0;
Scl=1;
Nop();
Sda=1;
Nop();
/*应答位*/
void Ack(void)
Sda=0;
Nop();
Scl=1;
Nop();
Scl=0;
/*反向应答位*/
void NoAck(void)
Sda=1;
Nop();
Scl=1;
Nop();
Scl=0;
/*发送数据子程序,Data为要求发送的数据*/
void Send(uchar Data)
uchar BitCounter=8;
uchar temp;
do
temp=Data;
Scl=0;
Nop();
if((temp&0x80)==0x80)
Sda=1;
else
Sda=0;
Scl=1;
temp=Data<<1;
Data=temp;
BitCounter--;
while(BitCounter);
Scl=0;
/*读一字节的数据,并返回该字节值*/
uchar Read()
uchar temp=0;
uchar temp1=0;
uchar BitCounter=8;
Sda=1;
do{
Scl=0;
Nop();
Scl=1;
Nop();
if(Sda)
temp=temp|0x01;
else
temp=temp&0xfe;
if(BitCounter-1)
temp1=temp<<1;
temp=temp1;
BitCounter--;
while(BitCounter);
return(temp);
void WrToROM(uchar Data[],uchar Address,uchar Num)
uchar i;
uchar *PData;
PData=Data;
for(i=0;i<Num;i++)
Start();
Send(0xa0);
Ack();
Send(Address+i);
Ack();
Send(*(PData+i));
Ack();
Stop();
mDelay(20);
void RdFromROM(uchar Data[],uchar Address,uchar Num)
uchar i;
uchar *PData;
PData=Data;
for(i=0;i<Num;i++)
Start();
Send(0xa0);
Ack();
Send(Address+i);
Ack();
Start();
Send(0xa1);
Ack();
*(PData+i)=Read();
Scl=0;
NoAck();
Stop();
//=======================================LCD1602====================================================
#define yi 0x80 //LCD第一行的初始位置,因为LCD1602字符地址首位D7恒定为1(100000000=80)
#define er 0x80+0x40 //LCD第二行初始位置(因为第二行第一个字符位置地址是0x40)
//----------------延时函数,后面经常调用----------------------
void delay(uint xms)//延时函数,有参函数
uint x,y;
for(x=xms;x>0;x--)
for(y=110;y>0;y--);
//--------------------------写指令---------------------------
void write_1602com(uchar com)//****液晶写入指令函数****
lcd1602_rs=0;//数据/指令选择置为指令
lcd1602_rw=0; //读写选择置为写
P0=com;//送入数据
delay(1);
lcd1602_en=1;//拉高使能端,为制造有效的下降沿做准备
delay(1);
lcd1602_en=0;//en由高变低,产生下降沿,液晶执行命令
//-------------------------写数据-----------------------------
void write_1602dat(uchar dat)//***液晶写入数据函数****
lcd1602_rs=1;//数据/指令选择置为数据
P0=dat;//送入数据
delay(1);
lcd1602_en=1; //en置高电平,为制造下降沿做准备
delay(1);
lcd1602_en=0; //en由高变低,产生下降沿,液晶执行命令
//-------------------------初始化-------------------------
void lcd_init()
write_1602com(0x38);//设置液晶工作模式,意思:16*2行显示,5*7点阵,8位数据
write_1602com(0x0c);//开显示不显示光标
write_1602com(0x06);//整屏不移动,光标自动右移
write_1602com(0x01);//清显示
//==============将按键值编码为数值=========================
unsigned char coding(unsigned char m1,unsigned char hh)
unsigned char k;
if(IrOK==1)
IrOK=0;
switch(m1)
case (0x0c): k=1;break;
case (0x18): k=2;break;
case (0x5e): k=3;break;
// case (0xff): k='A';break; //
case (0x08): k=4;break;
case (0x1c): k=5;break;
case (0x5a): k=6;break;
// case (0x82): k='B';break; //
case (0x42): k=7;break;
case (0x52): k=8;break;
case (0x4a): k=9;break;
// case (0x84): k='C';break; //
case (0x43): k='*';break; //撤销
case (0x16): k=0;break;
case (0x15): k='#';break; //确认键
case (0x0d): k='D';break; //重设密码
case (0x45): k='A';break; //
case (0x47): k='A';break; //
case (0x44): k='C';break; //删除按键
case (0x40): k='A';break; //
case (0x07): k='A';break; //
case (0x09): k='A';break; //
case (0x19): k='A';break; //
// default:;
else
switch(hh)
case (0x11): k=1;break;
case (0x21): k=2;break;
case (0x41): k=3;break;
case (0x81): k='A';break;
case (0x12): k=4;break;
case (0x22): k=5;break;
case (0x42): k=6;break;
case (0x14): k=7;break;
case (0x24): k=8;break;
case (0x44): k=9;break;
case (0x84): k='C';break; //删除按键
case (0x18): k='*';break;
case (0x28): k=0;break;
case (0x48): k='#';break;
case (0x88): k='D';break;
// default:;
return(k);
//=====================按键检测并返回按键值===============================
unsigned char keynum()
unsigned char row,col,i;
P1=0xf0;
if((P1&0xf0)!=0xf0)
Delay5Ms();
Delay5Ms();
if((P1&0xf0)!=0xf0)
row=P1^0xf0; //确定行线
i=0;
P1=a; //精确定位
while(i<4)
if((P1&0xf0)!=0xf0)
col=~(P1&0xff); //确定列线
break; //已定位后提前退出
else
i++;
P1=a;
else
return 0;
while((P1&0xf0)!=0xf0);
return (row|col); //行线与列线组合后返回
else return 0; //无键按下时返回0
//=======================一声提示音,表示有效输入========================
void OneAlam()
ALAM=0;
Delay5Ms();
ALAM=1;
//========================二声提示音,表示操作成功========================
void TwoAlam()
ALAM=0;
Delay5Ms();
ALAM=1;
Delay5Ms();
ALAM=0;
Delay5Ms();
ALAM=1;
//========================三声提示音,表示错误========================
void ThreeAlam()
ALAM=0;
Delay5Ms();
ALAM=1;
Delay5Ms();
ALAM=0;
Delay5Ms();
ALAM=1;
Delay5Ms();
ALAM=0;
Delay5Ms();
ALAM=1;
//=======================显示提示输入=========================
void DisplayChar()
unsigned char i;
if(pass==1)
//DisplayListChar(0,1,LockOpen);
write_1602com(er);
for(i=0;i<16;i++)
write_1602dat(LockOpen);
else
if(N==0)
//DisplayListChar(0,1,Error);
write_1602com(er);
for(i=0;i<16;i++)
write_1602dat(Error);
else
//DisplayListChar(0,1,start_line);
write_1602com(er);
for(i=0;i<16;i++)
write_1602dat(start_line);
//========================重置密码==================================================
void ResetPassword()
unsigned char i;
unsigned char j;
if(pass==0)
pass=0;
DisplayChar();
ThreeAlam();
else
if(ReInputEn==1)
if(N==6)
ReInputCont++;
if(ReInputCont==2)
for(i=0;i<6;)
if(TempPassword==InputData) //将两次输入的新密码作对比
i++;
else
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(Error[j]);
ThreeAlam(); //错误提示
pass=0;
ReInputEn=0; //关闭重置功能,
ReInputCont=0;
DisplayChar();
break;
if(i==6)
//DisplayListChar(0,1,ResetOK);
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(ResetOK[j]);
TwoAlam(); //操作成功提示
WrToROM(TempPassword,0,6); //将新密码写入24C02存储
ReInputEn=0;
ReInputCont=0;
CorrectCont=0;
else
OneAlam();
//DisplayListChar(0, 1, again); //显示再次输入一次
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(again[j]);
for(i=0;i<6;i++)
TempPassword=InputData; //将第一次输入的数据暂存起来
N=0; //输入数据位数计数器清零
//=======================输入密码错误超过三过,报警并锁死键盘======================
void Alam_KeyUnable()
P1=0x00;
ALAM=~ALAM;
Delay5Ms();
//=======================取消所有操作============================================
void Cancel()
unsigned char i;
unsigned char j;
//DisplayListChar(0, 1, start_line);
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(start_line[j]);
TwoAlam(); //提示音
for(i=0;i<6;i++)
InputData=0;
KEY=1; //关闭锁
ALAM=1; //报警关
pass=0; //密码正确标志清零
ReInputEn=0; //重置输入充许标志清零
// ErrorCont=0; //密码错误输入次数清零
CorrectCont=0; //密码正确输入次数清零
ReInputCont=0; //重置密码输入次数清零
s3_keydown=0;
key_disable=0;
N=0; //输入位数计数器清零
//==========================确认键,并通过相应标志位执行相应功能===============================
void Ensure()
unsigned char i,j;
RdFromROM(CurrentPassword,0,6); //从24C02里读出存储密码
if(N==6)
if(ReInputEn==0) //重置密码功能未开启
for(i=0;i<6;)
if(CurrentPassword==InputData)
i++;
else
i=7;
ErrorCont++;
if(ErrorCont>=3&&KEY==1) //错误输入计数达三次时,报警并锁定键盘
write_1602com(er);
for(i=0;i<16;i++)
Alam_KeyUnable();
TR0=1; //开启定时
key_disable=1; //锁定键盘
pass=0;
break;
if(i==6)
if((InputData[0]==1)&&(InputData[1]==3)&&(InputData[2]==1)&&(InputData[3]==4)&&(InputData[4]==2)&&(InputData[5]==0))
WrToROM(initpassword,0,6); //强制将初始密码写入24C02存储
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(initword[j]);
TwoAlam();
Delay400Ms();
TwoAlam();
N=0;
else
CorrectCont++;
if(CorrectCont==1) //正确输入计数,当只有一次正确输入时,开锁,
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(LockOpen[j]);
TwoAlam(); //操作成功提示音
ErrorCont=0;
KEY=0; //开锁
pass=1; //置正确标志位
TR0=1; //开启定时
for(j=0;j<6;j++) //将输入清除
InputData=0;
else //当两次正确输入时,开启重置密码功能
//DisplayListChar(0,1,SetNew);
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(SetNew[j]);
TwoAlam(); //操作成功提示
ReInputEn=1; //允许重置密码输入
CorrectCont=0; //正确计数器清零
else //=========================当第一次使用或忘记密码时可以用131420对其密码初始化============
write_1602com(er);
for(j=0;j<16;j++)
TwoAlam();
Delay400Ms();
TwoAlam();
N=0;
else
write_1602com(er);
for(j=0;j<16;j++)
ThreeAlam(); //错误提示音
pass=0;
else //当已经开启重置密码功能时,而按下开锁键,
//DisplayListChar(0,1,Er_try);
write_1602com(er);
for(j=0;j<16;j++)
write_1602dat(Er_try[j]);
ThreeAlam();
else
write_1602com(er);
for(j=0;j<16;j++)
pass=0;
N=0; //将输入数据计数器清零,为下一次输入作准备
//==============================主函数===============================
void main()
unsigned char KEY,NUM;
unsigned char i,j;
P1=0xFF;
EA=1;
TMOD=0x11;
IT1=1;//下降沿有效
EX1=1;//外部中断1开
TH0=0;//T0赋初值
TL0=0;
TR0=0;//t0开始计时
TL1=0xB0;
TH1=0x3C;
ET1=1;
TR1=0;
Delay400Ms(); //启动等待,等LCM讲入工作状态
lcd_init(); //LCD初始化
write_1602com(yi);//日历显示固定符号从第一行第0个位置之后开始显示
for(i=0;i<16;i++)
write_1602dat(name);//向液晶屏写日历显示的固定符号部分
write_1602com(er);//时间显示固定符号写入位置,从第2个位置后开始显示
for(i=0;i<16;i++)
write_1602dat(start_line);//写显示时间固定符号,两个冒号
write_1602com(er+9); //设置光标位置
write_1602com(0x0f); //设置光标为闪烁
Delay5Ms(); //延时片刻(可不要)
N=0; //初始化数据输入位数
while(1)
if(key_disable==1)
Alam_KeyUnable();
else
ALAM=1; //关报警
KEY=keynum();
if(KEY!=0||IrOK==1)
if(key_disable==1)
second=0;
else
NUM=coding(Im[2],KEY);
switch(NUM)
case ('A'): ; break;
case ('B'): ; break;
case ('C'):
for(i=0;i<16;i++)
write_1602dat(name);//向液晶屏写开机画面
if(N>=1) N--; OneAlam(); //按键提示音
for(j=N;j<16;j++)
write_1602com(er+6+j);
write_1602dat(' ');
for(j=0;j<N;j++)
write_1602com(er+6+j); //显示位数随输入增加而增加
write_1602dat('*'); //但不显示实际数字,用*代替
InputData[N]=N+4;
break;
case ('D'): ResetPassword(); break; //重新设置密码
case ('*'): Cancel(); break; //取消当前输入
case ('#'): Ensure(); break; //确认键,
default:
if(N<6) //当输入的密码少于6位时,接受输入并保存,大于6位时则无效。
write_1602com(er);
for(i=0;i<16;i++)
write_1602dat(Input);
OneAlam(); //按键提示音
//DisplayOneChar(6+N,1,'*');
for(j=0;j<=N;j++)
write_1602dat('*');
InputData[N]=NUM;
N++;
else //输入数据位数大于6后,忽略输入
N=6;
break;
//*********************************中断服务函数**************************************
void time1_int() interrupt 3
TL1=0xB0;
TH1=0x3C;
countt0++;
if(countt0==20)
countt0=0;
second++;
if(pass==1)
if(second==1)
TR1=0; //关定时器
TL1=0xB0;
TH1=0x3C;
second=0;
else
if(second==3)
TR1=0;
second=0;
key_disable=0;
s3_keydown=0;
TL1=0xB0;
TH1=0x3C;
else
TR1=1;
//外部中断解码程序_外部中断0
void intersvr1() interrupt 2 using 1
TR0=1;
Tc=TH0*256+TL0;//提取中断时间间隔时长
TH0=0;
TL0=0; //定时中断重新置零
if((Tc>Imin)&&(Tc<Imax))
m=0;
f=1;
return;
} //找到启始码
if(f==1)
if(Tc>Inum1&&Tc<Inum3)
Im[m/8]=Im[m/8]>>1|0x80; m++;
if(Tc>Inum2&&Tc<Inum1)
Im[m/8]=Im[m/8]>>1; m++; //取码
if(m==32)
m=0;
f=0;
if(Im[2]==~Im[3])
IrOK=1;
TR0=0;
else IrOK=0; //取码完成后判断读码是否正确
} //准备读下一码
