0x81fff030: Did not find emulation code for x86... using floating point
hardware.
This occurs on the x86, as there are some versions of the i486 architecture that do not include the floating-point co-processor. The system will check for the presence of the FPEMUL library. (You can specify that your BSP uses one of these CPUs by setting BSP_FPEMUL=1.) All code on an x86 is written assuming the presence of the co-processor. In a case where there isn't one, the instructions cause a trap in the kernel, which then calls the emulation library to implement the floating-point calculations. This message simply informs you that the kernel did not find the emulation library and therefore is using the hardware co-processor. If your CPU doesn't have the co-processor, this would be an important message to look for if your fonts are not showing up in the Microsoft? Internet Explorer shell (or other applications).
引用 10 楼 amorous 的回复:
? hardware.
