2826|5
64
can I use file system filter driver in windows ce 4 and above [复制链接]
I wrote a file system filter driver under xp using ifs 2003, don't know if can copy that to windows ce 4 and above?
some xp's api function can't work well in wince system.but some can. So you should  modify your source somewhere.   详情 回复 发表于 2010-4-24 23:37
79
up
84
平台不一样,呵呵
it's no problem maybe
ok, thanks, all brothers
67
