3070|6
53
【先楫HPM6750测评】测试CAN收发 [复制链接]
        HPM6750有4个CAN控制器,支持CANFD,目前在工业上用的还是CAN2.0比较多,本次测评使用CAN1控制器。CAN驱动芯片使用TI的VD230,电脑端使用了一个USB转CAN调试器,带有调试上位机软件。
连线如下:
1.初始化CAN引脚和时钟
        HPM_IOC->PAD[IOC_PAD_PE31].FUNC_CTL = IOC_PE31_FUNC_CTL_CAN1_TXD;
        HPM_IOC->PAD[IOC_PAD_PE30].FUNC_CTL = IOC_PE30_FUNC_CTL_CAN1_RXD;
        /* Set the CAN1 peripheral clock to 80MHz */
        clock_set_source_divider(clock_can1, clk_src_pll1_clk1, 5);
        freq = clock_get_frequency(clock_can1);
2.初始化CAN
        can_config_t can_config;
        can_get_default_config(&can_config);
        can_config.baudrate = 500000; /* 500kbps */
        can_config.mode = can_mode_normal;
        board_init_can(HPM_CAN1);
        uint32_t can_src_clk_freq = board_init_can_clock(BOARD_APP_CAN_BASE);
        hpm_stat_t status = can_init(HPM_CAN1, &can_config, can_src_clk_freq);
        if (status != status_success) {
            printf("CAN initialization failed, error code: %d\n", status);
            return;
3.设置CAN中断
        can_enable_tx_rx_irq(HPM_CAN1, CAN_EVENT_RECEIVE);
        intc_m_enable_irq_with_priority(IRQn_CAN1, 1);
4.CAN中断
SDK_DECLARE_EXT_ISR_M(IRQn_CAN1, test_can1_isr);
void test_can1_isr(void)
    uint8_t flags = can_get_tx_rx_flags(HPM_CAN1);
    if ((flags & CAN_EVENT_RECEIVE) != 0) {
        can_read_received_message(HPM_CAN1, (can_receive_buf_t *)&s_can_rx_buf);
        has_new_rcv_msg = true;
    if ((flags & (CAN_EVENT_TX_PRIMARY_BUF | CAN_EVENT_TX_SECONDARY_BUF))) {
        has_sent_out = true;
    if ((flags & CAN_EVENT_ERROR) != 0) {
        has_error = true;
    can_clear_tx_rx_flags(HPM_CAN1, flags);
    error_flags = can_get_error_interrupt_flags(HPM_CAN1);
    can_clear_error_interrupt_flags(HPM_CAN1, error_flags);
5.CAN发送接收到的数据
    while (!has_new_rcv_msg) {
    has_new_rcv_msg = false;
    show_received_can_message((const can_receive_buf_t *)&s_can_rx_buf);
    can_transmit_buf_t tx_buf;
    memset(&tx_buf, 0, sizeof(tx_buf));
    tx_buf.dlc = s_can_rx_buf.dlc;
    tx_buf.id = 0x321;
    uint32_t msg_len = can_get_data_bytes_from_dlc(s_can_rx_buf.dlc);
    memcpy(&tx_buf.data, (uint8_t *)&s_can_rx_buf.data, msg_len);
    status = can_send_message_blocking(BOARD_APP_CAN_BASE, &tx_buf);
        printf("CAN sent message failed, error_code:%d\n", status);
        return;
6.测试程序,设置CAN调试器为CA2.0,波特率500k,标准模式,依次发送数据,接收均正常。
错误帧率呢?也就是给出来的时钟精确度?   详情 回复 发表于 2022-8-10 19:08
7215
用CAN调式器测试可以通过,可以试试跟其他的开发板测评一下,这样更有说明力。
我的CAN调试器就是用的STM32F103的CAN控制器,PHY用的是TJA1040  详情 回复 发表于 2022-8-9 21:49
161
CAN应用场景都有哪些?目前只用过串口,SPI,IIC等常用接口
    CAN相对于串口最大的优势在自动仲裁,方便做多主站。串口做多主站通常需要令牌环  详情 回复 发表于 2022-8-9 21:51
CAN在汽车电子方面用得比较多,相比串口、SPI、IIC的传输无论是距离、抗干扰等都相对较强。  详情 回复 发表于 2022-8-9 11:51
7215
qzc飘曳 发表于 2022-8-9 11:00 CAN应用场景都有哪些?目前只用过串口,SPI,IIC等常用接口
53
lugl4313820 发表于 2022-8-8 23:31 用CAN调式器测试可以通过,可以试试跟其他的开发板测评一下,这样更有说明力。
53
7794
错误帧率呢?也就是给出来的时钟精确度?
默认摸鱼,再摸鱼。2022、9、28
站长推荐上一条 2/10 下一条
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
