2846|2
64
麻烦各位帮我看一看我的程序哪里有问题,拜托了,我是新手阿 [复制链接]
#include
#define TIMER0H 0xD8
#define TIMER0L 0XF0
#define  uchar unsigned char
#define  ON   0
#define  OFF  1
TableLED[]={0X3F,0X06,0X5B,0X4F,0X66,0X6D,0X7D,0X07,0X7F,0X6F};
sbit  L0= P1^0;
sbit  L1= P1^1;
sbit  L2 =P1^2;
sbit  L3 =P1^3;
sbit  L4 =P1^4;
sbit  KEY_UP= P1^5;
sbit  KEY_DW= P1^6;
sbit  KEY_ST= P1^7;
sbit  KEY_T2=P3^2;
sbit  KEY_T3=P3^3;
uchar code
uchar preSet;
uchar Index;
uchar buff[2];
uchar flag;
uchar time,T,J;
uchar pps;
uchar sec;
uchar sec05;
uchar s;
uchar flag_run;
uchar time1,time2,time3;
void InitDevice(void);
void SetLED(void);
void Reload(void);
void OnRunning(void);
void Delay(uchar u);
void OnSetting(void);
main()
        InitDevice();
        time1=10;
        time2=20;
        time3=6;
        time=0;
        T=0;
        flag = 0x00;
        sec = 0;
        s = 0;
        sec05 = 0;
        Reload();
    L0=ON;
    L1=OFF;
        L2=OFF;
        L3=ON;
        L4=OFF;
        flag_run = 1;
        while(1)
                if(KEY_ST==1)
                        OnRunning();
                else
                        OnSetting();
        Delay(4);
        while(!KEY_ST);
        flag_run = 0;
        while(1)
                if ( !KEY_UP)
                        Delay(4);
                        while(!KEY_UP);
                    time1++;
                        time2++;
                        time3++;
                        if(time1>99) time1=1;
                        if(time2>99) time2=1;
                        if(time3>99) time3=1;
                        Reload();
                        SetLED();
                if ( !KEY_DW)
                        Delay(4);
                        while(!KEY_DW);
                    time1--;
                        time2--;
                        time3--;
                        if (time1<0)time1=99;
                        if (time2<0)time2=99;
                        if (time3<0)time3=99;
                        Reload();
                        SetLED();
                if ( !KEY_ST )
                        Delay(4);
                        while(!KEY_ST);
                        flag_run = 1;
                        return;
void Delay(uchar u)
{int i;
        while(u--)
                i = 1000;
                while(i--);
   if(flag)
    flag=0;
    SetLED();
   if(T>time1+time2+time3*60)
    return;
   else if(T>=(time1+time2))
     if(sec05==2)
        L1=OFF;
        L2=ON;
        L4=ON;
        L3=OFF;
        J=0x04;
   else if(T>time1)
      if(sec05==1)
      L0=OFF;
      L1=ON;
      J=0x02;
      L3=ON;
   else
     if(sec05==0)
     L0=ON;
         J=0x01;
         L3=ON;
void SetLED(void)
   if(sec>100)
     buff[0]=sec/600;
         buff[1]=sec/60-buff[0]*10;
   else
     buff[0]=sec/10;
         buff[1]=sec-buff[0]*10;
void Reload(void)
     return;
    sec=time3*60;
     return;
        else if(T>=time1)
          sec=time2;
          return;
         else
          sec=time1;
          return;
void Timer0_Interruput(void) interrupt 1
        TR0 = 0;
        TH0 = TIMER0H;
        TL0 = TIMER0L;
        TR0 = 1;
        time++;
        if(time==100)
                T=T+1;
Index++;
        Index &=0x01;
        P0 = TableLED[buff[Index]];
        switch ( Index )
                case  0 :
                        P2 = 0X80 |J;
                        break;
                case  1 :
                        P2 = 0X40 |J;
                        break;
        pps ++;
        if ( !flag_run) return;
        if ( pps == 50 )
                pps = 0;
                sec05 ++;
                flag = 1;
                if ( sec05 == 3)
                        sec05 = 0;
                        sec -- ;
                        if (sec==0 )
                                Reload();
                        s = -s;
        Index = 0;
        pps = 0;
        TH0  = TIMER0H;
        TL0  = TIMER0L;
    TMOD = 0X01;
    TR0 = 1;
        ET0 = 1;
        EA        = 1;
keil中提示的错误是 syntax error near 'unsigned'
居然没分。。。  详情 回复 发表于 2009-5-14 11:23
81
第18行是啥啊,uchar code ???
没写完?
你要在代码区定义常量?
你要定义名字为code的变量?code是关键字,不能作为变量名
42
居然没分。。。
中星联华&ADI明日直播
直播主题:大咖面对面,轻松玩转高速ADC性能测试
直播时间:3月25日(周二)14:00
活动奖励:京东卡、双肩包
