3329|1
MakeCode 开始支持 ESP32 和 ESP32-S2了 [复制链接]
微软的图形化编程教育平台MakeCode 开始支持 ESP32 和 ESP32-S2了。
https://github.com/microsoft/pxt-maker/commit/79408a320fd15c3472639fdfbfa80c57ea2f20ff
add support for esp32 and esp32-s2 (#347)
* Add esp32-devkitc
* Docker fix
* Disable device config for now on esp
* Add esp32s2
* Add new esp32s2 compile service
* add jacdac-iot board
* import settings and wifi libs for esp32
* update shims
* enable pins on esp32
* fix pin config
* Remove feather-s2 config (incomplete anyways)
* fix deps
* add missing libs
* bump pxt and pxt-c-p
* Add cards for ESP32 boards
* add missing libs
* Optimised images with calibre/image-actions
* re-generate files
点赞(1) 关注
目前已有两个ESP32开发板了
图形化编程和仿真界面
