3588|2
267
【GD32E503评测03】 5分钟移植好FreeRTOS到GD32E503 [复制链接]
1. 利用MDK5超强大的功能,可以实现FreeRTOS的快速移植。
首先,打开MDK的Pack工具包,勾线FreeRTOS中间件:
到这里后,编译肯定有3个报错,三个函数已经重复定义了:
在 FreeRTOSConfig.h中有如下三个接口的定义:
/* Map the FreeRTOS port interrupt handlers to their CMSIS standard names. */
#define xPortPendSVHandler                    PendSV_Handler
#define vPortSVCHandler                       SVC_Handler
#define xPortSysTickHandler                   SysTick_Handler
在gd32e50x_it.c 需要屏蔽掉这些函数即可。
    \brief      this function handles SVC exception
    \param[in]  none
    \param[out] none
    \retval     none
//void SVC_Handler(void)
    \brief      this function handles DebugMon exception
    \param[in]  none
    \param[out] none
    \retval     none
void DebugMon_Handler(void)
    \brief      this function handles PendSV exception
    \param[in]  none
    \param[out] none
    \retval     none
//void PendSV_Handler(void)
    \brief      this function handles SysTick exception
    \param[in]  none
    \param[out] none
    \retval     none
//void SysTick_Handler(void)
//    delay_decrement();
第三部,添加上我们我们的任务创建函数即可:
#include "systick.h"
#include "gd32e503v_eval.h"
#include "gd32e503v_lcd_eval.h"
#include "bsp_touch.h"
#include "picture.h"
#include <stdio.h>
#include "FreeRTOS.h"
#include "task.h"
#define LED1_TASK_PRIO    ( tskIDLE_PRIORITY + 2 )
void LED1_task(void * pvParameters);
static void led_init(void)
    /* initialize the leds */
    gd_eval_led_init(LED1);
    gd_eval_led_init(LED2);
    gd_eval_led_init(LED3);
    gd_eval_led_init(LED4);
    /* close all of leds */
    gd_eval_led_off(LED1);
    gd_eval_led_off(LED2);
    gd_eval_led_off(LED3);
    gd_eval_led_off(LED4);
    \brief      main function
    \param[in]  none
    \param[out] none
    \retval     none
int main(void)
    //systick_config();
	led_init();
	 /* configure EVAL_COM0 */
    gd_eval_com_init(EVAL_COM0);
    /* configure TAMPER key */
    gd_eval_key_init(KEY_B, KEY_MODE_GPIO);
	printf("\r\nHello,eeworld!");
    /* configure the GPIO of SPI touch panel */
    touch_panel_gpio_configure();
    //delay_1ms(50);
	/* configure the EXMC access mode */
    exmc_lcd_init();
    /* initialize the LCD */
    lcd_init();
    /* clear the LCD screen */
    lcd_clear(LCD_COLOR_WHITE);
	uint8_t len_s;
	char *str;
	uint16_t i;
	char_format_struct char_format;
	char error_string[]="Hello,EEWORLD!";
    /* draw character on LCD screen */
    len_s = sizeof(error_string)-1;
    str = error_string;
// 	/* configure char format */
//    char_format.char_color = LCD_COLOR_RED;
//    char_format.bk_color = LCD_COLOR_WHITE;
//    char_format.direction = CHAR_DIRECTION_VERTICAL;
//    char_format.font = CHAR_FONT_8_16;
//    for (i = 0; i < len_s; i++)
//        lcd_char_display((8*i), 100 + 24, *str++, char_format);
    char_format.char_color = LCD_COLOR_BLUE;
    char_format.font = CHAR_FONT_16_24;
        lcd_char_display((16*i), 10, *str++, char_format);
	/* 设置优先级分组为4,16个优先级全是抢占优先级 */
    nvic_priority_group_set(NVIC_PRIGROUP_PRE4_SUB0);
	xTaskCreate(LED1_task, "LED1", configMINIMAL_STACK_SIZE, NULL, LED1_TASK_PRIO, NULL);
	/* start scheduler */
    vTaskStartScheduler();
    while(1){
    for( ;; ){
        /* toggle LED2 each 500ms */
        gd_eval_led_toggle(LED1);;
        vTaskDelay(100);
最后编译OK,下载运行,LED开始闪烁,OS已经运行起来了!
是不是很简单,没有复杂的 各种文件的添加到工程等等。
欢迎多多交流~
厉害了!移植真的快,刘辟刘辟,到时候我也试一下!嘿嘿   详情 回复 发表于 2021-1-20 15:19
赞赏
查看全部赞赏
点赞(1) 关注(1)
gitee/casy
1942
多多交流,一起学习进步  详情 回复 发表于 2021-1-21 08:56
267
w494143467 发表于 2021-1-20 15:19 厉害了!移植真的快,刘辟刘辟,到时候我也试一下!嘿嘿
多多交流,一起学习进步
gitee/casy
