4355|6
wince 清空键盘缓冲区 [复制链接]
如题.
如何清空wince系统的键盘缓冲区.
我想要的结果是,在一个操作进行的时候,如果操作员按下了别的按键,等这个操作进行完成以后,将用户按下的那些键清除,不作响应.
public static void FilterMassage(IntPtr from)         {             NativeMethods.Message ms = new NativeMethods.Message();             uint index = 0;             while (true)             {                 //while (NativeMethods.PeekMessage(out ms, this.Handle, 0, 0, 1)) ;                 bool ret = NativeMethods.PeekMessage(out ms, from, index, index, 1);                 if (!ret)                 {                     break;                 }                 else                 {                     if (ms.msg == 15)                     {                         index++;                     }                 }             }         }     }       public class NativeMethods         {             /**/             /// Windows Message             [StructLayout(LayoutKind.Sequential)]             public struct Message             {                 public IntPtr hWnd;                 public uint msg;                 public IntPtr wParam;                 public IntPtr lParam;                                public uint time;                 public System.Drawing.Point p;             }             [DllImport("coredll.dll", CharSet = CharSet.Auto)]             public static extern bool PeekMessage(out Message msg, IntPtr hWnd, uint messageFilterMin, uint messageFilterMax, uint flags);             [DllImport("coredll.dll", CharSet = CharSet.Auto)]             public static extern bool GetMessage(out Message msg, IntPtr hWnd, uint messageFilterMin, uint messageFilterMax);       } 复制代码 最后的方法是调用了windows API,将所有的操作完成之前的Enter从按键序列中删除  详情 回复 发表于 2009-10-6 17:01
77
帮顶
55
up
62
没有什么好办法
可以考虑在操作过程中,将屏幕disable掉
84
不作响应,enablewindiow()--->false
HotKey 钩子
  1. public static void FilterMassage(IntPtr from)
  2.         {
  3.             NativeMethods.Message ms = new NativeMethods.Message();
  4.             uint index = 0;
  5.             while (true)
  6.             {
  7.                 //while (NativeMethods.PeekMessage(out ms, this.Handle, 0, 0, 1)) ;
  8.                 bool ret = NativeMethods.PeekMessage(out ms, from, index, index, 1);
  9.                 if (!ret)
  10.                 {
  11.                     break;
  12.                 }
  13.                 else
  14.                 {
  15.                     if (ms.msg == 15)
  16.                     {
  17.                         index++;
  18.                     }
  19.                 }
  20.             }
  21.         }
  22.     }
  23.       public class NativeMethods
  24.         {
  25.             /**/
  26.             /// Windows Message
  27.             [StructLayout(LayoutKind.Sequential)]
  28.             public struct Message
  29.             {
  30.                 public IntPtr hWnd;
  31.                 public uint msg;
  32.                 public IntPtr wParam;
  33.                 public IntPtr lParam;
  34.                 public uint time;
  35.                 public System.Drawing.Point p;
  36.             }
  37.             [DllImport("coredll.dll", CharSet = CharSet.Auto)]
  38.             public static extern bool PeekMessage(out Message msg, IntPtr hWnd, uint messageFilterMin, uint messageFilterMax, uint flags);
  39.             [DllImport("coredll.dll", CharSet = CharSet.Auto)]
  40.             public static extern bool GetMessage(out Message msg, IntPtr hWnd, uint messageFilterMin, uint messageFilterMax);
  41.       }
复制代码
【回帖赢京东卡】说说无线技术那些事儿
即日起—2月28日,参与回帖讨论都有机会赢取【30元京东卡】
