2828|2
59
Unable to locate the feature for the SYSGEN_JSCRIPT variable in the catalog [复制链接]
我用的PB4.2,每次选完我们的BSP,然后新建一个工程。都有如下的Warning(加粗部分),之后什么组件也不加,直接Build PlatForm就总会出现3个错误,用以前编译好的工程也是如此。不知道为什么。3个错误在最后列出。另外想问一下,PB4.2需要打补丁吗?需要的话打那个版本的补丁?希望得到大家的指点。
Updating the feature and driver list for your platform.
Warning PB2007: Unable to locate the feature for the SYSGEN_JSCRIPT variable in the catalog.
Added the Times New Roman (Subset 1_30) feature (SYSGEN_FONTS_TIMES_1_30) to the platform.
Added the Toolhelp API feature (SYSGEN_TOOLHELP) to the platform.
Added the Pocket Internet Explorer HTML View (WEBVIEW) feature (SYSGEN_WEBVIEW) to the platform.
Added the Printer Devices feature (SYSGEN_PRINTING) to the platform.
Added the Standard I/O (STDIO) feature (SYSGEN_STDIO) to the platform.
Added the SimSun & NSimSun feature (SYSGEN_FONTS_SIMSUN) to the platform.
Added the Standard I/O ASCII (STDIOA) feature (SYSGEN_STDIOA) to the platform.
Added the Internet Explorer Multiple-Language Base API feature (SYSGEN_MLANG) to the platform.
Added the Symbol feature (SYSGEN_FONTS_SYMBOL) to the platform.
Added the Storage Manager feature (SYSGEN_STOREMGR) to the platform.
Added the CAB File Installer/Uninstaller feature (SYSGEN_WCELOAD) to the platform.
Added the Windows Internet Services feature (SYSGEN_WININET) to the platform.
Added the URL Moniker Services feature (SYSGEN_URLMON) to the platform.
Added the RAM and ROM File System feature (SYSGEN_FSRAMROM) to the platform.
Added the C++ Exception Handling feature (SYSGEN_CPP_SEH) to the platform.
Added the Sample Internet Explorer 6.0 Internet Options Control Panel feature (SYSGEN_INETCPL) to the platform.
Added the Software-based Input Panel Driver feature (SYSGEN_SOFTKB) to the platform.
Added the Tahoma (Subset 1_07) feature (SYSGEN_FONTS_TAHOMA_1_07) to the platform.
Added the Internet Explorer Browser Control Host feature (SYSGEN_SHDOCVW) to the platform.
Added the RAM-based Registry feature (SYSGEN_FSREGRAM) to the platform.
Added the National Language Support (NLS) feature (SYSGEN_CORELOC) to the platform.
Added the Run-Time Type Information feature (SYSGEN_RTTI) to the platform.
Added the Telephony API (TAPI 2.0) feature (SYSGEN_TAPI) to the platform.
Added the Printer Devices driver to the platform.
Added the PCMCIA (i82365-compatible) driver to the platform.
Added the CS8900 driver to the platform.
Added the S32410 Touch Panel driver to the platform.
Added the S32410 USB Device driver to the platform.
Added the Storage Devices driver to the platform.
Added the PCI Bus driver to the platform.
Added the S32410 Audio driver to the platform.
Added the SMDK2410 Power Button driver to the platform.
Added the NOP (Stub) Keyboard/Mouse English driver to the platform.
Added the S32410 LCD Display driver to the platform.
Added the S32410 Serial UART driver to the platform.
1 warnings found. Not all features or drivers could be added. The build system will automatically include these when you build the platform.
makeimg: FATAL ERROR: Cannot open D:\WINCE420\PUBLIC\THREE\RelDir\MY2410~1\postproc\platform.bib
Error PB2505: Error executing #(D:\WINCE420\PUBLIC\THREE\RelDir\MY2410~1\)makeimg.exe.
THREE - 3 error(s), 0 warning(s)
1、BSP包的的名称 要看CEC文件,路径要正确 2、Setting要设置  详情 回复 发表于 2009-12-19 12:52
86
jf,哈哈
577
2、Setting要设置
