[国民技术N32WB452测评] 二、PWM输出代码分析及呼吸灯实现
国民技术N32WB452提供了很多的示例程序,其中涉及PWM输出的在TIM目录下,为定时器的案例之一。
1、PWM Output示例
示例程序路径
示例代码的目录有个readme文件,说明了其功能
收头没有示波器就没办法得到波形了
2、代码分析
具体的实现代码比较简单
首先是时钟RCC的开启及其使能
- void RCC_Configuration(void)
- RCC_EnableAPB1PeriphClk(RCC_APB1_PERIPH_TIM3, ENABLE);
- RCC_EnableAPB2PeriphClk(
- RCC_APB2_PERIPH_GPIOA | RCC_APB2_PERIPH_GPIOB | RCC_APB2_PERIPH_GPIOC | RCC_APB2_PERIPH_AFIO, ENABLE);
接下来是GPIO的设置
由于TIM3的通道CH1-CH4分别对应PA6、PA7、PB0和PB1,GPIO也只针对这4各管脚进行
- void GPIO_Configuration(void)
- GPIO_InitType GPIO_InitStructure;
- GPIO_InitStructure.Pin = GPIO_PIN_6 | GPIO_PIN_7;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitPeripheral(GPIOA, &GPIO_InitStructure);
- GPIO_InitStructure.Pin = GPIO_PIN_0 | GPIO_PIN_1;
- GPIO_InitPeripheral(GPIOB, &GPIO_InitStructure);
下面是定时器及其通道的设置,代码里做了比较详细的说明
- TIM3 Configuration: generate 4 PWM signals with 4 different duty cycles:
- The TIM3CLK frequency is set to SystemCoreClock (Hz), to get TIM3 counter
- clock at 24 MHz the Prescaler is computed as following:
- - Prescaler = (TIM3CLK / TIM3 counter clock) - 1
- SystemCoreClock is set to 72 MHz for Low-density, Medium-density, High-density
- and Connectivity line devices and to 24 MHz for Low-Density Value line and
- Medium-Density Value line devices
- The TIM3 is running at 36 KHz: TIM3 Frequency = TIM3 counter clock/(AR + 1)
- = 24 MHz / 666 = 36 KHz
- TIM3 Channel1 duty cycle = (TIM3_CCR1/ TIM3_ARR)* 100 = 50%
- TIM3 Channel2 duty cycle = (TIM3_CCR2/ TIM3_ARR)* 100 = 37.5%
- TIM3 Channel3 duty cycle = (TIM3_CCR3/ TIM3_ARR)* 100 = 25%
- TIM3 Channel4 duty cycle = (TIM3_CCR4/ TIM3_ARR)* 100 = 12.5%
- /* Compute the prescaler value */
- PrescalerValue = (uint16_t)(SystemCoreClock / 24000000) - 1;
- /* Time base configuration */
- TIM_TimeBaseStructure.Period = 665;
- TIM_TimeBaseStructure.Prescaler = PrescalerValue;
- TIM_TimeBaseStructure.ClkDiv = 0;
- TIM_TimeBaseStructure.CntMode = TIM_CNT_MODE_UP;
- TIM_InitTimeBase(TIM3, &TIM_TimeBaseStructure);
- /* PWM1 Mode configuration: Channel1 */
- TIM_OCInitStructure.OcMode = TIM_OCMODE_PWM1;
- TIM_OCInitStructure.OutputState = TIM_OUTPUT_STATE_ENABLE;
- TIM_OCInitStructure.Pulse = CCR1_Val;
- TIM_OCInitStructure.OcPolarity = TIM_OC_POLARITY_HIGH;
- TIM_InitOc1(TIM3, &TIM_OCInitStructure);
- TIM_ConfigOc1Preload(TIM3, TIM_OC_PRE_LOAD_ENABLE);
- /* PWM1 Mode configuration: Channel2 */
- TIM_OCInitStructure.Pulse = CCR2_Val;
- TIM_InitOc2(TIM3, &TIM_OCInitStructure);
- TIM_ConfigOc2Preload(TIM3, TIM_OC_PRE_LOAD_ENABLE);
- /* PWM1 Mode configuration: Channel3 */
- TIM_OCInitStructure.Pulse = CCR3_Val;
- TIM_InitOc3(TIM3, &TIM_OCInitStructure);
- TIM_ConfigOc3Preload(TIM3, TIM_OC_PRE_LOAD_ENABLE);
- /* PWM1 Mode configuration: Channel4 */
- TIM_OCInitStructure.Pulse = CCR4_Val;
- TIM_InitOc4(TIM3, &TIM_OCInitStructure);
- TIM_ConfigOc4Preload(TIM3, TIM_OC_PRE_LOAD_ENABLE);
- TIM_ConfigArPreload(TIM3, ENABLE);
- /* TIM3 enable counter */
- TIM_Enable(TIM3, ENABLE);
通用定时器TIM3以24MHz的工作进行计数,其中计数周期设置为666,PWM的4个通道分别为这个计数周期的50%、37.5%、25%以及12.5%;
- uint16_t CCR1_Val = 333;
- uint16_t CCR2_Val = 249;
- uint16_t CCR3_Val = 166;
- uint16_t CCR4_Val = 83;
设置完成后就由定时器TIM3硬件输出PWM信号了
3、呼吸灯实现
在这个demo案例中,稍微加点变化,就能实现呼吸灯效果了
定义了两个变量,一个为递增及递减的方向u8 dir,一个为记录输出比较器的参考值u16 led0pwmval=0;
在main主循环中增加以下代码
- while (1)
- if(dir)led0pwmval++;
- else led0pwmval--;
- if(led0pwmval>660)dir=0;
- if(led0pwmval==0)dir=1;
- TIM3->CCDAT4 = led0pwmval;
- Delay(0x01FFFF);
用通道4实现呼吸灯的效果
播放器加载失败: 未检测到Flash Player,请到 安装
PWM呼吸灯
Keil的开发环境相对比较熟悉,整起来还是蛮快的。
