1706|0
1704
MSP430时钟倍频设置 亲测 MSP430F5529有效 [复制链接]
void initClock()
     UCSCTL6 &= ~XT1OFF; //启动XT1
     P5SEL |= BIT2 + BIT3; //XT2引脚功能选择
     UCSCTL6 &= ~XT2OFF;          //打开XT2
//      PMMCTL0 |=PMMPW+ PMMCOREV_3;
      PMMCTL0_H = 0xA5;                                         //开PMM电源管理
      SVSMLCTL |= SVSMLRRL_1 + SVMLE;                            //配置SVML电压
      PMMCTL0 =  PMMPW + PMMCOREV_2;                             //配置内核电压
      while((PMMIFG & SVSMLDLYIFG ) == 0);                       //等待设置完成
      PMMIFG &= ~(SVMLVLRIFG + SVMLIFG + SVSMLDLYIFG);
      if((PMMIFG & SVMLIFG) == 1)                                //判断内核电压是否上升到VSVML
            while((PMMIFG & SVMLVLRIFG) == 0);                   //如果没有等待
      SVSMLCTL &= ~SVMLE;                                        //关掉SVML模块
      PMMCTL0_H = 0X00;                                          //锁存配置
     __bis_SR_register(SCG0);
     UCSCTL0 = DCO0+DCO1+DCO2+DCO3+DCO4; //选择DCO频率区域
     UCSCTL1 = DCORSEL_5;       //DCO频率范围在28.2MHZ以下
     UCSCTL2 = FLLD_4 + 2;       //D=16,N=1    16*2*(4/8)=16
     UCSCTL3 = SELREF_5 + FLLREFDIV_3;    //n=8,FLLREFCLK时钟源为XT2CLK;DCOCLK=D*(N+1)*(FLLREFCLK/n);DCOCLKDIV=(N+1)*(FLLREFCLK/n);
     UCSCTL4 = SELA_4 + SELS_3 +SELM_3;    //ACLK的时钟源为DCOCLKDIV,MCLK\SMCLK的时钟源为DCOCLK
     UCSCTL5 = DIVA_5 +DIVS_1;      //ACLK由DCOCLKDIV的32分频得到,SMCLK由DCOCLK的2分频得到
                 //最终MCLK:24MHZ,SMCLK:12MHZ,ACLK:48KHZ
     __bic_SR_register(SCG0);                   //Enable the FLL control loop
void initClock()
     UCSCTL1 = DCORSEL_4;       //DCO频率范围在28.2MHZ以下
     UCSCTL2 = FLLD_4 +1;       //D=16,N=1    16*2*(4/8)=16
                 //最终MCLK:16MHZ,SMCLK:8MHZ,ACLK:32KHZ
void initClock()
     UCSCTL2 = FLLD_4 + 1;       //D=16,N=1
     UCSCTL5 = DIVA_5 +DIVS_4;      //ACLK由DCOCLKDIV的32分频得到,SMCLK由DCOCLK的2分频得到
                 //最终MCLK:16MHZ,SMCLK:1MHZ,ACLK:32KHZ
