1973|1
130
【平头哥RVB2601创意应用开发】串口接收字符并在oled屏幕上显示 [复制链接]
实现了串口接收字符并在oled屏幕上显示的功能,具体代码如下:/*
 * Copyright (C) 2015-2017 Alibaba Group Holding Limited
 *      INCLUDES
#define _DEFAULT_SOURCE /* needed for usleep() */
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <time.h>
#include <aos/aos.h>
#include "aos/cli.h"
#include "app_init.h"
#include "lvgl.h"
#include "lv_label.h"
#include "oled.h"
#include "myled.h"
#include "console_uart.h"
 *      DEFINES
#define TAG "app"
 *      TYPEDEFS
 *  STATIC PROTOTYPES
// GUI
//static void gui_lvgl_task(void *arg);
 *  STATIC VARIABLES
 *      MACROS
 *   GLOBAL FUNCTIONS
#define N 80
volatile uint32_t g_debug   = 0;
volatile uint32_t g_debug_v = 0;
volatile char c;
char myinput[N];
static lv_obj_t *p;
static void led_task(void *arg);
static void ch_input_task(void *arg);
void fun(char *str);
#include "csi_core.h"
 * main
int main(void)
    board_yoc_init();
    myled_init();
    aos_task_new("gui", gui_lvgl_task, NULL, 10 * 1024);
    aos_task_new("led", led_task, NULL, 10 * 1024);
    aos_task_new("getchar", ch_input_task, NULL, 10 * 1024);
    return 0;
static void gui_label_create(void)
    p = lv_label_create(lv_scr_act(), NULL);
    lv_label_set_long_mode(p, LV_LABEL_LONG_BREAK);
    lv_label_set_align(p, LV_LABEL_ALIGN_LEFT);
    lv_obj_set_pos(p, 0, 4);
    lv_obj_set_size(p, 128, 60);
    lv_label_set_text(p, "Hello\n world!\n");
//    lv_label_set_long_mode(p, LV_LABEL_LONG_SROLL_CIRC);
    lv_init();
    /*Initialize for LittlevGL*/
    oled_init();
    /*Select display 1*/
    // demo_create();
    gui_label_create();
//    extern static lv_obj_t *p;
    while (1) {
        /* Periodically call the lv_task handler.
         * It could be done in a timer interrupt or an OS task too.*/
        lv_task_handler();
//        LOGD(TAG, "hello world!");
        aos_msleep(5);
        lv_label_set_text(p, myinput);
        lv_tick_inc(1);
static void led_task(void *arg){
    while(1){
        myled_test();
static void ch_input_task(void *arg){
    while(1){
    fun(myinput);
    printf("%s",myinput);
    aos_msleep(5);
void fun(char * str){
    for (int i=0,ch ='\0';ch != '\n';++i){
        ch= uart_getc();
        if(i>=N){
            continue;
        if(ch == '\n' ||i == N-1){
            str = '\0';
            continue;
        str =ch;
每次看到这些能现实显示的操作,就感叹开发板的设计者的高明   详情 回复 发表于 2022-3-25 21:21
4854
会议时间:3月18日(周二)09:30签到
参会奖励:电动螺丝刀套装、户外登山包、京东卡
