1899|0
7211
【国产RISC-V Linux板 昉·星光VisionFive试用报告】创建用户数据插入 [复制链接]
tornado创建模型用于数据库的插入,今天设计被采样人数据插入,设计models下面的model.py
  • from peewee import *
  • import peewee_async
  • database = peewee_async.MySQLDatabase(
  • host='localhost',
  • port=3306,
  • user='user',
  • password='pypasswd',
  • database='test_db',
  • autocommit=False
  • objects = peewee_async.Manager(database)
  • database.set_allow_sync(True)
  • class BaseModel(Model):
  • class Meta:
  • database = database
  • class personnel_information(BaseModel):
  • name = CharField(max_length=10, verbose_name="姓名", index=True)
  • ID_card = CharField(max_length=20, verbose_name="身份证号")
  • phone = CharField(max_length=15, verbose_name="手机号码")
  • uint = CharField(max_length=45, verbose_name="单位名称")
  • class specimen_information(BaseModel):
  • tube_Id = CharField(max_length=10, verbose_name="试管号", index=True)
  • name = CharField(max_length=10, verbose_name="姓名")
  • phone = CharField(max_length=15, verbose_name="手机号")
  • acquisition_time = DateTimeField(verbose_name="采样时间")
  • Collector = CharField(max_length=10, verbose_name="采样人姓名")
  • Collection_unit = CharField(max_length=40, verbose_name="采样单位")
wiews_index.py下面新建class SamplePersnnelHandler
  • class SamplePersnnelHandler(CommonHandler):
  • def check_xsrf_cookie(self):
  • return True
  • async def post(self):
  • res = dict(code=9999, msg='')
  • print(self.request.body)
  • try:
  • """ 分析POST请求参数 接收消息 获取参数"""
  • data_quest = json.loads(self.request.body)
  • if 'command' not in data_quest:
  • res['msg'] = "请救命令参数错误"
  • else:
  • print(data_quest['command'])
  • print(data_quest['name'])
  • if data_quest['command'] == "appendPersonnel":
  • # 插入被采人信息
  • if 'name' not in data_quest:
  • res['msg'] = '姓名不能为空'
  • if 'ID_card' not in data_quest:
  • res['msg'] = res['msg'] + '身份证号码为空'
  • if 'phone' not in data_quest:
  • res['msg'] = res['msg'] + "手机号码为空"
  • if 'uint' not in data_quest:
  • res['msg'] = res['msg'] + "单位为空"
  • if res['msg'] == "":
  • # 开始插入采样人信息
  • print("开始保存数据")
  • query = personnel_information.select().where(personnel_information.name == data_quest['name'])
  • results = await objects.execute(query.dicts())
  • if results:
  • print("用户已存在")
  • res['code'] = 2001
  • res['msg'] = "用户已存在"
  • else:
  • try:
  • ob = await objects.create(
  • personnel_information,
  • name=data_quest['name'],
  • ID_card=data_quest['ID_card'],
  • phone=data_quest['phone'],
  • uint=data_quest['uint']
  • if ob:
  • res['code'] = 1000
  • res['msg'] = "save OK"
  • else:
  • res['msg'] = "save data err"
  • except Exception as e:
  • res['code'] = 2003
  • res['msg'] = "save data ERROR"
  • else:
  • res['msg'] = "command err!"
  • print("错误信息:" + str(e))
  • print(res)
  • self.write(res)
增加路由:
  • from app.api.views_index import IndexHandler as api_index
  • from app.api.views_index import SamplePersnnelHandler as man_index
  • # API接口
  • api_urls = [
  • (r'/', api_index),
  • (r'/man', man_index),
重启服务后用curl模拟POST插入数据:
 然后数据库更新了数据:
 数据插入成功。下面书写数据读取、采样信息的插入。这段时间主要设计数据库的东西多一些,要等服务器建好才能进入昉星光的程序展示,大家耐心等待。
会议时间:3月18日(周二)09:30签到
参会奖励:电动螺丝刀套装、户外登山包、京东卡
