5163|1
121
2608
在STM32程序中添加 printf函数 [复制链接]
前提是你有一个完整的keil工程 比如ADC的
调试的时候很多时候用到串口 这里教你怎么样使用Printf 函数
在程序中添加Printf.txt
1,
#include
2,
/* Private functions ---------------------------------------------------------*/ 下添加
void USART_Configuration(void);
#ifdef __GNUC__
/* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
      set to 'Yes') calls __io_putchar() */
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
3,添加如下2个函数 usart配置 和 重定向 C库的printf函数
void USART_Configuration()
/* USARTx configured as follow:
         - BaudRate = 9600 baud
         - Word Length = 8 Bits
         - One Stop Bit
         - No parity
         - Hardware flow control disabled (RTS and CTS signals)
         - Receive and transmit enabled
USART_InitTypeDef USART_InitStructure;
GPIO_InitTypeDef GPIO_InitStructure;
/* Configure USART1 Tx (PA9) as alternate function push-pull */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* Configure USART1 Rx (PA10) as input floating */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
USART_InitStructure.USART_BaudRate = 9600;
USART_InitStructure.USART_WordLength = USART_WordLength_8b;
USART_InitStructure.USART_StopBits = USART_StopBits_1;
USART_InitStructure.USART_Parity = USART_Parity_No;
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
USART_Init(USART1, &USART_InitStructure);
/* Enable USART1 */
USART_Cmd(USART1, ENABLE);
* @brief Retargets the C library printf function to the USART.
* @param None
* @retval None
PUTCHAR_PROTOTYPE
/* Place your implementation of fputc here */
/* e.g. write a character to the USART */
USART_SendData(USART1, (uint8_t) ch);
/* Loop until the end of transmission */
while (USART_GetFlagStatus(USART1, USART_FLAG_TC) == RESET)
return ch;
4,
void RCC_Configuration(void) 添加
/* Enable GPIOA and USART1 clocks */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_USART1, ENABLE);
5,
STM32F10x.CONF.H
去掉/* #include "stm32f10x_usart.h" */ 的注释
6,
在Main()中添加
然后就可以在main()调用
printf("The is a example!" );
printf("%s%c%c%c%c%c%s",
            Value/256,Value%256,
            Value_2/256,Value_2%256,
之类的输出函数
此帖出自stm32/stm8论坛
printf函数的实现过程也可以自己来写!  详情 回复 发表于 2010-3-4 14:12
2131
至上芯片
此帖出自stm32/stm8论坛
个人签名处处留心皆学问!
有奖探索 | 和村田一起,深挖 GNSS 开发!
活动时间:即日起-5月11日
活动奖励:智能手环、螺丝刀套装、双肩包
