4191|10
616
出售-ATMEL STK600 开发套件-全新未开封 [复制链接]
都没有开封的,套件带一块mege2560扩展板,套件大概就这些东西。 官方199美元,考虑1000左右出回去拍个实物图,这个是网上的照片哈~
下面为官方资料
Starter kits
Atmel STK600 (ATSTK600)
SKU: ATSTK600
The STK600 is a complete starter kit and development system for the AVR flash microcontrollers. It is designed to give designers a quick start to develop code on the AVR, combined with advanced features for using the starter kit to prototype and test new designs.
In store: 10+
$199
Quantity:
[url=][/url]
[url=]Supported Devices[/url]
[url=]Related Document[/url]
[url=]What's in the Box[/url]
[url=]Related Tools[/url]
Routing cards and socket cards for your specific device must be bought separately. Select your routing card and socket card by using the Store Search and select device
The STK600 is a complete starter kit and development system for the AVR flash microcontrollers from ATMEL® Corporation. It is designed to give designers a quick start to develop code on the AVR, combined with advanced features for using the starter kit to prototype and test new designs.
  • AVR Studio 4/AVR32 Studio compatible
  • USB Interface to PC for programming and control
  • Powered from USB bus or from an external 10-15V DC power supply
  • Adjustable target VCC (0-5.5V)
  • Two adjustable reference voltages with high accuracy. (0-5.0V, 10mV res)
  • Clock oscillator, adjustable on the fly from AVRStudio (0-50MHz, 0.1% res)
  • Serial In-System Programming (ISP) of tinyAVR and megaAVR devices
  • PDI Programming of XMEGA devices
  • JTAG programming of 8-bit megaAVR, 8/16-bit AVR XMEGA and 32-bit AVR UC3 devices
  • aWire Programming of 32-bit AVR UC3 devices
  • ISP and JTAG programming of AVR devices in external target systems
  • Flexible routing and socket card system for easy mounting of all supported devices
  • 8 push-buttons for general use
  • 8 LEDs for general use
  • All AVR I/O ports easily accessible through pin header connectors
  • Expansion connectors for plug-in modules and prototyping area
  • On-board 2Mbit Dataflash for non-volatile data
  • USB mini-AB (On-The-Go) connector for AVR devices with USB
  • PHY and DSUB-9 connetor for RS232 interface
  • PHY and DSUB-9 connector for CAN bus
  • PHY and header for LIN bus
  • Device board with an ATmega2560 AVR microcontroller is included.
The STK600 supports the whole range of AVR microcontrollers, from the smallest 6-pin 8-bit tinyAVR up to the large 144-pin 32-bit AVR UC3 devices.
The AVR device is connected to the STK600 using an innovative routing and socketcard sandwich system, which routes the signals from the device to the appropriate hardware.
The system consists of a generic socketcard, on which the AVR device is inserted, and a device specific signal routing card, which routes the signals from the socket pins to the different functions on the STK600 main board dependant on the device.
The system simplifies the hardware setup when switching from one AVR device to another, since all connections from the device to the motherboard is determined by the routingcard, which is a custom board for each device. The routing system is purely passive, i.e. no electronic components are used to route the signals, and hence all I/O pins are directly accessible on the connectors with no altering of the electrical behavior.
With access to all device pins, and several useful hardware functions that can be connected, such as pushbuttons, LEDs, dataflash, etc, the kit provides a complete system to prototype and test new designs.
With the free AVR Studio the user can write and compile firmware in either assembly or C language, and download the code to the target AVR device.
The board also has adjustable voltage supply and adjustable clock to the target AVR device. The VCC level and clock frequency can be adjusted on the fly from AVR Studio, and gives the designer the ability to test the performance at different voltage levels and clock frequencies with just the click of a button.Starter kits
此帖出自淘e淘论坛
喜欢,帮顶  详情 回复 发表于 2014-10-24 17:27
616
全部大图,点击可以查看细节。板子未开封,封条还粘着的,有意联系报价~
此帖出自淘e淘论坛
800有人要吗~  详情 回复 发表于 2014-10-4 22:05
赞赏
查看全部赞赏
怎么那么大啊????
此帖出自淘e淘论坛
这个类似于一个平台,可以连接atmel的avr系列芯片8bit 到32bit ,一个基础版。为了适应不同芯片所以比较大哇  详情 回复 发表于 2014-7-27 21:47
616
ddllxxrr 发表于 2014-7-27 21:35
怎么那么大啊????
此帖出自淘e淘论坛
423
太贵啊
此帖出自淘e淘论坛
报个价~,谁买了吧~  详情 回复 发表于 2014-7-28 15:29
616
报个价~,谁买了吧~
此帖出自淘e淘论坛
616
没有人出来看看么~ ,不买也看个热闹啊
此帖出自淘e淘论坛
2856
260
挺贵的
此帖出自淘e淘论坛
打个9折  详情 回复 发表于 2014-7-30 22:37
616
打个9折
此帖出自淘e淘论坛
616
800有人要吗~
此帖出自淘e淘论坛
180
喜欢,帮顶
此帖出自淘e淘论坛
