5692|22
nand flash读写求助 [复制链接]
希望有人能够指点下
         情况1:
             FlashReset();
                   state = FlashReadStatus();   //结果是state = 0xe0;
                   flashid = FlashReadId();        //结果是flashid = 0xe0e0;
         情况2:
             FlashReset();
                   flashid = FlashReadId();        //结果是flashid = ad76
                   state = FlashReadStatus();   //结果是state = 0xad;
         情况3:
             FlashReset();
                   FlashReset();
                   flashid = FlashReadId();        //结果是flashid = 0xad76;
                  正确的,先读哪个都正确。
         情况4:
             FlashReset();
                   FlashReadPage(0,readbuf);   //结果是readbuf为e0e0e0...,
                   FlashReset();
                   FlashReadPage(0,readbuf);   //结果是readbuf为ad76ad76ad76...,
         情况5:
          FlashReset();
                   FlashReset();
                   FlashReadPage(0,readbuf);   //结果是readbuf为f0ffffffffff...,
         情况6:
            unsigned char FlashReadStatus(void)
                   unsigned char status = 0x00;
                   CE = 0;
                   //如果在这里再加一个FlashWriteCmd(任意命令);那读之前不要先写复位命令FlashReset();也可以得到与写了FlashReset();一样的结果,其他如FlashReadId();FlashReadPage(0,readbuf);也一样。
                   FlashWriteCmd(NAND_READSTATUS);
                   status = FlashDataRead();
                   CE = 1;
                   return status;
到底是咋回事呢,看了hy27us08121a数据手册上的读写时序及读写过程,感觉上面程序没啥问题啊,不知道有没忽略掉什么,很不解,知道的能不能提点建议啊,谢过先。。
ls有理,顶一下  详情 回复 发表于 2010-1-27 23:46
57
用的HY27US08121A程序如下,有啥问题呢
void FlashWriteCmd(unsigned char cmd)
CLE = 1;
ALE = 0;
RE = 1;
WE = 0;
DataPort = cmd;
WE = 1;
void FlashWriteAddr(unsigned char addr)
CLE = 0;
ALE = 1;
RE = 1;
WE = 0;
DataPort = addr;
WE = 1;
void FlashDataWrite(unsigned char dat)
CLE = 0;
ALE = 0;
RE = 1;
WE = 0;
DataPort = dat;
WE = 1;
unsigned char FlashDataRead(void)
unsigned char dat;
DataPort = 0xFF;
CLE = 0;
ALE = 0;
WE = 1;
RE = 1;
RE = 0;
dat = DataPort;
RE = 1;
return dat;
void FlashReset(void)
CE = 0;
FlashWriteCmd(NAND_RST);
_nop_();
NAND_WAITREADY
CE = 1;
unsigned int FlashReadId(void)
unsigned int deviceId = 0x0000;
CE = 0;
FlashWriteCmd(NAND_READ_ID);
FlashWriteAddr(0x00);
deviceId  = FlashDataRead();
deviceId  = deviceId << 8;
deviceId |= FlashDataRead();
CE =1;
return   deviceId;
CE = 0;
CE = 1;
return status;
unsigned char FlashEraseBlock(unsigned int blockAddr)
CE = 0;
FlashWriteCmd(NAND_READ0);
FlashWriteCmd(NAND_BLOCKERASE_C1);
FlashWriteAddr(blockAddr & 0xFF);
FlashWriteAddr((blockAddr >> 8) & 0xFF);
FlashWriteCmd(NAND_BLOCKERASE_C2);
_nop_();
NAND_WAITREADY
status = 0x01 & (FlashReadStatus());
CE = 1;
return  status;
void FlashReadPage(unsigned long PageAddr,unsigned char * buf)
unsigned int i;
CE = 0;
FlashWriteAddr(PageAddr & 0xFF);
FlashWriteAddr((PageAddr >> 8) & 0xFF);
FlashWriteAddr((PageAddr >> 16) & 0xFF);
_nop_();
NAND_WAITREADY
for(i = 0;i < NAND_PAGE_SIZE;i++)
  buf = FlashDataRead();
CE = 1;
unsigned char FlashWritePage(unsigned long PageAddr,unsigned char * buf)
unsigned int i;
CE = 0;
FlashWriteCmd(NAND_PAGE_PROG_C1);
  FlashDataWrite(buf);
FlashWriteCmd(NAND_PAGE_PROG_C2);
_nop_();
NAND_WAITREADY
CE = 1;
return  status;
75
帮顶下。
MARK.
78
估计你还是要看看FLASH的DATASHEET,看看时序有没有问题。
86
你的读和写寄出函数用了程序控制口线的方式选择ALE,CS,RD,WR等信号,这样,对NAND FLASH的读写严重依赖于你所使用的CPU时钟频率,易导致时序不匹配。建议根据Datasheet 和CPU的口线输出频率查找原因。
55
可是我读的FLASH ID和STATUS的值是正确的啊。。
时序我都看了好多遍了,也加了延时等,结果都一样,好郁闷啊。。
flash速度都是纳秒级的
C8051F CPU 系统时钟24MHz执行一条指令都不止了啊
89
肯定是这个问题啦!
NAND Flash还有和状态脚R/B,即Ready/Busy,在写一个命令后,一定要查看R/B,等他Ready,即完成当前命令,再进行下一个动作。在你的Flash的dataSheet中的时序途中一定有这个描述的,但在你的代码中,没看到这个步骤?
67
刚才错别字太多!
肯定是这个问题啦!
NAND Flash还有个状态脚R/B,即Ready/Busy,在写一个命令后,一定要查看R/B,等他Ready,即完成当前命令,再进行下一个动作。Flash的dataSheet中的时序图中一定有这个描述的,但在你的代码中,没看到这个步骤?
92
引用 8 楼 yangcuncunzhang 的回复:
刚才错别字太多!
肯定是这个问题啦!
有等待延时啊是这个宏定义
#define NAND_WAITREADY  {while(RB == 0);}
我把时钟改为12MHz后
state = FlashReadStatus();//结果是state = 0xE0;
flashid = FlashReadId();//结果是flashid = 0xAD76;
是正确的
但读写还是有问题,继续求助
state = FlashEraseBlock(0);
writebuf = i;
state = FlashWritePage(0,writebuf);
readbuf结果总是FEFFFFFFFFFFF.....
84
引用 9 楼 sytu_chyq 的回复:
刚才错别字太多!
肯定是这个问题啦!
有等待延时啊是这个宏定义
#define NAND_WAITREADY? {while(RB == 0);}
但是你的代码不是这样啊,例如你的读ID函数
CE = 0;
deviceId  = deviceId < < 8;
CE =1;
return  deviceId;
FlashWriteCmd(NAND_READ_ID);之后没有等待Ready啊?
FlashWriteAddr(0x00); 之后也没有啊?
你看看DataSheet,是不是每个命令后都要等待完成的啊。
引用 11 楼 yangcuncunzhang 的回复:
刚才错别字太多!
肯定是这个问题啦!
有等待延时啊是这个宏定义
CE = 0;? ? ? ? ? ?
deviceId? = FlashDataRead();
deviceId? = deviceId < < 8;
CE =1;
return? deviceId;
不是啊,只有块擦除(2ms)、页读取(...)及页写入(...)才有的啊
引用 12 楼 sytu_chyq 的回复:
刚才错别字太多!
肯定是这个问题啦!
有等待延时啊是这个宏定义
CE = 0;? ? ? ? ? ?
CE =1;
return? deviceId;
如果你用的Flash的资料上,只有这几个地方有,那你照着做就是对的。
可能是其他方面的问题
66
你把你用的Flash的资料也传上来,一起看看!
77
引用 14 楼 yangcuncunzhang 的回复:
好的,谢谢,附件怎么传呢
还有我发现把系统频率再改小为6M
10楼情况结果为00 00 02 02 04 04.。。fe fe只读偶数
改小为3M结果为00 01 02 03 04.。。是对的
这咋回事呢
引用 15 楼 sytu_chyq 的回复:
好的,谢谢,附件怎么传呢
还有我发现把系统频率再改小为6M
这咋回事呢
我也不知道怎么直接在帖子里贴附件,图片我也不会,因此我都是在eeworld空间的相册中上传图片,在这里贴个链接。至于其他文件,在资源区上传,然后在这里贴链接。、
75
引用 16 楼 yangcuncunzhang 的回复:
手册已上传,谢谢
http://download.eeworld.net/source/2021921
现在有点建议:
1、先调试FlashReadPage(),你在10楼说读的结果是0xFEFFFFFF.....,说明读取结果不正确。但到底是读失败了呢?还是写错误了?因此,你先调试读函数,因为Erase函数比较好做,你做好Erase函数,然后来验证Read函数。等读函数做好了再调试写的。因为要先写进去,再读出来验证嘛。
2、在调试FlashEraseBlock(),FlashReadPage()和FlashWritePage()时,操作完成都有Status,你看看状态值都是什么,有没有操作成功。
我之前用过很多Nand Flash,最早Sharp的,Toashiba的,后来Samsung的,现在也用Hynix的(现在用HY27UF081g2A),基本上没什么难度。
如果连基本的读状态、Erase都返回错误状态的话,看是不是检查一下有些宏的定义、命令值的定义,看有没有出错的????
你先试试,我再看看资料
引用 18 楼 yangcuncunzhang 的回复:
现在有点建议:
你先试试,我再看看资料
关键是我现在把系统频率降下来了已经是对的啊,你看看我前面的回复,帮解释下什么情况,谢了。。
另:FlashEraseBlock(),有误
立即报名 | 2025 瑞萨电子工业以太网技术日即将开启!
预报从速,好礼等您拿~
