4425|9
82
关于uboot地址重定位 [复制链接]
新手学习uboot,对于地址重定位的问题始终没有搞明白,请高手指点
Q1:start.s最初是在0x0000开始的地址处开始执行,中间有个过程是把自己以及uboot的其他代码搬移到0x3ff8 0000的位置,可是程序是怎么跳转到0x3ff8000处(或者所在的ram中)运行的呢?
以下是start.s的代码,高手能否告知是哪一条指令使pc跳转到ram中的?
#include
#include
* Jump vector table as in table 3.1 in [1]
.globl _start
_start: b      reset
ldr pc, _undefined_instruction
ldr pc, _software_interrupt
ldr pc, _prefetch_abort
ldr pc, _data_abort
ldr pc, _not_used
ldr pc, _irq
ldr pc, _fiq
_undefined_instruction: .word undefined_instruction
_software_interrupt: .word software_interrupt
_prefetch_abort: .word prefetch_abort
_data_abort: .word data_abort
_not_used: .word not_used
_irq: .word irq
_fiq: .word fiq
.balignl 16,0xdeadbeef
* Startup Code (reset vector)
* do important init only if we don't start from memory!
* relocate armboot to ram
* setup stack
* jump to second stage
_TEXT_BASE:
.word TEXT_BASE
.globl _armboot_start
_armboot_start:
.word _start
* These are defined in the board-specific linker script.
.globl _bss_start
_bss_start:
.word __bss_start
.globl _bss_end
_bss_end:
.word _end
#ifdef CONFIG_USE_IRQ
/* IRQ stack memory (calculated at run-time) */
.globl IRQ_STACK_START
IRQ_STACK_START:
.word 0x0badc0de
.globl FIQ_STACK_START
FIQ_STACK_START:
.word 0x0badc0de
#endif
* the actual reset code
reset:
* set the cpu to SVC32 mode
mrs r0,cpsr
bic r0,r0,#0x1f
orr r0,r0,#0xd3
msr cpsr,r0
/* turn off the watchdog */
#if defined(CONFIG_S3C2400)
# define pWTCON 0x15300000
# define INTMSK 0x14400008 /* Interupt-Controller base addresses */
# define CLKDIVN 0x14800014 /* clock divisor register */
#elif defined(CONFIG_S3C2410)
# define pWTCON 0x53000000
# define INTMSK 0x4A000008 /* Interupt-Controller base addresses */
# define INTSUBMSK 0x4A00001C
# define CLKDIVN 0x4C000014 /* clock divisor register */
#endif
#if defined(CONFIG_S3C2400) || defined(CONFIG_S3C2410)
ldr    r0, =pWTCON
mov    r1, #0x0
str    r1, [r0]
* mask all IRQs by setting all bits in the INTMR - default
mov r1, #0xffffffff
ldr r0, =INTMSK
str r1, [r0]
# if defined(CONFIG_S3C2410)
ldr r1, =0x3ff
ldr r0, =INTSUBMSK
str r1, [r0]
# endif
/* FCLK:HCLK:PCLK = 1:2:4 */
/* default FCLK is 120 MHz ! */
ldr r0, =CLKDIVN
mov r1, #3
str r1, [r0]
#endif /* CONFIG_S3C2400 || CONFIG_S3C2410 */
* we do sys-critical inits only at reboot,
* not when booting from ram!
#ifndef CONFIG_SKIP_LOWLEVEL_INIT
bl cpu_init_crit
#endif
#ifndef CONFIG_SKIP_RELOCATE_UBOOT
relocate: /* relocate U-Boot to RAM     */
adr r0, _start /* r0 <- current position of code  */
ldr r1, _TEXT_BASE /* test if we run from flash or RAM */
cmp    r0, r1                  /* don't reloc during debug        */
beq    stack_setup
ldr r2, _armboot_start
ldr r3, _bss_start
sub r2, r3, r2 /* r2 <- size of armboot            */
add r2, r0, r2 /* r2 <- source end address        */
copy_loop:
ldmia r0!, {r3-r10} /* copy from source address [r0]    */
stmia r1!, {r3-r10} /* copy to  target address [r1]    */
cmp r0, r2 /* until source end addreee [r2]    */
ble copy_loop
#endif /* CONFIG_SKIP_RELOCATE_UBOOT */
/* Set up the stack     */
stack_setup:
ldr r0, _TEXT_BASE /* upper 128 KiB: relocated uboot  */
sub r0, r0, #CFG_MALLOC_LEN /* malloc area                      */
sub r0, r0, #CFG_GBL_DATA_SIZE /* bdinfo                        */
sub r0, r0, #(CONFIG_STACKSIZE_IRQ+CONFIG_STACKSIZE_FIQ)
#endif
sub sp, r0, #12 /* leave 3 words for abort-stack    */
clear_bss:
ldr r0, _bss_start /* find start of bss segment        */
ldr r1, _bss_end /* stop here                        */
mov r2, #0x00000000 /* clear                            */
clbss_l:str r2, [r0] /* clear loop...                    */
add r0, r0, #4
cmp r0, r1
ble clbss_l
#if 0
/* try doing this stuff after the relocation */
ldr    r0, =pWTCON
mov    r1, #0x0
str    r1, [r0]
mov r1, #0xffffffff
ldr r0, =INTMR
str r1, [r0]
ldr r0, =CLKDIVN
mov r1, #3
str r1, [r0]
/* END stuff after relocation */
#endif
ldr pc, _start_armboot
_start_armboot: .word start_armboot
uboot的哪个文件使链接的时候函数地址都增加了TEXT_BASE?   详情 回复 发表于 2010-1-17 22:29
有热心高手讲几句么?
83
跳转发生在
start_armboot 的值为TEXT_BASE加上start_armboot的实际偏移值。
完成代码拷贝后,start.S做了一些诸如开启MMU,设置堆栈,清除bss的工作后,就开始执行C语言函数start_armboot. 也正是在这里,完成了向SDRAM的跳转。
mark
期待高手出现
引用 2 楼 dairyman000 的回复:
完成代码拷贝后,start.S做了一些诸如开启MMU,……
赫赫,uboot里可不敢开启mmu,那是kernel自己要做的事情。
65
uboot开启MMU只有愿不愿开启和能不能开启(硬件不支持MMU)的问题,不存在敢不敢开启的问题。
uboot自身完全可以运行在虚拟地址空间,上面提到开启MMU,设置堆栈,清除bss都是针对Uboot而言的。
66
跳转发生在
谢谢,回复
_start_armboot 里的值是_start,编译的时候_start代表值不是0x0000?如果编译的时候 _start =0x0000,那么运行ldr pc, _start_armboot时岂不是跳到0x0了?
希望高手指正
90
引用 6 楼 lucseven 的回复:
跳转发生在
谢谢,回复
希望高手指正
我之前说的不对_start_armboot 里的值是void start_armboot()函数的地址,根据uboot的lds文件看,所有的代码都放在0x000开始的区域。程序怎么回调转到3ff80000左右的地址处运行呢?
这个是因为链接的时候,函数的地址都被增加了TEXT_BASE。你可以在代码中搜索一下TEXT_BASE的值定义为多少,看看就明白了。  这个值往往也就是u-boot被拷贝到内存,内存的起始值。
81
引用 8 楼 dairyman000 的回复:
这个是因为链接的时候,函数的地址都被增加了TEXT_BASE。你可以在代码中搜索一下TEXT_BASE的值定义为多少,看看就明白了。? 这个值往往也就是u-boot被拷贝到内存,内存的起始值。
