2551|1
66
看不懂老外的网页 [复制链接]
我也不知道发到哪个区 既然是因为wince而搜索到就发到wince区吧
今天遇到一个问题'E:\WINCE500\PBWorkspaces\t1_2440a_handheld_default\WINCE500\smdk2440a_ARMV4I\cesysgen\oak\lib\ARMV4I\retail\storeapi.lib'
就搜索了 在老外的网站中发现了
这个网页网址是
http://www.tech-archive.net/Archive/WindowsCE/microsoft.public.windowsce.platbuilder/2008-12/msg00044.html
但是我点他后面的Relevant Pages  却进不了人家的回复
Re: ERRORE] NMAKE : U1073: don't know how to make ...
Date: Tue, 2 Dec 2008 00:40:00 -0800
I am reading your article and think it is helpful.
"Erwin Zwart" <"erwin AT GuruCE DOT COM" wrote:
Hi,
Like CL mentioned perform a sygen and never a "build and sysgen". Take a
look at the following blog post to tell you why:
http://guruce.com/blogpost/whattobuildwhen
After installing CE 5.0 install all QFE's
(http://msdn.microsoft.com/en-us/embedded/aa731256.aspx)
Is the storapi.lib available in the
public\common\oak\lib\<$(_CPUDEPPATH)>\ ?
The clean option will delete these folders and tries to build them
again, so perhaps something went wrong there. I am not aware of any
csp_arm.lib, but suspect that this is something that the OEM added.
Did you also got a workspace from your vendor? Try to build that,
Good luck,
Erwin Zwart,
Check out my blog: http://GuruCE.com/blog
GuruCE
Microsoft Embedded Partner
http://GuruCE.com
Consultancy, training and development services.
Raj schreef:
On Dec 1, 4:16 pm, ping wrote:
I have done the following:
1, install platform builder 5.0, copy some bsp to \wince500\platform\
2, import that bsp and new a platform, using default setting
3, in "platform setting" -> "Build Options", only check IMGEBOOT=1
4, build and sysgen with "clean before building"
and I have got the following message:
BUILD: [00:0000000202:PROGC ] Linking
\WINCE500\PLATFORM\SMDK2440\KERNEL\BUILDEXE\KERN\ directory.
BUILD: [01:0000000210:ERRORE] NMAKE : U1073: don't know how to make
'E:\WINCE500\PBWorkspaces\t1_2440_handheld_default\WINCE500\smdk2440_ARMV4I\cesysgen\oak\lib\ARMV4I\retail\csp_arm.lib'
BUILD: [01:0000000212:ERRORE] NMAKE.EXE -i -c BUILDMSG=Stop. LINKONLY=1
NOPASS0=1 failed - rc = 2
for another bsp I have got:
BUILD: [00:0000000160:PROGC ] Compiling
\WINCE500\PLATFORM\SMDK2440A\Src\Drivers\AtapiRomi\ directory.
BUILD: [01:0000000167:ERRORE] NMAKE : U1073: don't know how to make
BUILD: [01:0000000169:ERRORE] NMAKE.EXE -i -c BUILDMSG=Stop. NOLINK=1
the first bsp is from board vender and the second is said to be provided by
samsung formally. both should be work.
I don't know why. should I add something from the right catalog window to
make minimum building?
Do you have the mentioned libs (storeapi.lib & csp_arm.lib) on the
path that is shown in the error message?
References:
Prev by Date: Re: Creating .obj file
Next by Date: Re: Creating .obj file
Previous by thread: Re: ERRORE] NMAKE : U1073: don't know how to make ...
Next by thread: RE: ERRORE] NMAKE : U1073: don't know how to make ...
Index(es):
Date
Thread
Relevant Pages
Re: ERRORE] NMAKE : U1073: dont know how to make ...
... Take a look at the following blog post to tell you why: http://guruce.com/blogpost/whattobuildwhen ... After installing CE 5.0 install all QFE's ... 2, import that bsp and new a platform, using default setting ... path that is shown in the error message? ...
(microsoft.public.windowsce.platbuilder)
... 2, import that bsp and new a platform, using default setting ... make minimum building? ... path that is shown in the error message? ...
Re: Error while compiling WINCE OS 6.0 with Emulator ARMV4I
... Augustin schreef: ... I have send you the link to your ID,for the WINCE 6.0 BSP whatever i am using. ... Sysgening platform C:\WINCE500\platform\Adelaide_298 ... For every QFE they include a read me which tells you exaclty what will change/update when you install the QFE. ...
(microsoft.public.windowsce.app.development)
Re: wince 5.0 evaluation version
... But the PB cannot build OS if the support for XScale is not included. ... Armv4i and XScale. ... Install support for XSCALE ... Create a new BSP form BSP Wizard selecting Armv4i ...
... I'm able to build for a 270 and I've never installed the XSCALE stuff (as ... But the PB cannot build OS if the support for XScale is not included. ... Install support for XSCALE ... Create a new BSP form BSP Wizard selecting Armv4i ...
We are proud to have Web Hosting and Rack Housing from 9 Net Avenue Deutschland.
(17)
Windows Science Usenet ArchiveAboutPrivacySearchImprint  www.tech-archive.net  > Archive  > WindowsCE  > microsoft.public.windowsce.platbuilder  > 2008-12
很乱,不明白讲什么。  详情 回复 发表于 2009-6-8 21:30
很乱,不明白讲什么。
