上次发了一次贴子 链接
讲如何编译程序,不过没成功,后来讲如何用MicroPython来玩
后来不死心,再试,终于算是成功了
以下分享出过程:
1.先下载SDK,GIT,VS2019 C++工具,GCC编译器,具体方法官方PDF里有,设置系统环境变量,最好为绝对地址,见图:
2.下载 pico-project-generator ,它是一个GUI CMAKE工具,下载后,在其主目录有这个文件 pico_project.py
不能直接执行,需要给个参数,建议在其目录创建一个批处理文件 gui.bat,内容如下:
python pico_project.py --gui
这样以后直接执行 gui.bat即可,界面如下:
3.创建后项目位置后,修改你的程序,我的程序如下:
#include <stdio.h>
#include "pico/stdlib.h"
#include "hardware/uart.h"
#include "hardware/gpio.h"
#include "hardware/divider.h"
// UART defines
// By default the stdout UART is `uart0`, so we will use the second one
#define UART_ID uart1
#define BAUD_RATE 9600
// Use pins 4 and 5 for UART1
// Pins can be changed, see the GPIO function select table in the datasheet for information on GPIO assignments
#define UART_TX_PIN 4
#define UART_RX_PIN 5
// GPIO defines
// Example uses GPIO 2
#define LED 25 //led 引脚
int main()
stdio_init_all();
// Set up our UART
uart_init(UART_ID, BAUD_RATE);
// Set the TX and RX pins by using the function select on the GPIO
// Set datasheet for more information on function select
gpio_set_function(UART_TX_PIN, GPIO_FUNC_UART);
gpio_set_function(UART_RX_PIN, GPIO_FUNC_UART);
// GPIO initialisation.
// We will make this GPIO an input, and pull it up by default
gpio_init(LED);
gpio_set_dir(LED, GPIO_OUT);
gpio_put(LED,1); //打开LED
// Example of using the HW divider. The pico_divider library provides a more user friendly set of APIs
// over the divider (and support for 64 bit divides), and of course by default regular C language integer
// divisions are redirected thru that library, meaning you can just use C level `/` and `%` operators and
// gain the benefits of the fast hardware divider.
int32_t dividend = 123456;
int32_t divisor = -321;
// This is the recommended signed fast divider for general use.
divmod_result_t result = hw_divider_divmod_s32(dividend, divisor);
printf("%d/%d = %d remainder %d\n", dividend, divisor, to_quotient_s32(result), to_remainder_s32(result));
// This is the recommended unsigned fast divider for general use.
int32_t udividend = 123456;
int32_t udivisor = 321;
divmod_result_t uresult = hw_divider_divmod_u32(udividend, udivisor);
printf("%d/%d = %d remainder %d\n", udividend, udivisor, to_quotient_u32(uresult), to_remainder_u32(uresult));
puts("Hello, world!");
return 0;
里边大部分是自动生成的,我只点亮了LED灯,其它没动。
修改程序用VS CODE或记事本均可
LED指示灯是接地GP25上的,见图纸:
4.编译
昨天贴子里经过无数次测试没成功,今天偶然试一个命令竟然可以编译了
官方命令是直接用nmake命令,可我的直接执行不了
然后我用绝对命令,C:\Program Files (x86)\Microsoft Visual Studio\2019\Preview\VC\Tools\MSVC\14.28.29333\bin\HostX64\x64\nmake.exe
仍然报一推错误,后来考虑到要用ARM版的,然后再试 C:\Program Files (x86)\Microsoft Visual Studio\2019\Preview\VC\Tools\MSVC\14.28.29617\bin\Hostx86\x86\nmake.exe
还是不行,偶然在nmake目录看到了一个DLL, C:\Program Files (x86)\Microsoft Visual Studio\2019\Preview\VC\Tools\MSVC\14.28.29333\bin\HostX64\x64\2052\nmakeui.dll
然后我试试加了-ui命令,奇迹出现了,可以编译了,并且成功编译出了elf文件,hex文件,bin都有
说明:至于为什么加了-ui可以,我还没查,等会我找下这个namke的帮助看一下
注意,需要在项目录下下的build目录下执行 ,如 ProjectName\build ,生成好的文件如图:
5.转换
这个目标板只支持uf2文件,准备想用c#自己写一个转换程序,想来还是算了,用官方的,
官方SDK的这个目录下有个工具pico-sdk\tools\elf2uf2,不过只有源代码,
我用VS2019创建了一个C++工程,编译了一次,成功,以下是编译好的EXE,大家可以直接使用
elf转换到uf2.exe ,使用方法 ,命令行输入 elf转换到uf2.exe 原文件.elf 目标文件.uf2
elf转换到uf2.zip
(9.23 KB, 下载次数: 14)
6.下载
这个就比较简单了,上电前按住按钮,再插入USB上电,直接将UF2文件拖入目标盘即可,然后你就会发现LED灯奇迹的变亮了
很神奇吧?
修改原因:补充图片
