【AT-START-F425测评】USB转CAN之二
我的起始工程是基于RT_Thread CAN工程搭建的。
1、在原来的基础工程上添加USB工程的驱动:
从USB工程中拷贝usb_drivers、usbd_class、usbh_class三个文件夹到工程的\libraries\middlewares文件夹下面。
2、在mdk工程中新加入文件:
3、从原来的USB虚拟串口工程中拷贝usb_conf.h到user文件夹下:
4、在mdk中添加头文件的引用:
5、修改usb_delay_ms为rt_thread_mdelay,同时给头文件添加必要的地方添加rtthread.h头文件。
6、新建usb_port.c与usb_port.h文件
#include "usb_port.h"
#include "usb_conf.h"
#include "usb_core.h"
#include "usbd_int.h"
#include "cdc_class.h"
#include "cdc_desc.h"
#include "rtthread.h"
#include "usb_std.h"
otg_core_type otg_core_struct;
uint8_t usb_buffer[256];
void usb_clock48m_select(usb_clk48_s clk_s);
void usb_gpio_config(void);
void usb_low_power_wakeup_config(void);
/* usart global struct define */
extern linecoding_type linecoding;
void usb_usart_config(linecoding_type linecoding);
void usart_gpio_config(void);
#define usart_buffer_size 1024
uint8_t usart_rx_buffer[usart_buffer_size];
uint16_t hw_usart_rx_index = 0;
uint16_t hw_usart_read_index = 0;
uint16_t usart_rx_data_len = 0;
uint16_t ov_cnt = 0;
void usart_send_data(uint8_t *send_data, uint16_t len);
uint16_t usart_receive_data(void);
void usb_usart_config( linecoding_type linecoding)
usart_stop_bit_num_type usart_stop_bit;
usart_data_bit_num_type usart_data_bit;
usart_parity_selection_type usart_parity_select;
/* enable the usart2 and gpio clock */
crm_periph_clock_enable(CRM_USART2_PERIPH_CLOCK, FALSE);
crm_periph_clock_enable(CRM_USART2_PERIPH_CLOCK, TRUE);
/* stop bit */
switch(linecoding.format)
case 0x0:
usart_stop_bit = USART_STOP_1_BIT;
break;
/* to be used when transmitting and receiving data in smartcard mode */
case 0x1:
usart_stop_bit = USART_STOP_1_5_BIT;
break;
case 0x2:
usart_stop_bit = USART_STOP_2_BIT;
break;
default :
break;
/* data bits */
switch(linecoding.data)
case 0x8:
usart_data_bit = USART_DATA_8BITS;
break;
case 0x7:
usart_data_bit = USART_DATA_7BITS;
break;
/* hardware usart not support data bits for 5/6/16 */
case 0x5:
case 0x6:
case 0x10:
break;
default :
break;
/* parity */
switch(linecoding.parity)
case 0x0:
usart_parity_select = USART_PARITY_NONE;
break;
case 0x1:
usart_parity_select = USART_PARITY_ODD;
break;
case 0x2:
usart_parity_select = USART_PARITY_EVEN;
break;
/* hardware usart not support parity for mark and space */
case 0x3:
case 0x4:
break;
default :
break;
nvic_irq_enable(USART2_IRQn, 0, 0);
/* configure usart2 param */
usart_init(USART2, linecoding.bitrate, usart_data_bit, usart_stop_bit);
usart_parity_selection_config(USART2, usart_parity_select);
usart_transmitter_enable(USART2, TRUE);
usart_receiver_enable(USART2, TRUE);
/* enable usart2 interrupt */
usart_interrupt_enable(USART2, USART_RDBF_INT, TRUE);
usart_enable(USART2, TRUE);
* @brief this function handles usart2 gpio config.
* @param none
* @retval none
gpio_init_type gpio_init_struct;
crm_periph_clock_enable(CRM_GPIOA_PERIPH_CLOCK, TRUE);
/* configure the usart2 tx, rx pin */
gpio_init_struct.gpio_drive_strength = GPIO_DRIVE_STRENGTH_STRONGER;
gpio_init_struct.gpio_out_type = GPIO_OUTPUT_PUSH_PULL;
gpio_init_struct.gpio_mode = GPIO_MODE_MUX;
gpio_init_struct.gpio_pins = GPIO_PINS_2 | GPIO_PINS_3;
gpio_init_struct.gpio_pull = GPIO_PULL_NONE;
gpio_init(GPIOA, &gpio_init_struct);
gpio_pin_mux_config(GPIOA, GPIO_PINS_SOURCE2, GPIO_MUX_1);
gpio_pin_mux_config(GPIOA, GPIO_PINS_SOURCE3, GPIO_MUX_1);
* @brief usb 48M clock select
* @param clk_s:USB_CLK_HICK, USB_CLK_HEXT
* @retval none
if(clk_s == USB_CLK_HICK)
crm_usb_clock_source_select(CRM_USB_CLOCK_SOURCE_HICK);
/* enable the acc calibration ready interrupt */
crm_periph_clock_enable(CRM_ACC_PERIPH_CLOCK, TRUE);
/* update the c1\c2\c3 value */
acc_write_c1(7980);
acc_write_c2(8000);
acc_write_c3(8020);
/* open acc calibration */
acc_calibration_mode_enable(ACC_CAL_HICKTRIM, TRUE);
else
switch(system_core_clock)
/* 48MHz */
case 48000000:
crm_usb_clock_div_set(CRM_USB_DIV_1);
break;
/* 72MHz */
case 72000000:
crm_usb_clock_div_set(CRM_USB_DIV_1_5);
break;
/* 96MHz */
case 96000000:
crm_usb_clock_div_set(CRM_USB_DIV_2);
break;
default:
break;
* @brief this function config gpio.
* @param none
* @retval none
crm_periph_clock_enable(OTG_PIN_GPIO_CLOCK, TRUE);
gpio_default_para_init(&gpio_init_struct);
#ifdef USB_SOF_OUTPUT_ENABLE
crm_periph_clock_enable(OTG_PIN_SOF_GPIO_CLOCK, TRUE);
gpio_init_struct.gpio_pins = OTG_PIN_SOF;
gpio_init(OTG_PIN_SOF_GPIO, &gpio_init_struct);
gpio_pin_mux_config(OTG_PIN_GPIO, OTG_PIN_SOF_SOURCE, OTG_PIN_MUX);
#endif
/* otgfs use vbus pin */
#ifndef USB_VBUS_IGNORE
gpio_init_struct.gpio_pins = OTG_PIN_VBUS;
gpio_init_struct.gpio_pull = GPIO_PULL_DOWN;
gpio_pin_mux_config(OTG_PIN_GPIO, OTG_PIN_VBUS_SOURCE, OTG_PIN_MUX);
gpio_init(OTG_PIN_GPIO, &gpio_init_struct);
#endif
#ifdef USB_LOW_POWER_WAKUP
* @brief usb low power wakeup interrupt config
* @param none
* @retval none
exint_init_type exint_init_struct;
crm_periph_clock_enable(CRM_SCFG_PERIPH_CLOCK, TRUE);
exint_default_para_init(&exint_init_struct);
exint_init_struct.line_enable = TRUE;
exint_init_struct.line_mode = EXINT_LINE_INTERRUPUT;
exint_init_struct.line_select = OTG_WKUP_EXINT_LINE;
exint_init_struct.line_polarity = EXINT_TRIGGER_RISING_EDGE;
exint_init(&exint_init_struct);
#endif
* @brief this function handles otgfs interrupt.
* @param none
* @retval none
void OTG_IRQ_HANDLER(void)
if(exint_flag_get(OTG_WKUP_EXINT_LINE))
exint_flag_clear(OTG_WKUP_EXINT_LINE);
usbd_irq_handler(&otg_core_struct);
void usb_init_port(void)
/* usart gpio config */
usart_gpio_config();
/* hardware usart config: usart2 */
usb_usart_config(linecoding);
/* usb gpio config */
usb_gpio_config();
/* enable otgfs clock */
crm_periph_clock_enable(OTG_CLOCK, TRUE);
/* select usb 48m clcok source */
usb_clock48m_select(USB_CLK_HEXT);
/* enable otgfs irq */
nvic_irq_enable(OTG_IRQ, 0, 0);
/* init usb */
usbd_init(&otg_core_struct,
USB_FULL_SPEED_CORE_ID,
USB_ID,
&cdc_class_handler,
&cdc_desc_handler);
* @brief this function handles usart2 send data.
* @param send_data: pointer to data
* @param len: data len
* @retval none
uint16_t index = 0;
for(index = 0; index < len; index++ )
do
}while(usart_flag_get(USART2, USART_TDBE_FLAG) == RESET);
usart_data_transmit(USART2, send_data[index]);
* @brief this function handles usart2 receive data.
* @param none
* @retval the data len
uint16_t usart_data_len;
if(hw_usart_read_index == hw_usart_rx_index)
usart_data_len = 0;
else
/* whether to process the fifo overflow or not */
if(hw_usart_rx_index > hw_usart_read_index)
usart_data_len = hw_usart_rx_index - hw_usart_read_index;
else if(hw_usart_rx_index == 0 && hw_usart_rx_index != hw_usart_read_index)
usart_data_len = usart_buffer_size - hw_usart_read_index;
else
usart_data_len = (usart_buffer_size-1) + hw_usart_rx_index - hw_usart_read_index;
return usart_data_len;
* @brief this function handles usart2 handler.
* @param none
* @retval none
void USART2_IRQHandler(void)
if(usart_flag_get(USART2, USART_RDBF_FLAG) != RESET)
/* read one byte from the receive data register */
usart_rx_buffer[hw_usart_rx_index] = usart_data_receive(USART2);
hw_usart_rx_index = ( (hw_usart_rx_index+1) & (usart_buffer_size-1) );
void usb_recv_test(void)
uint16_t data_len;
uint32_t timeout;
uint8_t send_zero_packet = 0;
/* get usb vcp receive data */
data_len = usb_vcp_get_rxdata(&otg_core_struct.dev, usb_buffer);
/* send data to hardware usart */
if(data_len > 0)
usart_send_data(usb_buffer, data_len);
/* if hardware usart received data,usb send data to host */
usart_rx_data_len = usart_receive_data();
if(usart_rx_data_len || send_zero_packet == 1)
if(usart_rx_data_len > 0)
send_zero_packet = 1;
if(usart_rx_data_len == 0)
timeout = 500;
if((hw_usart_read_index + usart_rx_data_len) < usart_buffer_size)
do
/* send data to host */
if(usb_vcp_send_data(&otg_core_struct.dev, &usart_rx_buffer[hw_usart_read_index], usart_rx_data_len) == SUCCESS)
hw_usart_read_index = hw_usart_read_index + usart_rx_data_len;
break;
}while(timeout --);
/* process the fifo overflow */
else
do
if(usb_vcp_send_data(&otg_core_struct.dev, &usart_rx_buffer[hw_usart_read_index], usart_buffer_size - hw_usart_read_index) == SUCCESS)
/* get fifo overflow data count */
ov_cnt = usart_rx_data_len - (usart_buffer_size - hw_usart_read_index);
break;
}while(timeout --);
timeout = 50;
do
if(usb_vcp_send_data(&otg_core_struct.dev, &usart_rx_buffer[hw_usart_read_index], ov_cnt) == SUCCESS)
hw_usart_read_index = ov_cnt;
break;
}while(timeout --);
usbpor.h
#ifndef _USB_PORT_H_
#define _USB_PORT_H_
#include "at32f425.h"
#include "at32f425_board.h"
void usb_init_port(void);
void usb_recv_test(void);
#endif
7、在main.c中引用usb_port.h头文件,添加usb初始化函数。
int main(void)
can_configuration();
usb_init_port();
tid_rudder = rt_thread_create("RUDDER",
tid_rudder_entry, RT_NULL,
KEY_THREAD_STACK_SIZE,
THREAD_PRIORITY, THREAD_TIMESLICE);
/* 如果获得线程控制块,启动这个线程 */
if (tid_rudder != RT_NULL)
rt_thread_startup(tid_rudder);
usart_send_data("hello\n",6);
while(1)
usb_recv_test();
rt_thread_mdelay(10);
// at32_led_toggle(LED2);
// rt_thread_mdelay(g_speed * DELAY);
// at32_led_toggle(LED3);
// at32_led_toggle(LED4);
//can_transmit_data();
//at32can_count.can_tx ++;
至此所有usb驱动移植玩必,编译时有时会报一些引用函数的错误,一一找出来添回或按指定修改就OK。
【实验现象】连接USART2的TX引脚(PA2)和RX(PA3)
实验现象为:
至此虚拟串口移植到CAN工程中已经完成。
下一步,修改串口与CAN的中转接口函数。
