2070|2
565
【N32L43x评测】3、利用串口接收中断和空闲中断,实现不定长数据接收 [复制链接]
1、实现思路
本文利用串口接收中断和空闲中断,实现串口不定长数据接收
接收中断:实现数据的接收;
空闲中断:判断一帧数据完成。
2、硬件
本文使用串口1,引脚为PA9和PA10,同时,PA9和PA10直接连接到了NS-LINK的usb转串口上,因此可以直接在电脑上查看。
3、代码实现
(1)串口初始化
void SerialInit(void)
	 /* Enable GPIO clock */
    RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOA , ENABLE);
    /* Enable USARTy and USARTz Clock */
    RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_USART1, ENABLE);
	NVIC_InitType NVIC_InitStructure;
    /* Enable the USART Interrupt */
    NVIC_InitStructure.NVIC_IRQChannel            = USART1_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelCmd         = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
	GPIO_InitType GPIO_InitStructure;
    /* Initialize GPIO_InitStructure */
    GPIO_InitStruct(&GPIO_InitStructure);
    /* Configure USARTx Tx as alternate function push-pull */
    GPIO_InitStructure.Pin            = GPIO_PIN_9;
    GPIO_InitStructure.GPIO_Mode      = GPIO_Mode_AF_PP;
    GPIO_InitStructure.GPIO_Alternate = GPIO_AF4_USART1;  //GPIO_Mode_AF_PP
    GPIO_InitPeripheral(GPIOA, &GPIO_InitStructure);
    /* Configure USARTx Rx as alternate function push-pull and pull-up */
    GPIO_InitStructure.Pin            = GPIO_PIN_10;
    GPIO_InitStructure.GPIO_Pull      = GPIO_Pull_Up;
	USART_InitType USART_InitStructure;
	USART_StructInit(&USART_InitStructure);
    USART_InitStructure.BaudRate            = 115200;
    USART_InitStructure.WordLength          = USART_WL_8B;
    USART_InitStructure.StopBits            = USART_STPB_1;
    USART_InitStructure.Parity              = USART_PE_NO;
    USART_InitStructure.HardwareFlowControl = USART_HFCTRL_NONE;
    USART_InitStructure.Mode                = USART_MODE_RX | USART_MODE_TX;
    /* Configure USART*/
    USART_Init(USART1, &USART_InitStructure);
	 /* Enable USARTy Receive and Transmit interrupts */
    USART_ConfigInt(USART1, USART_INT_RXDNE, ENABLE);
	USART_ConfigInt(USART1, USART_INT_IDLEF, ENABLE);
    USART_Enable(USART1, ENABLE);
(2)串口中断
void USART1_IRQHandler(void)
    if(RESET != USART_GetIntStatus(USART1, USART_INT_RXDNE))
       SerialRecv(USART_ReceiveData(USART1));
	if(RESET !=USART_GetIntStatus(USART1, USART_INT_IDLEF))
		USART_ReceiveData(USART1);
		SerialStr.Idle=1;
(3)接收应用代码
void SerialRecv(uint8_t data)
	if(SerialStr.RecvLen<UART_MAX_LEN)
		SerialStr.RecvBuff[SerialStr.RecvLen++]=data;
void SerialSend(uint8_t *data,uint8_t len)
	for(uint8_t i=0; i<len;i++)
		while (RESET == USART_GetFlagStatus(USART1, USART_FLAG_TXDE ));
		USART_SendData(USART1, data[i]);
void SerialPro(void)
	if(SerialStr.Idle&&SerialStr.RecvLen)
		printf("Recv:%d,[",SerialStr.RecvLen);
		SerialSend(SerialStr.RecvBuff,SerialStr.RecvLen);
		printf("]\r\n");
		SerialStr.RecvLen=0;
		SerialStr.Idle=0;
int fputc(int ch, FILE *f)
	while (RESET == USART_GetFlagStatus(USART1, USART_FLAG_TXDE )) {};
	USART_SendData(USART1, (uint8_t) ch);
    return ch;
4、测试
有些单片机没有空闲中断就很恶心。   详情 回复 发表于 2022-9-28 20:06
个人签名stm32/LoRa物联网:304350312
您好,请问有源代码吗?
7504
有些单片机没有空闲中断就很恶心。
默认摸鱼,再摸鱼。2022、9、28
