1898|3
565
【N32L43x评测】2、点灯,blink,blink,blink…… [复制链接]
1、前言:
官方的demo用的阻塞方式点灯,即就是死等,在等待期间mcu干不了其他事情(中断除外),这种方式不太友好,本文使用非阻塞方式点灯。
2、硬件连接
3、思路
利用定时器中断,每1ms中断一次,整个系统维护一个tick计数;
记录某一时刻的tick,用A表示,再获取当前的tick,用B表示,如果当前的B-A大于等于500(这里500ms闪烁一次),那么就执行一次led翻转,同时也更新A的值。
4、软件实现
(1)利用定时器中断,每1ms中断一次,整个系统维护一个tick计数
static uint32_t SystemTick=0;
void TimerConfig(void)
	NVIC_InitType NVIC_InitStructure;
	TIM_TimeBaseInitType TIM_TimeBaseStructure;
	RCC_EnableAPB1PeriphClk(RCC_APB1_PERIPH_TIM2, ENABLE);
    /* Enable the TIM2 global Interrupt */
    NVIC_InitStructure.NVIC_IRQChannel                   = TIM2_IRQn;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority        = 1;
    NVIC_InitStructure.NVIC_IRQChannelCmd                = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
	//TIMER2CLK = SystemCoreClock/(107+1) = 1MHz, the period is 1s((999+1)/1000000 = 0.001s=1ms).
    /* Time base configuration */
    TIM_TimeBaseStructure.Period    = 107;
    TIM_TimeBaseStructure.Prescaler = 999;
    TIM_TimeBaseStructure.ClkDiv    = TIM_CLK_DIV1;
    TIM_TimeBaseStructure.CntMode   = TIM_CNT_MODE_UP;
    TIM_InitTimeBase(TIM2, &TIM_TimeBaseStructure);
	/* TIM IT enable */
    TIM_ConfigInt(TIM2, TIM_INT_UPDATE , ENABLE);
    /* TIM2 enable counter */
    TIM_Enable(TIM2, ENABLE);
void TIM2_IRQHandler(void)
    if (TIM_GetIntStatus(TIM2, TIM_INT_UPDATE) != RESET)
        TIM_ClrIntPendingBit(TIM2, TIM_INT_UPDATE);
		SystemTick++;
uint32_t SystemGetTick(void)
	return SystemTick;
(2)LED翻转
    GPIO_InitType GPIO_InitStructure;
	RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOA, ENABLE);
	RCC_EnableAPB2PeriphClk(RCC_APB2_PERIPH_GPIOB, ENABLE);
	GPIO_InitStruct(&GPIO_InitStructure);
    GPIO_InitStructure.Pin        = GPIO_PIN_8;
    GPIO_InitStructure.GPIO_Current = GPIO_DC_12mA;
    GPIO_InitStructure.GPIO_Pull    = GPIO_No_Pull;
    GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_Out_PP;
    GPIO_InitPeripheral(GPIOA, &GPIO_InitStructure);
	GPIO_InitStructure.Pin        = GPIO_PIN_4|GPIO_PIN_5;
    GPIO_InitPeripheral(GPIOB, &GPIO_InitStructure);
void SystemRun(void)
	static uint32_t curtick=0;
	static uint8_t state=0;
	if(SystemGetTick()-curtick>=500)
		if(state)
			GPIO_SetBits(GPIOA, GPIO_PIN_8);
			GPIO_SetBits(GPIOB, GPIO_PIN_4|GPIO_PIN_5);
		else
			GPIO_ResetBits(GPIOA, GPIO_PIN_8);
			GPIO_ResetBits(GPIOB, GPIO_PIN_4|GPIO_PIN_5);
		curtick=SystemGetTick();
		state=!state;
5、现象
led blink
三色灯为啥不直接用三色灯,,,   详情 回复 发表于 2022-7-5 17:37
个人签名stm32/LoRa物联网:304350312
7062
很精彩的作品哦,大家可以学习定时器,来做做状态转换!
7671
三色灯为啥不直接用三色灯,,,
这就要问官方设计人员了  详情 回复 发表于 2022-7-5 19:21
默认摸鱼,再摸鱼。2022、9、28
565
freebsder 发表于 2022-7-5 17:37 三色灯为啥不直接用三色灯,,,
这就要问官方设计人员了
