342|0
31
供应10A45升压芯片,10A45 pdf [复制链接]
GENERAL DESCRIPTION
The PW5410A is a low noise, constant frequency (1.2MHz) switched capacitor voltage doubler. It produces a regulated output voltage from 2.7V to 5V input with up to 250mA of output current. Low external parts count (one flying capacitor and two small bypass capacitors at VIN and VOUT) make the PW5410A ideally suited for small, battery-powered applications.
The new charge-pump architecture maintains constant switching frequency to no load and reduces both output and input ripple. The PW5410A have thermal shutdown capability and can survive a continuous short circuit from VOUT to GND. Built-in soft-start circuitry prevents excessive inrush current during start-up.
  1. Fixed 5V±4% Output
  2. VIN Range: 2.7V ~ 5V
  3. Output Current: up to 250mA (VIN=4.5V)
  4. Low Noise Constant Frequency Operation
  5. Shutdown Current: <1μA
  6. Short-Circuit Protection
  7. Soft-start
  8. No Inductors
  9. Available in Low Profile 6-Lead SOT-23 Package
APPLICATIONS
  1. White LED Backlighting
  2. Li-Ion Battery Backup Supplies
  3. Local 3V to 5V Conversion
  4. Smart Card Readers
  5. PCMCIA Local 5V Supplies
10A45代理: 深圳夸克微科技
郑生 13528458039
   QQ:2867714804
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
站点相关: 国产芯 安防电子 汽车电子 手机便携 工业控制 家用电子 医疗电子 测试测量 网络通信 物联网 13
