2542|0
3836
DSP28335烧写Flash遇到的问题 [复制链接]
做一个SPWM逆变闭环测试,发现程序在RAM中运行没有问题,但是烧写到Flash中就不能正常运行了,针对这个问题,我查找了好多资料(心疼小白的我...),最终问题得以解决,现将解决思路分享出来,希望能够帮到和我有同样遭遇的同行~
      首先,在TI的官方例程中,有 DELAY_US(); 这个函数,这是定义在RAM中的,在Flash中加载程序不将其复制到RAM中运行,则有可能造成上述问题以及程序跑飞...
      在ADC初始化程序中,就有用到这个函数,因此要特别注意~
       我的解决方法如下:注意ramfuncs中的配置
       在F28335.cmd文件中配置如下
SECTIONS
   /* Allocate program areas: */
   .cinit              : > FLASHC      PAGE = 0
   .pinit              : > FLASHC,     PAGE = 0
   .text               : > FLASHC      PAGE = 0
   codestart           : > BEGIN       PAGE = 0
  ramfuncs            : LOAD = FLASHD,
                         RUN = RAML0,
                         LOAD_START(_RamfuncsLoadStart),
                         LOAD_END(_RamfuncsLoadEnd),
                         RUN_START(_RamfuncsRunStart),
                         PAGE = 0
   csmpasswds          : > CSM_PWL     PAGE = 0
   csm_rsvd            : > CSM_RSVD    PAGE = 0
   /* Allocate uninitalized data sections: */
   .stack              : > RAMM1       PAGE = 1
   .ebss               : > RAML4       PAGE = 1
   .esysmem            : > RAMM1       PAGE = 1
   /* Initalized sections go in Flash */
   /* For SDFlash to program these, they must be allocated to page 0 */
   .econst             : > FLASHA      PAGE = 0
   .switch             : > FLASHA      PAGE = 0
   /* Allocate IQ math areas: */
   IQmath              : > FLASHC      PAGE = 0                  /* Math Code */
   IQmathTables     : > IQTABLES,  PAGE = 0, TYPE = NOLOAD
   /* Uncomment the section below if calling the IQNexp() or IQexp()
      functions from the IQMath.lib library in order to utilize the
      relevant IQ Math table in Boot ROM (This saves space and Boot ROM
      is 1 wait-state). If this section is not uncommented, IQmathTables2
      will be loaded into other memory (SARAM, Flash, etc.) and will take
      up space, but 0 wait-state is possible.
   IQmathTables2    : > IQTABLES2, PAGE = 0, TYPE = NOLOAD
              IQmath.lib<IQNexpTable.obj> (IQmathTablesRam)
   FPUmathTables    : > FPUTABLES, PAGE = 0, TYPE = NOLOAD
   /* Allocate DMA-accessible RAM sections: */
   DMARAML4         : > RAML4,     PAGE = 1
   DMARAML5         : > RAML5,     PAGE = 1
   DMARAML6         : > RAML6,     PAGE = 1
   DMARAML7         : > RAML7,     PAGE = 1
   /* Allocate 0x400 of XINTF Zone 7 to storing data */
   ZONE7DATA        : > ZONE7B,    PAGE = 1
   /* .reset is a standard section used by the compiler.  It contains the */
   /* the address of the start of _c_int00 for C Code.   /*
   /* When using the boot ROM this section and the CPU vector */
   /* table is not needed.  Thus the default type is set here to  */
   /* DSECT  */
   .reset              : > RESET,      PAGE = 0, TYPE = DSECT
   vectors             : > VECTORS     PAGE = 0, TYPE = DSECT
   /* Allocate ADC_cal function (pre-programmed by factory into TI reserved memory) */
   .adc_cal     : load = ADC_CAL,   PAGE = 0, TYPE = NOLOAD
//                    RAM
   在工程中添加DSP2833x_CodeStartBranch.asm和DSP2833x_MemCopy.c文件
   在main函数中InitSysCtrl();后添加 MemCopy(&RamfuncsLoadStart, &RamfuncsLoadEnd, &RamfuncsRunStart);
   InitFlash();函数
   要注意在main 函数前对Memcopy中的变量进行外部变量声明
以上,解决了我的问题,希望也能帮到你~
