1754|0
1717
MSP430设置主时钟源、主时钟源和辅助时钟源 [复制链接]
        时钟图
设置主时钟源
*  函数名称:CLOCK_MCLK_Config  (CLOCK_Source mclk , CLOCK_DIVx mclk_div)
*  功能说明:设置主时钟源及分频
*  参数说明:CLOCK_Source mclk   :主时钟时钟源
             CLOCK_DIVx mclk_div :主时钟分频系数
*  函数返回:无
*  使用示例:CLOCK_MCLK_Config  (CLOCK_DCO , DIV_1);   //主时钟使用DCO作为时钟源,分频系数为1(不分频)
void CLOCK_MCLK_Config  (CLOCK_Source mclk , CLOCK_DIVx mclk_div)
  if(mclk == CLOCK_XT2)
    XT2_Config(TRUE);
  else if(mclk == CLOCK_XT1)
    XT1_Config(TRUE);
  UCS->SELM = mclk;                         //选择DCO作为时钟源
  UCS->DIVM = mclk_div;
  switch(mclk)
  case CLOCK_XT1    :g_sClock.MCLK.nHZ = EXTAL_IN_XT1_HZ;break;
  case CLOCK_VLO    :g_sClock.MCLK.nHZ = VLOCLK_FREQUENCY;break;
  case CLOCK_REFO   :g_sClock.MCLK.nHZ = REFOCLK_FREQUENCY;break;
  case CLOCK_DCO    :g_sClock.MCLK.nHZ = g_sClock.DCO_FLL_Frequency;break;
  case CLOCK_DCO_DIV:g_sClock.MCLK.nHZ = g_sClock.DCO_FLL_Frequency;break;
  case CLOCK_XT2    :g_sClock.MCLK.nHZ = EXTAL_IN_XT2_HZ;break;
  default :return;
  g_sClock.MCLK.nHZ  >>= mclk_div;
  g_sClock.MCLK.nKHZ = g_sClock.MCLK.nHZ/1000u;
  g_sClock.MCLK.fMHZ = g_sClock.MCLK.nHZ/1000000.0;
3.2 设置系统时钟源
*  函数名称:CLOCK_SMCLK_Config (CLOCK_Source smclk, CLOCK_DIVx smclk_div)
*  功能说明:设置系统时钟源及分频
*  参数说明:CLOCK_Source smclk   :系统时钟时钟源
             CLOCK_DIVx smclk_div :系统时钟分频系数
*  函数返回:无
*  使用示例:CLOCK_SMCLK_Config  (CLOCK_DCO , DIV_2);   //系统时钟使用DCO作为时钟源,分频系数为2(二分频)
void CLOCK_SMCLK_Config (CLOCK_Source smclk, CLOCK_DIVx smclk_div)
  if(smclk == CLOCK_XT2)
    XT2_Config(TRUE);
  else if(smclk == CLOCK_XT1)
    XT1_Config(TRUE);
  UCS->SELS = smclk;//选择smclk时钟源
  UCS->DIVS = smclk_div;
  switch(smclk)
  case CLOCK_XT1    :g_sClock.SMCLK.nHZ = EXTAL_IN_XT1_HZ;break;
  case CLOCK_VLO    :g_sClock.SMCLK.nHZ = VLOCLK_FREQUENCY;break;
  case CLOCK_REFO   :g_sClock.SMCLK.nHZ = REFOCLK_FREQUENCY;break;
  case CLOCK_DCO    :g_sClock.SMCLK.nHZ = g_sClock.DCO_FLL_Frequency;break;
  case CLOCK_DCO_DIV:g_sClock.SMCLK.nHZ = g_sClock.DCO_FLL_Frequency;break;
  case CLOCK_XT2    :g_sClock.SMCLK.nHZ = EXTAL_IN_XT2_HZ;break;
  default :return;
  g_sClock.SMCLK.nHZ >>= smclk_div;
  g_sClock.SMCLK.nKHZ = g_sClock.SMCLK.nHZ/1000u;;
  g_sClock.SMCLK.fMHZ = g_sClock.SMCLK.nHZ/1000000.0;
3.3 设置辅助时钟源
*  函数名称:CLOCK_ACLK_Config  (CLOCK_Source aclk , CLOCK_DIVx aclk_div)
*  功能说明:设置辅助时钟源及分频
*  参数说明:CLOCK_Source aclk   :辅助时钟时钟源
             CLOCK_DIVx aclk_div :辅助时钟分频系数
*  函数返回:无
*  使用示例:CLOCK_ACLK_Config  (XT! , DIV_4);   //辅助时钟使用XT1作为时钟源,分频系数为4(四分频)
void CLOCK_ACLK_Config  (CLOCK_Source aclk , CLOCK_DIVx aclk_div)
   if(aclk == CLOCK_XT2)
    XT2_Config(TRUE);
  else if(aclk == CLOCK_XT1)
    XT1_Config(TRUE);
  UCS->SELA = aclk;//选择时钟源
  UCS->DIVA = aclk_div; //设置分频系数为0
  switch(aclk)
  case CLOCK_XT1    :g_sClock.ACLK.nHZ = EXTAL_IN_XT1_HZ;break;
  case CLOCK_VLO    :g_sClock.ACLK.nHZ = VLOCLK_FREQUENCY;break;
  case CLOCK_REFO   :g_sClock.ACLK.nHZ = REFOCLK_FREQUENCY;break;
  case CLOCK_DCO    :g_sClock.ACLK.nHZ = g_sClock.DCO_FLL_Frequency;break;
  case CLOCK_DCO_DIV:g_sClock.ACLK.nHZ = g_sClock.DCO_FLL_Frequency;break;
  case CLOCK_XT2    :g_sClock.ACLK.nHZ = EXTAL_IN_XT2_HZ;break;
  default :return;
  g_sClock.ACLK.nHZ >>= aclk_div;
  g_sClock.ACLK.nKHZ = g_sClock.ACLK.nHZ/1000u;;
  g_sClock.ACLK.fMHZ = g_sClock.ACLK.nHZ/1000000.0;
4.更改时钟来源操作
具体路径请改变msp430f5529_system.h里面的宏定义修改时钟源及时钟分频
//宏定义初始化时钟频率及时钟源
#define FLL_REF         FLLREF_REFO     //FLL参考时钟源
#define FLLREF_DIV      FLLREF_DIV_1    //FLL参考时钟分频系数
#define DCO_CLK_HZ      25MHZ            //DCO时钟频率
//主时钟设置
#define MCLK_SOURCE     CLOCK_DCO       //主时钟时钟源
#define MCLK_DIV        CLOCK_DIV_1     //主时钟时钟分频系数
//系统时钟设置
#define SMCLK_SOURCE    CLOCK_XT2       //系统时钟时钟源
#define SMCLK_DIV       CLOCK_DIV_1     //系统时钟分频系数
//辅助时钟设置
#define ACLK_SOURCE     CLOCK_REFO      //辅助时钟时钟源
#define ACLK_DIV        CLOCK_DIV_1     //辅助时钟分频系数
直播时间:3月12日(周三)上午10:00
直播奖励:多功能榨汁机、蓝牙音箱、手机支架
