1060|0
HDMI2.1到DP1.4,支持8K@60Hz分辨率,适应最新的USB Type-C系统 [复制链接]
1.  描述
Lontium LT6711GX是HDMI2.1到DP1.4转换器与内部c型交替模式开关和PD控制器。
对于HDMI输入,它由4个数据通道组成,支持3,6或8Gbps的链路速度。 它允许8K@60Hz与DSC或8K@30Hz的最高分辨率。
对于DP1.4输出,它由4个数据通道组成,支持1.62、2.7、5.4或8.1Gbps的链路速度。 内置可选SSC功能减少电磁干扰影响。
为了适应最新的USB Type-C系统,LT6711GX集成了一个高性能的双向超高速,由CC逻辑和PD管理单元控制,以减轻移动系统的设计复杂性和BOM成本。
LT6711GX采用先进的CMOS工艺制作,采用10mmx10mmqfn88封装。 该封装符合RoHS标准,可在-40°C至+85°C范围内工作。
 2 特性
•HDMI2.1接收机
•DP1.4发射机
•USB c型
•杂项
3. 应用程序
•移动系统、VR/AR
•手机、PAD/平板电脑
•数码摄像机
•数码静止相机
1. Description
The Lontium LT6711GX is HDMI2.1 to DP1.4 converter with internal Type-C Alternate Mode switch and PD controller.
For HDMI input, it consists of 4 data lanes, support 3, 6 or 8Gbps link speeds. It allow for the highest resolutions of 8K@60Hz with DSC or 8K@30Hz.
For DP1.4 output, it consists of 4 data lanes, support 1.62, 2.7, 5.4 or 8.1Gbps link speeds. The build-in optional SSC function reduces EMI effect.
In order to be adaptable to the latest USB Type-C system, LT6711GX integrates a high performance bi-directional Super-Speed controlled by CC logic and PD management unit to relieve mobile system design complexity and BOM cost.
The LT6711GX is fabricated in advanced CMOS process and implemented in 10mmx10mm QFN88 package. This package is RoHS compliant and specified to operate from -40°C to +85°C.
2. Features
• HDMI2.1 Receiver
• DP1.4 Transmitter
• USB Type-C
• Miscellaneous
3. Applications
• Mobile systems, VR/AR
• Cellular handsets, PAD/Tablets
• Digital video cameras
• Digital still cameras
