3079|3
为什么电压表数值始终为5,不变 [复制链接]
#include <reg52.h>
#define uint unsigned int
#define uchar unsigned char
uchar code LEDData[]=
 	0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
sbit OE  = P1^0;
sbit EOC = P1^1;
sbit ST  = P1^2;
sbit CLK = P1^3;
sbit dp=P0^7;
void DelayMS(uint ms)
 	uchar i;
	while(ms--)
	 	for(i=0;i<120;i++);
void Display_Result(uint d)
 	P2 = 0xf7;
	P0 = LEDData[d%10];
	DelayMS(5);
	P2 = 0xfb;
	P0 = LEDData[d%100/10];
	DelayMS(5);
	P2 = 0xfd;
	P0 = LEDData[d/100%10];
	DelayMS(5);
                 P2 = 0xfe;
	P0 = LEDData[d/1000];
	dp=1;
	DelayMS(5);
void main()
	uint v;
 	TMOD = 0x02;
	TH0  = 0x14;
	TL0  = 0x00;
	IE   = 0x82;
	TR0  = 1;
	P1   = 0x3f;
	while(1)
	 	ST = 0;
		ST = 1;
		ST = 0;
		while(EOC == 0);
		OE = 1;
	                 v=P3*19.607843;
		Display_Result(v);
		OE = 0;
void Timer0_INT() interrupt 1
 	CLK = !CLK;
此帖出自51单片机论坛
哥哥你的总线那么智能吗,都没联通好像。   详情 回复 发表于 2021-12-22 10:26
此帖出自51单片机论坛
6040
202
哥哥你的总线那么智能吗,都没联通好像。
此帖出自51单片机论坛
搞定了兄弟,感谢指点  详情 回复 发表于 2021-12-22 11:33
lcofjp 发表于 2021-12-22 10:26 哥哥你的总线那么智能吗,都没联通好像。
搞定了兄弟,感谢指点
此帖出自51单片机论坛
