3427|2
关天fseek(fp_Write, 0L, SEEK_END);指向文件未尾应用 [复制链接]
bool SaveToBookMark3(char* pBookMarkTitle, char* pUrl )
        //char FullPath[256] = {"\\Windows\\收藏夹\\"};
        char FullPath[256] = {"\\Windows\\Opera9\\Opera6.adr"};
        //strcat((char*)FullPath , pBookMarkTitle);
        char BookmarkPrex[32] = {"[InternetShortcut]"};
        char CReturn[4] = {"\r\n"};
        char CUrlHeader[8] = {"URL="};
        FILE *fp_Write;
        fp_Write =fopen(FullPath, "w+");
        if (!fp_Write)
                return false;
        ////line 1:
        fwrite(BookmarkPrex, sizeof(char), strlen(BookmarkPrex), fp_Write);
        fwrite(CReturn, sizeof(char), strlen(CReturn), fp_Write);
        //line 2:
        fwrite(CUrlHeader, sizeof(char), strlen(CUrlHeader), fp_Write);
        fwrite(pUrl, sizeof(char), strlen(pUrl), fp_Write);
        //line 3:
        fclose(fp_Write);
        return true;
这样写为什么每次都把以前的内容覆盖了?fseek(fp_Write, 0L, SEEK_END);不能让指针指向文件未尾吗?
该为: FILE *fp_Write; fp_Write =fopen(FullPath, "a+"); if (!fp_Write) { return false; } 复制代码  详情 回复 发表于 2009-4-29 17:36
不知道你写完fwrite指针会不会移动要不你在每次fwrite之后再加一句fseek
82
该为:
  1. FILE *fp_Write;
  2. fp_Write =fopen(FullPath, "a+");
  3. if (!fp_Write)
  4. {
  5. return false;
  6. }
复制代码
