#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#define PACKET_SIZE 4096
#define MAX_WAIT_TIME 5
#define MAX_NO_PACKETS 3
char sendpacket[PACKET_SIZE];
char recvpacket[PACKET_SIZE];
int sockfd,datalen=56;
int nsend=0,nreceived=0;
struct sockaddr_in dest_addr;
pid_t pid;
struct sockaddr_in from;
struct timeval tvrecv;
void statistics(int signo);
unsigned short cal_chksum(unsigned short *addr,int len);
int pack(int pack_no);
void send_packet(void);
void recv_packet(void);
int unpack(char *buf,int len);
void tv_sub(struct timeval *out,struct timeval *in);
printf("\n--------------------PING statistics-------------------\n");
printf("%d packets transmitted, %d received , %%%d lost\n",nsend,nreceived,(nsend-nreceived)/nsend*100);
close(sockfd);
exit(1);
/*校验和算法*/
int nleft=len;
int sum=0;
unsigned short *w=addr;
unsigned short answer=0;
/*把ICMP报头二进制数据以2字节为单位累加起来*/
while(nleft>1)
sum+=*w++;
nleft-=2;
/*若ICMP报头为奇数个字节,会剩下最后一字节。把最后一个字节视为一个2字节数据的高字节,
这个2字节数据的低字节为0,继续累加*/
if( nleft==1)
*(unsigned char *)(&answer)=*(unsigned char *)w;
sum+=answer;
sum=(sum>>16)+(sum&0xffff);
sum+=(sum>>16);
answer=~sum;
return answer;
/*设置ICMP报头*/
int i,packsize;
struct icmp *icmp;
struct timeval *tval;
icmp=(struct icmp*)sendpacket;
icmp->icmp_type=ICMP_ECHO;
icmp->icmp_code=0;
icmp->icmp_cksum=0;
icmp->icmp_seq=pack_no;
icmp->icmp_id=pid;
packsize=8+datalen;
tval= (struct timeval *)icmp->icmp_data;
gettimeofday(tval,NULL); /*记录发送时间*/
icmp->icmp_cksum=cal_chksum( (unsigned short *)icmp,packsize); /*校验算法*/
return packsize;
/*发送三个ICMP报文*/
void send_packet()
int packetsize;
while(nsend)
nsend++;
packetsize=pack(nsend); /*设置ICMP报头*/
if(sendto(sockfd,sendpacket,packetsize,0,(struct sockaddr *)&dest_addr,sizeof(dest_addr))<0 )
perror("sendto error");
continue;
sleep(1); /*每隔一秒发送一个ICMP报文*/
/*接收所有ICMP报文*/
void recv_packet()
int n,fromlen;
extern int errno;
signal(SIGALRM,statistics);
fromlen=sizeof(from);
while(nreceived)
alarm(MAX_WAIT_TIME);
if( (n=recvfrom(sockfd,recvpacket,sizeof(recvpacket),0,(struct sockaddr *)&from,&fromlen)) <0)
if(errno==EINTR) continue;
perror("recvfrom error");
continue;
gettimeofday(&tvrecv,NULL); /*记录接收时间*/
if(unpack(recvpacket,n)==-1) continue;
nreceived++;
/*剥去ICMP报头*/
int i,iphdrlen;
struct ip *ip;
struct icmp *icmp;
struct timeval *tvsend;
double rtt;
ip=(struct ip *)buf;
iphdrlen=ip->ip_hl<<2; /*求ip报头长度,即ip报头的长度标志乘4*/
icmp=(struct icmp *)(buf+iphdrlen); /*越过ip报头,指向ICMP报头*/
len-=iphdrlen; /*ICMP报头及ICMP数据报的总长度*/
if(len<8) /*小于ICMP报头长度则不合理*/
printf("ICMP packets\'s length is less than 8\n");
return -1;
/*确保所接收的是我所发的的ICMP的回应*/
if( (icmp->icmp_type==ICMP_ECHOREPLY) && (icmp->icmp_id==pid) )
tvsend=(struct timeval *)icmp->icmp_data;
tv_sub(&tvrecv,tvsend); /*接收和发送的时间差*/
rtt=tvrecv.tv_sec*1000+tvrecv.tv_usec/1000; /*以毫秒为单位计算rtt*/
/*显示相关信息*/
printf("%d byte from %s: icmp_seq=%u ttl=%d rtt=%.3f ms\n",
len,inet_ntoa(from.sin_addr),icmp->icmp_seq,ip->ip_ttl,rtt);
else return -1;
int main(int argc,char *argv[])
struct hostent *host;
struct protoent *protocol;
unsigned long inaddr=0l;
int waittime=MAX_WAIT_TIME;
int size=50*1024;
if(argc<2)
printf("usage:%s hostname/IP address\n",argv[0]);
exit(1);
if( (protocol=getprotobyname("icmp") )==NULL)
perror("getprotobyname");
exit(1);
/*生成使用ICMP的原始套接字,这种套接字只有root才能生成*/
if( (sockfd=socket(AF_INET,SOCK_RAW,protocol->p_proto) )<0)
perror("socket error");
exit(1);
/* 回收root权限,设置当前用户权限*/
setuid(getuid());
/*扩大套接字接收缓冲区到50K这样做主要为了减小接收缓冲区溢出的
的可能性,若无意中ping一个广播地址或多播地址,将会引来大量应答*/
setsockopt(sockfd,SOL_SOCKET,SO_RCVBUF,&size,sizeof(size) );
bzero(&dest_addr,sizeof(dest_addr));
dest_addr.sin_family=AF_INET;
/*判断是主机名还是ip地址*/
if( inaddr=inet_addr(argv[1])==INADDR_NONE)
if((host=gethostbyname(argv[1]) )==NULL) /*是主机名*/
perror("gethostbyname error");
exit(1);
memcpy( (char *)&dest_addr.sin_addr,host->h_addr,host->h_length);
else /*是ip地址*/
memcpy( (char *)&dest_addr,(char *)&inaddr,host->h_length);
/*获取main的进程id,用于设置ICMP的标志符*/
pid=getpid();
printf("PING %s(%s): %d bytes data in ICMP packets.\n",argv[1],
inet_ntoa(dest_addr.sin_addr),datalen);
send_packet(); /*发送所有ICMP报文*/
recv_packet(); /*接收所有ICMP报文*/
statistics(SIGALRM); /*进行统计*/
return 0;
/*两个timeval结构相减*/
if( (out->tv_usec-=in->tv_usec)<0)
--out->tv_sec;
out->tv_usec+=1000000;
out->tv_sec-=in->tv_sec;
/*------------- The End -----------*/
请问错在?
