3108|5
75
DDRAW程序问题,在全屏方式下,用创建程序的方式打开一个程序后,程序的界面显示不出来,LCD上显示的还是DDRAW的画面 [复制链接]
请问如何解决这个问题
// Copyright (c) Microsoft Corporation.  All rights reserved.
// Use of this source code is subject to the terms of the Microsoft end-user
// license agreement (EULA) under which you licensed this SOFTWARE PRODUCT.
// If you did not accept the terms of the EULA, you are not authorized to use
// this source code. For a copy of the EULA, please see the LICENSE.RTF on your
// install media.
// File: DDEx1.CPP
// Desc: Direct Draw example program 1.  Creates a Direct Draw
//       object and then a primary surface with a back buffer.
//       Slowly flips between the primary surface and the back
//       buffer.  Press F12 to terminate the program.
#ifndef WIN32_LEAN_AND_MEAN
#define WIN32_LEAN_AND_MEAN
#endif
// Include files
#include
#include
#include "resource.h"
// Local definitions
#define NAME                TEXT("DDExample1")
#define TITLE               TEXT("Direct Draw Example 1")
// Default settings
#define TIMER_ID            1
#define TIMER_RATE          500
// Global data
LPDIRECTDRAW4               g_pDD = NULL;        // DirectDraw object
LPDIRECTDRAWSURFACE4        g_pDDSPrimary = NULL;// DirectDraw primary surface
LPDIRECTDRAWSURFACE4        g_pDDSBack = NULL;   // DirectDraw back surface
BOOL                        g_bActive = FALSE;   // Is application active?
// Local data
static TCHAR                szMsg[] = TEXT("Page Flipping Test: Press F12 to exit");
static TCHAR                szFrontMsg[] = TEXT("Front buffer (F12 to quit)");
static TCHAR                szBackMsg[] = TEXT("Back buffer (F12 to quit)");
// Name: ReleaseAllObjects()
// Desc: Finished with all objects we use; release them
static void
ReleaseAllObjects(void)
    if (g_pDDSBack != NULL)
        g_pDDSBack->Release();
        g_pDDSBack = NULL;
    if (g_pDDSPrimary != NULL)
        g_pDDSPrimary->Release();
    if (g_pDD != NULL)
        g_pDD->Release();
        g_pDD = NULL;
// Name: InitFail()
// Desc: This function is called if an initialization function fails
#define PREFIX      TEXT("DDEX1: ")
#define PREFIX_LEN  7
HRESULT
InitFail(HWND hWnd, HRESULT hRet, LPCTSTR szError,...)
    TCHAR                       szBuff[128];
    va_list                     vl;
    va_start(vl, szError);
    wsprintf(szBuff, PREFIX);
    wvsprintf(szBuff + PREFIX_LEN, szError, vl);
    ReleaseAllObjects();
    OutputDebugString(szBuff);
    DestroyWindow(hWnd);
    va_end(vl);
    return hRet;
#undef PREFIX_LEN
#undef PREFIX
// Name: UpdateFrame()
// Desc: Displays the proper text for the page
static void
UpdateFrame(HWND hWnd)
    static BYTE phase = 0;
    HDC hdc;
    RECT rc;
    SIZE size;
    int nMsg;
    DDBLTFX ddbltfx;
    // Use the blter to do a color fill to clear the back buffer
    memset(&ddbltfx, 0, sizeof(ddbltfx));
    ddbltfx.dwSize = sizeof(ddbltfx);
    ddbltfx.dwFillColor = 0;
    g_pDDSBack->Blt(NULL, NULL, NULL, DDBLT_COLORFILL | DDBLT_WAIT, &ddbltfx);
    if (g_pDDSBack->GetDC(&hdc) == DD_OK)
        SetBkColor(hdc, RGB(0, 0, 255));
                SetBkMode (hdc, TRANSPARENT);
        SetTextColor(hdc, RGB(255, 255, 0));
        GetClientRect(hWnd, &rc);
        if (phase)
                nMsg = lstrlen(szMsg);
            GetTextExtentPoint(hdc, szMsg, nMsg, &size);
            ExtTextOut(hdc,
                       (rc.right - size.cx) / 2,
                       (rc.bottom - size.cy) / 2,
                       0,                        // fuOptions
                       NULL,                     // lprc
               szMsg,
                       nMsg,
                       NULL);                    // lpDx
            nMsg = lstrlen(szFrontMsg);
            GetTextExtentPoint(hdc, szFrontMsg, nMsg, &size);
            ExtTextOut(hdc,
                       (rc.right - size.cx) / 2, // Center horz. for tv reasons
                       0,
                       0,                        // fuOptions
                       NULL,                     // lprc
                       szFrontMsg,
                       nMsg,
                       NULL);                    // lpDx
            phase = 0;
        else
            nMsg = lstrlen(szBackMsg);
            GetTextExtentPoint(hdc, szBackMsg, nMsg, &size);
            ExtTextOut(hdc,
                       0,
                       0,                        // fuOptions
                       NULL,                     // lprc
                       szBackMsg,
                       nMsg,
                       NULL);                    // lpDx
            phase = 1;
        g_pDDSBack->ReleaseDC(hdc);
         HRESULT                     hRet;
         while (TRUE)
                    hRet = g_pDDSPrimary->Flip(NULL, 0);
                    if (hRet == DD_OK)
                        break;
                    if (hRet == DDERR_SURFACELOST)
                        hRet = g_pDDSPrimary->Restore();
                        if (hRet != DD_OK)
                            break;
                    if (hRet != DDERR_WASSTILLDRAWING)
                        break;
看完LZ的代码真的需要耐心  详情 回复 发表于 2009-6-4 13:33
61
// Name: WindowProc()
// Desc: The Main Window Procedure
long FAR PASCAL
WindowProc(HWND hWnd, UINT message, WPARAM wParam, LPARAM lParam)
    //HRESULT                     hRet;
    switch (message)
        case WM_ACTIVATE:
//        case WM_ACTIVATEAPP:
            // Pause if minimized or not the top window
            g_bActive = (wParam == WA_ACTIVE) || (wParam == WA_CLICKACTIVE);
            return 0L;
        case WM_DESTROY:
            // Clean up and close the app
            PostQuitMessage(0);
            return 0L;
        case WM_KEYDOWN:
            // Handle any non-accelerated key commands
            switch (wParam)
                case VK_ESCAPE:
                case VK_F12:
                    PostMessage(hWnd, WM_CLOSE, 0, 0);
                    return 0L;
            break;
                case WM_LBUTTONDOWN:
                                CreateProcess(_T("\\ResidentFlash\\CopyScreen.exe"), NULL, NULL, NULL,
                                        NULL, 0, NULL, NULL,NULL,NULL );
             break;
        case WM_SETCURSOR:
            // Turn off the cursor since this is a full-screen app
            SetCursor(NULL);
            return TRUE;
        case WM_TIMER:
            // Update and flip surfaces
            if (g_bActive && TIMER_ID == wParam)
                UpdateFrame(hWnd);
            break;
    return DefWindowProc(hWnd, message, wParam, lParam);
#define Msg(str)        MessageBox(GetActiveWindow(),TEXT(str),TEXT("Info"),\
                                                MB_OK|MB_ICONINFORMATION);
// Name: InitApp()
// Desc: Do work required for every instance of the application:
//          Create the window, initialize data
static HRESULT
InitApp(HINSTANCE hInstance, int nCmdShow)
    HWND                        hWnd;
    WNDCLASS                    wc;
    DDSURFACEDESC2              ddsd;
    DDSCAPS2                    ddscaps;
    HRESULT                     hRet;
    LPDIRECTDRAW                pDD;
    // Set up and register window class
    wc.style = CS_HREDRAW | CS_VREDRAW;
    wc.lpfnWndProc = WindowProc;
    wc.cbClsExtra = 0;
    wc.cbWndExtra = 0;
    wc.hInstance = hInstance;
    wc.hIcon = LoadIcon(hInstance, MAKEINTRESOURCE(IDI_MAIN_ICON));
    wc.hCursor = LoadCursor(NULL, IDC_ARROW);
    wc.hbrBackground = (HBRUSH )GetStockObject(BLACK_BRUSH);
    wc.lpszMenuName = NULL;
    wc.lpszClassName = NAME;
    RegisterClass(&wc);
    // Create a window
    hWnd = CreateWindowEx(WS_EX_TOPMOST,
                          NAME,
                          TITLE,
                          WS_POPUP,
                          0,
                          0,
                          GetSystemMetrics(SM_CXSCREEN),
                          GetSystemMetrics(SM_CYSCREEN),
                          NULL,
                          NULL,
                          hInstance,
                          NULL);
    if (!hWnd)
        return FALSE;
    ShowWindow(hWnd, nCmdShow);
    UpdateWindow(hWnd);
    SetFocus(hWnd);
    // Create the main DirectDraw object
    hRet = DirectDrawCreate(NULL, &pDD, NULL);
    if (hRet != DD_OK)
        return InitFail(hWnd, hRet, TEXT("DirectDrawCreate FAILED"));
    // Fetch DirectDraw4 interface
    hRet = pDD->QueryInterface(IID_IDirectDraw4, (LPVOID *) & g_pDD);
    if (hRet != DD_OK)
        return InitFail(hWnd, hRet, TEXT("QueryInterface FAILED"));
    pDD->Release();
    pDD = NULL;
    // Get exclusive mode
    hRet = g_pDD->SetCooperativeLevel(hWnd, DDSCL_EXCLUSIVE | DDSCL_FULLSCREEN);
    if (hRet != DD_OK)
        return InitFail(hWnd, hRet, TEXT("SetCooperativeLevel FAILED"));
    // Set the video mode to 640x480x8
        //Msg("UNDER_CE Before");
#ifndef UNDER_CE
    hRet = g_pDD->SetDisplayMode(800, 480, 16, 0, 0);
        //Msg("UNDER_CE");
    if (hRet != DD_OK)
        return InitFail(hWnd, hRet, TEXT("SetDisplayMode FAILED"));
#endif
    // Create the primary surface with 1 back buffer
    memset(&ddsd, 0, sizeof(ddsd));
    ddsd.dwSize = sizeof(ddsd);
    ddsd.dwFlags = DDSD_CAPS | DDSD_BACKBUFFERCOUNT;
    ddsd.ddsCaps.dwCaps = DDSCAPS_PRIMARYSURFACE |
        DDSCAPS_FLIP |
        DDSCAPS_COMPLEX;
    ddsd.dwBackBufferCount = 1;
    hRet = g_pDD->CreateSurface(&ddsd, &g_pDDSPrimary, NULL);
    if (hRet != DD_OK)
        if (hRet == DDERR_NOFLIPHW)
            return InitFail(hWnd, hRet, TEXT("******** Display driver doesn't support flipping surfaces. ********"));
        return InitFail(hWnd, hRet, TEXT("CreateSurface FAILED"));
    // Get a pointer to the back buffer
    ddscaps.dwCaps = DDSCAPS_BACKBUFFER;
    hRet = g_pDDSPrimary->GetAttachedSurface(&ddscaps, &g_pDDSBack);
    if (hRet != DD_OK)
        return InitFail(hWnd, hRet, TEXT("GetAttachedSurface FAILED"));
    // Create a timer to flip the pages
    if (TIMER_ID != SetTimer(hWnd, TIMER_ID, TIMER_RATE, NULL))
        return InitFail(hWnd, hRet, TEXT("SetTimer FAILED"));
    return DD_OK;
// Name: WinMain()
// Desc: Initialization, message loop
int PASCAL
WinMain(HINSTANCE hInstance,
        HINSTANCE hPrevInstance,
#ifdef UNDER_CE
        LPWSTR lpCmdLine,
#else
        LPSTR lpCmdLine,
#endif
        int nCmdShow)
    MSG                         msg;
    if (InitApp(hInstance, nCmdShow) != DD_OK)
        return FALSE;
    while (GetMessage(&msg, NULL, 0, 0))
        TranslateMessage(&msg);
        DispatchMessage(&msg);
    return msg.wParam;
54
            break;
问题是在创建该进程后,LCD屏的显示还是会被DDRAW部分显示占有,不会出现COPYSCREEN进程的界面,请问如何解决这样的问题,难道全屏模式下不能这样操作吗,还是有什么地方要注意的,请知道的说一声.我是在WINCE5.0上跑的
61
ztg0021
干起win32来了? 佩服!
你总是在我前面指引我。所以我只能顶了,抱歉。
84
gmam,我才来这发贴就被你发现啦,你都成富农了,哈哈
忙去了,88
66
看完LZ的代码真的需要耐心
