319|0
65
QCN9074 WiFi Card IPQ6010/IPQ6018,802.11ax,2x2 2.4G&5G, Support OpenWRT [复制链接]
DR-AP6018-S-A is a 2x2 2.4G&5G high power Radio AP Router which including 1x  DR6018(IPQ6010) Board;2 x 2.4G&5G dipole Antennas; 1 x PSU(DC power or PoE);
1 x Enclosure.
Dipole antenna
■  2 x 2.4G&5G Antenna
■  5dBi 2.4GHz/5Ghz
■ SMA Plug interface
■ Plastic rod of black
■ RoHS compliance
Enclosure
■  Dimension: 133x 128 x 44 mm
■  Aluminum alloy material
■ Two Version:
DR-AP6018-S-AB (color black)
DR-AP6018-S-AO (color orange)
■  Support Wally DR6018-S
Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, We're a supplier to Facebook. welcome to consult. (Web:wallystech  com)
EMAIL:sales@wallystech.com
WEB:https://www.wallystech.com/
  Absolute Maximum Rating
Rating
Supply Voltage
24V~48V(DC Jack)
Operating Temperature Range
-40 to +70
ºC
Storage Temperature Range
-45 to +105
ºC
Operating Humidity Range
5 to +95 (non-condensing)
   Hardware Specifications
CPU
Qualcomm-Atheros IPQ6010
CPU Frequency
Quad-core ARM 64 bit A53 @1.8 GHz processor
System Memory
1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port
1 x 1Gbps Ethernet Ports & POE 1x 1Gbps Ethernet Ports
NGFF Slot
M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0(For WiFi Module)
SD Card Slot
1x SD Card Slot(Option)
USB /header
1x USB 3.0 Port(Option)
POE
24V~48V passive POE/Active POE(Suport 802.3bt)
DC Jack
24V~48V power supply
LED header
2.0 pitch pin header
Serial Port
1x Serial Port 4 Pin Connector
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
4 x MMCX Connectors
Nor Flash
8MB
Nand Flash
256MB
DDR
256MB~512MB
Dimension
133mm x 128mm x 44mm
Radio TX Specifications(5180MHz-5825MHz)
Operating Mode
Data Rate
Power
Tolerance
1 Chain
2 Chains
5Ghz 802.11ax HE20
MCS0
20dBm
23dbm
±2dB
MCS1
20dBm
23dBm
±2dB
MCS2
20dBm
23dBm
±2dB
MCS3
20dBm
23dBm
±2dB
MCS4
19dBm
22dBm
±2dB
MCS5
18dBm
21dBm
±2dB
MCS6
17dBm
20dBm
±2dB
MCS7
16dBm
19dBm
±2dB
MCS8
15dBm
18dBm
±2dB
MCS9
14dBm
17dBm
±2dB
MCS10
13dBm
16dBm
±2dB
MCS11
13dBm
16dbm
±2dB
5Ghz 802.11ax HE400
MCS0
20dBm
23dbm
±2dB
MCS1
20dBm
23dBm
±2dB
MCS2
20dBm
23dBm
±2dB
MCS3
20dBm
23dBm
±2dB
MCS4
19dBm
22dBm
±2dB
MCS5
18dBm
21dBm
±2dB
MCS6
17dBm
20dBm
±2dB
MCS7
16dBm
19dBm
±2dB
MCS8
15dBm
18dBm
±2dB
MCS9
14dBm
17dBm
±2dB
MCS10
13dBm
16dBm
±2dB
MCS11
13dBm
16dbm
±2dB
5Ghz 802.11ax HE80
MCS0
20dBm
23dbm
±2dB
MCS1
20dBm
23dBm
±2dB
MCS2
20dBm
23dBm
±2dB
MCS3
20dBm
23dBm
±2dB
MCS4
19dBm
22dBm
±2dB
MCS5
18dBm
21dBm
±2dB
MCS6
17dBm
20dBm
±2dB
MCS7
16dBm
19dBm
±2dB
MCS8
15dBm
18dBm
±2dB
MCS9
14dBm
17dBm
±2dB
MCS10
13dBm
16dBm
±2dB
MCS11
13dBm
16dbm
±2dB
   Radio TX Specifications(2412MHz-2482MHz)
Operating Mode
Data Rate
Power
Tolerance
1 Chain
2 Chains
2.4Ghz 802.11ax HE20
MCS0
23dbm
26dbm
±2dB
MCS1
23dBm
26dBm
±2dB
MCS2
23dBm
26dBm
±2dB
MCS3
23dBm
26dBm
±2dB
MCS4
23dBm
26dBm
±2dB
MCS5
23dBm
26dBm
±2dB
MCS6
23dBm
26dBm
±2dB
MCS7
22dBm
25dBm
±2dB
MCS8
21dBm
24dBm
±2dB
MCS9
21dBm
24dBm
±2dB
MCS10
18dBm
21dBm
±2dB
MCS11
17dbm
20dbm
±2dB
2.4Ghz 802.11ax HE40
MCS0
23dbm
26dbm
±2dB
MCS1
23dBm
26dBm
±2dB
MCS2
23dBm
26dBm
±2dB
MCS3
23dBm
26dBm
±2dB
MCS4
23dBm
26dBm
±2dB
MCS5
23dBm
26dBm
±2dB
MCS6
23dBm
26dBm
±2dB
MCS7
22dBm
25dBm
±2dB
MCS8
21dBm
24dBm
±2dB
MCS9
21dBm
24dBm
±2dB
MCS10
21dBm
24dBm
±2dB
MCS11
19dbm
22dbm
±2dB
立即报名 | 2025 瑞萨电子工业以太网技术日即将开启!
预报从速,好礼等您拿~
