3217|8
64Mb PSRAM 的简单驱动 [复制链接]
64Mbit(8兆字节)的PSRAM让人兴奋,虽然速度不是最快,但是却很有用。
游客,如果您要查看本帖隐藏内容请回复
example.py 显示了如何使用它,只需给它一个地址(范围0-8388607)和一个值(范围0-255),就可以将数据从 bytearray 转换为整数。
mb_PSRAM_64Mb_SPI_example.py
Example MicroPython script for 64Mbit SPI PSRAM with RP2040 (Raspberry Pi Pico)
(Should work with other MicroPython-capable devices with hardware of software SPI)
Author: mark@marksbench.com
Version: 0.1, 2021-05-26
**NOTE: There is no guarantee that this software will work in the way you expect (or at all).
**Use at your own risk.
To use:
- Upload the mb_PSRAM_64Mb_SPI.py file to your board (the same location where your MicroPython scripts
  run from, or the /lib folder if applicable).
- Connect the PSRAM to the Pi Pico (RP2040), for testing (and to use this example script
  without modification) I suggest the following:
        PSRAM    |    Pi Pico
        1(/CE)   |    GP1 (Pin 2)
        2(SO)    | GP4, (SPI0 RX, Pin 6)
        3(SIO[2])|      NC
        4(Vss)   |    GND, (Pin 38)
        5(SI)    | GP7, (SPI0 TX, Pin 10)
        6(SCK)   | GP6, (SPI0 SCK, Pin 9)
        7(SIO[3])|      NC
        8(Vcc)   |   3V3 OUT, (Pin 36)
- To write a value: memory.write_byte(address, value)
- To read a value: value = memory.read_byte(address)
- You should get an error if the address or value is out of range.
from machine import Pin, SPI
import mb_PSRAM_64Mb_SPI
# Set up SPI with the pinout arrangement listed above
spi = SPI(0, sck=Pin(6), mosi=Pin(7), miso=Pin(4), polarity=0, phase=0, baudrate=2000000)
# Set a GP pin to use for /CS
cs = 1
# Create constructor to use driver
memory = mb_PSRAM_64Mb_SPI.mb_PSRAM_64Mb_SPI(spi, cs)
# Simple write test. Writing value of 38 to address 8388607 (highest address of this device)
memory.write_byte(8388607, 38)
# Write value 255 to address 0 (lowest address of the 23LC1024)
memory.write_byte(0, 255)
# Simple read test. Read the value from address 131071 and print it
read_value = memory.read_byte(8388607)
print("Retrieved: ", read_value)
# Now read from address 0 and print it
read_value = memory.read_byte(0)
看一下   详情 回复 发表于 2025-1-16 15:54
1942
这个是用的什么芯片?
1411
一般应用在哪里?
没有什么不可以,我就是我,不一样的烟火!
这个好
不错哦,下载下来看看
RP2040就是引脚少了点
回复看看啊
学习学习
78
看一下
