The code security module (CSM) is a security feature incorporated in 28x devices. It prevents access/visibility to on-chip memory to unauthorized persons—that is, it prevents duplication/reverse engineering of proprietary code.
The word secure means access to on-chip memory is protected. The word unsecure means access to onchip secure memory is not protected — that is, the contents of the memory could be read by any means (through a debugging tool such as Code Composer Studio™, for example).
In addition to the CSM, the emulation code security logic (ECSL) has been implemented to prevent unauthorized users from stepping through secure code. Any code or data access to flash, user OTP, L0 memory while the emulator is connected will trip the ECSL and break the emulation connection.
When initially debugging a device with the password locations in flash programmed (that is, secured), the emulator takes some time to take control of the CPU. During this time, the CPU will start running and may execute an instruction that performs an access to a protected ECSL area. If this happens, the ECSL will trip and cause the emulator connection to be cut.
C28xx: Error connecting to the target: (Error -1015 @ 0x0) Device is not responding to the request. Device may be locked, or the emulator connection may be unreliable. Unlock the device if possible (e.g. use wait in reset mode, and power-cycle the board). If error persists, confirm configuration and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.450.0)
此错误提示与密码错误时的提示是不一样的,密码错误时的提示如下:
C28xx: Flash Programmer: Device is locked or not connected. Operation cancelled.
C28xx: Error Writing Flash @ Address 0x003F74C6 of Length 0x00000016 (page 0)
C28xx: GEL: File: D:\Forklift\MS8000V10\Project\Release\MS8000V10.out: Load failed.
同时会有一个对话框提示:
TI的文档中也给出了此问题的解决办法:
The first is to use the Wait-In-Reset emulation mode, which will hold the device in reset until the emulator takes control. The emulator must support this mode for this option.
The second option is to use the “Branch to check boot mode” boot option. This will sit in a loop and continuously poll the boot mode select pins. You can select this boot mode and then exit this mode once the emulator is connected by re-mapping the PC to another address or by changing the boot mode selection pin to the desired boot mode.
简而言之,第一种方法是保持器件处于复位状态直至仿真器接管器件,这需要仿真器与器件的支持;第二种方法是通过BOOT引脚的配置,使得DSP进入一个所谓的”Branch to check boot mode”,然后再连接仿真器。
我使用的XDS100v3仿真器并不支持第一种方法,在仿真器设置中”Halt the target on a connect”一项是不可选的,如图所示:
此时只能采用第二种方法,然而第二种方法中的”Branch to check boot mode”具体指什么文档中并没有很明确的指出来。不过TI的Wiki Page上给出了正确的操作方法:
Q: Why does Code Composer Studio give me an emulator error when I try to connect to my locked device?
On devices with ECSL protection which do not support hardware wait-in-reset mode (such as the Piccolo devices), if the device is locked:
When the device is powered up, the CPU will start running and may execute an instruction that performs an access to an ECSL protected area. If this happens, the ECSL will trip and cause the emulator connection to be cut. To resolve this:
Disconnect your emulator.
Set your boot pins for “WAIT” boot mode. Note: on 2833x/2823x this is documented as the “loop to check” boot mode.
Reset your device.
Reconnect your emulator.
At this point you should be able to proceed and unlock your device.
