2438|1
【平头哥RVB2601创意应用开发】移植U8g2图形库+LCD显示天气 [复制链接]
1、移植u8g2图形库,参考的链接:【平头哥RVB2601创意应用开发】实践2-移植U8g2图形库 https://bbs.eeworld.com.cn/thread-1198007-1-1.html,感谢这位博主!
移植的过程,折腾了好久,最终弄完是,工程树形里面不显示,但是实际的工程有。本人是使用vscode和集成开发环境cdk组合使用的。用vscode编辑代码,cdk编译、下载代码。
2、代码的编写:(按照上次WiFi获取天气进行)
代码没有做任何鲁棒性考虑,先把整体功能调通,最终再优化。
void w800_data_receive_callback(int linkid, void *data, size_t len, char remote_ip[16], uint16_t remote_ports)
    uint8_t *buf;
    buf = (uint8_t *)data;
    if(len == 0)
        return;
    if(buf == NULL)
        return;
    printf("Receive data len: %d\r\n",len);
    printf("Receive data:");
    for(uint16_t i = 0; i < len; i++)
//        printf("%02X ",buf);
        printf("%c",buf);
    printf("\r\n\r\n");
    cJSON *body = NULL;
    uint8_t *cjson_buf = NULL;
    char buffer_temp[100];
    body = cJSON_Parse(buf);
    cjson_buf = cJSON_Print(body);
    printf("%s\r\r\n",cjson_buf);
    cJSON *cJSON_GetObjectItem(cJSON *object,const char *string);
    cJSON *cjson_data = NULL;
    cJSON *cjson_cityName = NULL;
    cJSON *cjson_lastUpdate = NULL;
    cJSON *cjson_fl = NULL;
    cJSON *cjson_fx = NULL;
    cJSON *cjson_qw = NULL;
    printf("\r\n\r\n");
    cjson_data = cJSON_GetObjectItem(body,"data");
        cjson_cityName = cJSON_GetObjectItem(cjson_data,"cityName");
    cjson_buf = cJSON_Print(cjson_cityName);
    memset(buffer_temp,0,sizeof(buffer_temp));
    strcat(buffer_temp,"cityName:");
    strcat(buffer_temp,cjson_buf);
    u8g2_DrawUTF8(&u8g2, 0, 12, buffer_temp);
    u8g2_SendBuffer(&u8g2);
    cjson_lastUpdate = cJSON_GetObjectItem(cjson_data,"lastUpdate");
    cjson_buf = cJSON_Print(cjson_lastUpdate);
    //strcat(buffer_temp,"lastUpdate:");
    u8g2_DrawUTF8(&u8g2, 0, 24, buffer_temp);
    cjson_fl = cJSON_GetObjectItem(cjson_data,"fl");
    cjson_buf = cJSON_Print(cjson_fl);
    strcat(buffer_temp,"fl:");
    u8g2_DrawUTF8(&u8g2, 0, 36, buffer_temp);
    cjson_fx = cJSON_GetObjectItem(cjson_data,"fx");
    cjson_buf = cJSON_Print(cjson_fx);
    strcat(buffer_temp,"fx:");
    u8g2_DrawUTF8(&u8g2, 0, 48, buffer_temp);
    cjson_qw = cJSON_GetObjectItem(cjson_data,"qw");
    cjson_buf = cJSON_Print(cjson_qw);
    strcat(buffer_temp,"qw:");
    u8g2_DrawUTF8(&u8g2, 0, 60, buffer_temp);
3、显示结果
效果非常好了,点赞点赞,加油加油!   详情 回复 发表于 2022-5-7 07:16
7047
效果非常好了,点赞点赞,加油加油!
