2515|0
67
紧急!!SIM300DZ 模块对AT指令返回错误信息 在线等 [复制链接]
我开发的平台是S3c2410,我想在嵌入式linux下实现GPRS上网,使用pppd call GPRS方式,SIM300DZ模块使用的是3脚串口,模块开机后向其拨打电话可以接通,但是执行pppd call GPRS,执行到send(AT)EXpect(OK)时,串口返回的是“%lee”这是怎么回事啊?请各位朋友指教啊!
gprs脚本:
# /etc/ppp/gprs
receive-all
# Give some debug info
debug
kdebug 7
dump
/dev/ttyS2
4800
# Turn off waiting of carrier detect or flow control signal
# With IrDA it should be disabled with nocrtscts option.
nocrtscts # serial cable
local
# To keep pppd on the terminal
nodetach
# Accept the peer's idea of our local IP address
ipcp-accept-local
# Accept the peer's idea of its (remote) IP address
ipcp-accept-remote
# IP addresses:
# - accept peers idea of our local address and set address peer as 10.0.0.1
# (any address would do, since IPCP gives 0.0.0.0 to it)
# - if you use the 10. network at home or something and pppd rejects it,
# change the address to something else
0.0.0.0:0.0.0.0
-chap
#-pap
# pppd must not propose any IP address to the peer!
#noipdefault
# No ppp compression
novj
novjccomp
papcrypt
nodeflate
#No ppp magic number
nomagic
# no asyn cmap
asyncmap 0
# Add default route
defaultroute
#Auto get IP address
usepeerdns
# Connect script
connect 'chat -s -v -f /etc/ppp/gprs-connect-chat'
gprs-connect-chat:
TIMEOUT 10 ECHO ON ABORT 'BUSY' ABORT 'ERROR' ABORT 'NO ANSWER' ABORT 'NO CARRIER' ABORT 'NO DIALTONE' ABORT 'RINGING' '' AT\r  TIMEOUT 12 OK ATE1 OK ATE0 OK ATS0 OK 'AT+CGDCONT=1,"IP","COMNET"' OK 'AT+CGCLASS="B"'
OK ATDT*99***1#
CONNECT ""
错误信息如下:
timeout set to 10 seconds
abort on (BUSY)
abort on (ERROR)
abort on (NO ANSWER)
abort on (NO CARRIER)
abort on (NO DIALTONE)
abort on (RINGING)
send (AT^M^M)
expect (OK)
%leealarm
send (AT^M^M)
expect (OK)
%leealarm
Failed
Connect script failed
紧急求救啊!
直播时间:4月22日(周二)10:00
直播奖励:京东卡、蓝牙温湿度计、定制水杯
