3083|8
88
关于动态加载中断流驱动 [复制链接]
1:如果加载驱动不成功 首先注意你的XXX_Open() 那3个XXX是否大写
2:对于WINCE4.2以上的版本,动态加载中断流是不成功的啊
但是我的版本是WINCE5.0,而且我大小写都注意了,我就是用CE驱动调试助手激活我的中断驱动就是不成功啊
希望大侠们指点
放出我的程序
[code]
** 函数: DLL程序入口
** 功能: 驱动形式是DLL的
BOOL WINAPI DllEntry(HANDLE hinstDLL,
                                         DWORD  dwReason,
                                         LPVOID /* lpvReserved */)
        switch (dwReason)
        case DLL_PROCESS_ATTACH:
                DEBUGREGISTER((HINSTANCE)hinstDLL);
                return TRUE;
        case DLL_THREAD_ATTACH:
                break;
        case DLL_THREAD_DETACH:
                break;
        case DLL_PROCESS_DETACH:
                break;
#ifdef UNDER_CE
        case DLL_PROCESS_EXITING:
                break;
        case DLL_SYSTEM_STARTED:
                break;
#endif
        return TRUE;
BOOL KEY_Deinit(DWORD hDeviceContext)
        BOOL ret=true;
        RETAILMSG(1,(TEXT("WZQ_KEY:KEY_Deinit......\r\n")));
        //屏蔽系统逻辑按键中断
        InterruptDisable(SYSINTR_USER_KEY);
        CloseHandle(g_hEINTIntrThread);
        for(int i=0; i<4; i++)
                CloseHandle(g_ahKeyEvent);
        //释放虚拟内存空间
        VirtualFree((void*)s2440IOP, sizeof(IOPreg), MEM_RELEASE);
        VirtualFree((void*)s2440INT, sizeof(INTreg), MEM_RELEASE);
        return TRUE;
BOOL KeyGpioInit()
        RETAILMSG(1,(TEXT("Key_Gpio_Setting----\r\n")));
        s2440IOP->rGPGCON  = (s2440IOP->rGPGCON  & ~(0x3 << 0x0)) | (0x2 << 0x0);        // GPG0 == EINT8
        s2440IOP->rEXTINT1 = (s2440IOP->rEXTINT1 & ~(0x7<< 0)) | (0x3 << 0);                // Falling-edge triggered.
        s2440IOP->rGPGCON  = (s2440IOP->rGPGCON  & ~(0x3 << 0x6)) | (0x2 << 0x6);        // GPG3 == EINT11
        s2440IOP->rEXTINT1 = (s2440IOP->rEXTINT1 & ~(0x7<< 12)) | (0x3 << 12);                // Falling-edge triggered.
        s2440IOP->rGPGCON  = (s2440IOP->rGPGCON  & ~(0x3 << 0x10)) | (0x2 << 0x10);        // GPG5 == EINT13
        s2440IOP->rEXTINT1 = (s2440IOP->rEXTINT1 & ~(0x7<< 20)) | (0x3 << 20);                // Falling-edge triggered.
        s2440IOP->rGPGCON  = (s2440IOP->rGPGCON  & ~(0x3 << 0x12)) | (0x2 << 0x12);        // GPG6 == EINT14
        s2440IOP->rEXTINT1 = (s2440IOP->rEXTINT1 & ~(0x7<< 24)) | (0x3 << 24);                // Falling-edge triggered.
        s2440IOP->rGPGCON  = (s2440IOP->rGPGCON  & ~(0x3 << 0x14)) | (0x2 << 0x14);        // GPG7 == EINT15
        s2440IOP->rEXTINT1 = (s2440IOP->rEXTINT1 & ~(0x7<< 28)) | (0x3 << 28);                // Falling-edge triggered.
        s2440IOP->rGPGCON  = (s2440IOP->rGPGCON  & ~(0x3 << 0x22)) | (0x2 << 0x22);        // GPG11 == EINT19
        s2440IOP->rEXTINT2 = (s2440IOP->rEXTINT2 & ~(0x7<< 12)) | (0x3 << 12);                // Falling-edge triggered.
        return TRUE;
BOOL InitInterruptThread(void)
        DWORD  threadID;
        DWORD  ret;
        g_hKeyEvent=CreateEvent(NULL, FALSE, FALSE, NULL);
        if(!g_hKeyEvent)
                RETAILMSG(1,(TEXT("Fail to g_hKeyEvent=CreateEvent(NULL, FALSE, FALSE, NULL);\r\n")));
                return FALSE;
        ret=InterruptInitialize(SYSINTR_USER_KEY, g_hKeyEvent, NULL, 0);
        if(!ret)
                RETAILMSG(1,(TEXT("Fail to ret=InterruptInitialize(SYSINTR_USER_KEY, g_hKeyEvent, NULL, 0);\r\n")));
                return FALSE;
        g_hEINTIntrThread=CreateThread(
                                        NULL,
                                        0,
                                        (LPTHREAD_START_ROUTINE)EintThread,
                                        0,
                                        0,
                                        &threadID
        if(NULL == g_hEINTIntrThread)
                RETAILMSG(1,(TEXT("Fail to g_hEINTIntrThread\r\n")));
                return FALSE;
        RETAILMSG(1,(_T("UserKey.DLL::InterruptThread Initialized.\r\n")));
        return TRUE;
DWORD KEY_Init(DWORD dwContext)
        RETAILMSG(1,(TEXT("KEY_Init----\r\n")));
        // 1. Virtual Alloc
        EINT_InitAddress();
        KeyGpioInit();
                g_ahKeyEvent=CreateEvent(NULL,FALSE,FALSE,NULL);
        if (!InitInterruptThread())
        RETAILMSG(1,(TEXT("Fail to initialize userkey interrupt event\r\n")));
        return FALSE;
        //mInitialized = TRUE;
        return TRUE;
BOOL KEY_IOControl(DWORD hOpenContext,
                                   DWORD dwCode,
                                   PBYTE pBufIn,
                                   DWORD dwLenIn,
                                   PBYTE pBufOut,
                                   DWORD dwLenOut,
                                   PDWORD pdwActualOut)
        RETAILMSG(1,(TEXT("KEY:Ioctl code = 0x%x\r\n"), dwCode));
        return TRUE;
DWORD KEY_Open(DWORD hDeviceContext, DWORD AccessCode, DWORD ShareMode)
        RETAILMSG(1,(TEXT("USERKEY: KEY_Open\r\n")));
    RETAILMSG(1,(TEXT("USERKEY: KEY_Open---------\r\n")));
        RETAILMSG(1,(TEXT("USERKEY: KEY_Open----------\r\n")));
        RETAILMSG(1,(TEXT("USERKEY: KEY_Open-----------\r\n")));
        return TRUE;
BOOL KEY_Close(DWORD hOpenContext)
        RETAILMSG(1,(TEXT("USERKEY: KEY_Close\r\n")));
        return TRUE;
void KEY_PowerDown(DWORD hDeviceContext)
        RETAILMSG(1,(TEXT("USERKEY: KEY_PowerDown\r\n")));
void KEY_PowerUp(DWORD hDeviceContext)
        RETAILMSG(1,(TEXT("USERKEY: KEY_PowerUp\r\n")));
DWORD KEY_Read(DWORD hOpenContext, LPVOID pBuffer, DWORD Count)
        DWORD dwRet;
        uchar *pReadBuf;
        RETAILMSG(1,(TEXT("USERKEY: KEY_Read\r\n")));
        if(pBuffer==NULL || Count==0)
                return FALSE;
        pReadBuf=(uchar *)MapPtrToProcess(pBuffer,GetCallerProcess());
        *pReadBuf=0;
        //挂起当前线程直到有按键按下为止
        dwRet=WaitForMultipleObjects(4,g_ahKeyEvent,FALSE,INFINITE);
        if(dwRet==WAIT_OBJECT_0)
                ResetEvent(g_ahKeyEvent[KEY1_EVENT]);
                *pReadBuf=KEY1_DOWN;
        else if(dwRet==WAIT_OBJECT_0+1)
                ResetEvent(g_ahKeyEvent[KEY2_EVENT]);
                *pReadBuf=KEY2_DOWN;
        else if(dwRet==WAIT_OBJECT_0+2)
                ResetEvent(g_ahKeyEvent[KEY3_EVENT]);
                *pReadBuf=KEY3_DOWN;
        else if(dwRet==WAIT_OBJECT_0+3)
                ResetEvent(g_ahKeyEvent[KEY4_EVENT]);
                *pReadBuf=KEY4_DOWN;
        return (TRUE);
DWORD KEY_Seek(DWORD hOpenContext, long Amount, DWORD Type)
        RETAILMSG(1,(TEXT("USERKEY: KEY_Seek\r\n")));
        return 0;
DWORD KEY_Write(DWORD hOpenContext, LPCVOID pSourceBytes, DWORD NumberOfBytes)
        RETAILMSG(1,(TEXT("USERKEY: KEY_Write\r\n")));
        return 0;
多谢大家 解决:外部中断被别人占用了  详情 回复 发表于 2009-5-29 15:35
请大家看看 不知道哪里出错 我已经编译驱动成功的 ,以上是驱动的主要部分
63
up
91
加载到哪一步不成功,请看打印信息,你打包这个驱动能用吗?
注意在XXX_DeInit函数必须把系统中断释放,否则卸载驱动再次加载会造成一个物理中断对应多个系统中断,这样是不会响应中断的。
怎么个不成功法?
基本上,只要注册表没错,加载应该是没问题的。
[color=#FF0000](1)我使用驱动调试助手来加载中断的
61
驱动加载不成功和你的KEY_init函数有很大关系。
如果跟不了代码,建议在KEY_init()中插入日志打印语句,看到底是哪步有问题,定位了这个再说。
例如:
// 1. Virtual Alloc
EINT_InitAddress();
RETAILMSG(1,(TEXT("EINT_InitAddress done...\r\n")));
KeyGpioInit();
RETAILMSG(1,(TEXT("KeyGpioInit done...\r\n")));
for(int i=0; i <4; i++)
RETAILMSG(1,(TEXT("Create 4 Events done...\r\n")));
        return FALSE;
return TRUE;
好的谢谢 我今晚会宿舍试试
59
多谢大家
解决:外部中断被别人占用了
