2577|3
86
串口信息如下,请高手分析~ [复制链接]
MMC::MMCCommandResponse: MMCSendCommand error, command = 17
MMC::MMCCommandResponse: Command Response Error
MMCRead: MMCCommandResponse error on READ_SINGLE_BLOCK!
read error
SDHC: command response timeout CTO!
MMC::MMCCommandResponse: MMCSendCommand error, command = 7
SDCardReadSector: Error reading file, retry (sector 49411)
rom_offset=0x0.
ImageStart = 0x84001000, ImageLength = 0x3B50EE4, LaunchAddr = 0x8400B8A4
Completed file(s):
[0]: Address=0x84001000  Length=0x3B50EE4  Name="" Target=RAM
ROMHDR at Address 84001044h
Launch Windows CE image by jumping to 0x8000b8a4...
Windows CE Kernel for ARM (Thumb Enabled) Built on Nov 24 2008 at 14:58:23
ProcessorType=0c08  Revision=2
OEMAddressTable = 8400b944
CPU CP15 Control Register = 0xc5387f
CPU CP15 Auxiliary Control Register = 0xe3
--- High Performance Frequecy is 32768 khz---
这是个什么问题呢?
非常感谢你的回答,不过好像不是SD host的问题,因为我用down下来的NK时,时能正常启动的。难道是内核定制哪些地方搞错了,导致加载错误?  详情 回复 发表于 2009-11-3 10:51
是不是发错了,前头还有这些:
OMAP3430 Version 0x2b7ae02f (ES2.1, ID determined using CRC)
TWL4030 Version 0x10 (ES2.x)
System ready!
Preparing for download...
INFO: Predownload....
WARN: Boot config wasn't found, using defaults...
Hit space to enter configuration menu 5...
Hit space to enter configuration menu 4...
Hit space to enter configuration menu 3...
Hit space to enter configuration menu 2...
Hit space to enter configuration menu 1...
Init HW: controller RST
BL_IMAGE_TYPE_BIN
Download file information:
[0]: Address=0x84001000  Length=0x03b50ee4  Save=0x80001000
Download file type: 1
SDIPollingReceive: TIMEOUT1
SDHC: SDIPollingReceive() failed
read error
79
SD host 读写操作失败
可能是你的SD host 出问题了或者接触不好?
引用 2 楼 suwyhoho 的回复:
SD host 读写操作失败
