1588|0
395
【GD32L233C-START评测】+猜猜下次哪个灯会亮 [复制链接]
GD32L233C 含有真随机数发生器模块(TRNG)能够通过连续模拟噪声生成一个32 位的随机数值。
操作步骤在手册里有详细说明,如下图
主函数
uint32_t random_data = 0, random_lastdata = 0;
    uint8_t retry = 0;
    /* configure systick */
    systick_config();
		/* turn on the oscillator */
    rcu_osci_on(RCU_IRC48M);
	    if(ERROR == rcu_osci_stab_wait(RCU_IRC48M)){
        while(1){
    /* initilize the LEDs, USART and key */
    gd_eval_led_init(LED1);
    gd_eval_led_init(LED2);
		gd_eval_led_init(LED3);
    gd_eval_led_init(LED4);
    gd_eval_com_init(EVAL_COM);
    gd_eval_key_init(KEY_WAKEUP, KEY_MODE_GPIO);
    /* print out the clock frequency of system, AHB, APB1 and APB2 */
    printf("\r\nCK_SYS is %d", rcu_clock_freq_get(CK_SYS));
    printf("\r\nCK_AHB is %d", rcu_clock_freq_get(CK_AHB));
    printf("\r\nCK_APB1 is %d", rcu_clock_freq_get(CK_APB1));
    printf("\r\nCK_APB2 is %d", rcu_clock_freq_get(CK_APB2));
    /* show example introduce */
    printf("============ Gigadevice TRNG poll mode demo ============ \r\n");
		/* configure TRNG module */
    while((ERROR == trng_configuration()) && retry < 3) {
        printf("TRNG init fail \r\n");
        printf("TRNG init retry \r\n");
        retry++;
		printf("TRNG init ok \r\n");
    /* get the first random data */
    random_lastdata = trng_get_true_random_data();
    while(1) {
        if(SET == gd_eval_key_state_get(KEY_WAKEUP)) {
            delay_1ms(50);
                /* check wherther the random data is valid and get it */
							if(SUCCESS == trng_ready_check()) {
									random_data = trng_get_true_random_data();
									if(random_data != random_lastdata) {
											random_lastdata = random_data;
											printf("Get random data: 0x%08x \r\n", random_data);
									} else {
											/* the random data is invalid */
											printf("Error: Get the random data is same \r\n");
									gd_eval_led_off(LED1);
									gd_eval_led_off(LED2);
									gd_eval_led_off(LED3);
									gd_eval_led_off(LED4);
									switch(random_data%4)
										case 0:gd_eval_led_on(LED1);break;
										case 1:gd_eval_led_on(LED2);break;
										case 2:gd_eval_led_on(LED3);break;
										case 3:gd_eval_led_on(LED4);break;
										default:break;
            while(RESET == gd_eval_key_state_get(KEY_WAKEUP)) {
随机数模块检查
    uint32_t timeout = 0;
    FlagStatus trng_flag = RESET;
    ErrStatus reval = SUCCESS;
    /* check wherther the random data is valid */
    do {
        timeout++;
        trng_flag = trng_flag_get(TRNG_FLAG_DRDY);
    } while((RESET == trng_flag) && (0xFFFF > timeout));
    if(RESET == trng_flag) {
        /* ready check timeout */
        printf("Error: TRNG can't ready \r\n");
        trng_flag = trng_flag_get(TRNG_FLAG_CECS);
        printf("Clock error current status: %d \r\n", trng_flag);
        trng_flag = trng_flag_get(TRNG_FLAG_SECS);
        printf("Seed error current status: %d \r\n", trng_flag);
        reval = ERROR;
    /* return check status */
    return reval;
随机数模块配置
    /* TRNG module clock enable */
    rcu_periph_clock_enable(RCU_TRNG);
    /* TRNG registers reset */
    trng_disable();
    trng_enable();
    /* check TRNG work status */
    reval = trng_ready_check();
    return reval;
按下开发板上的按键K2(Wakeup),LED1-LED4将会随机电量一盏灯
此帖出自GD32 MCU论坛
