极速cpsj 该用户已被删除
提示: 作者被禁止或删除 内容自动屏蔽
nk.bin的前7bytes是标志位,从第八个开始就是nk.nb0对应的起始地址,大小,校验和。存储的地址不是在nk.bin里面,而是下载完后,准备烧录到flash里去的时候确定的,因为nand可能有坏块,所以block0是不确定的。
谢谢!
那怎样去读取NK.bin呢?也就是说该怎样去找到nk.bin?
下载的时候按字节接收nk.bin,就可以分析了。
下载后就会将nk.bin的有效内容提取出来,形成标准二进制,其实就是nk.nb0的内容了。烧录到flash就会产生存储地址。
问题是我现在是在DNW环境下用USB端口下载,先下载NBoot,然后下载EBoot,再下载NK.bin。其中NBoot和EBoot不用每次都下载,主要是更新不同的NK.bin文件
以下是已经用VIVI下载NBoot和EBoot后,输入W,用usb端口下载NK.bin的调试输出消息:
##### FriendlyARM BIOS for 2440 #####
[x] bon part 0 320k 2368k
[v] Download vivi
[k] Download linux kernel
[y] Download root_yaffs image
[c] Download root_cramfs image
[a] Absolute User Application
[n] Download Nboot
[e] Download Eboot
Download WinCE NK.nb0
[w] Download WinCE NK.bin
[d] Download & Run
[z] Download zImage into RAM
[g] Boot linux from RAM
[f] Format the nand flash
[p] Partition for Linux
Boot the system
Set the boot parameters
[t] Print the TOC struct of wince
Backup NAND Flash to HOST through USB(upload)
[r] Restore NAND Flash from HOST through USB
[q] Goto shell of vivi
Enter your selection: w
Clear the free memory .............................................................
Read eboot image from flash ......
ReadImageFromNand: TOC is invalidate: 0x1, use default toc to load eboot
Sector addr on NAND: 0x100
TotalSector: 0x100
LoadAddress: 0x30038000
JumpAddr: 0x30038000
Now, to download the wince image(nk.bin) ......
USB host is connected. Waiting a download.
Now, Downloading [ADDRESS:30058000h,TOTAL:28481921]
Downloaded file at 0x30000000, size = 28481911 bytes
Mark bad blocks as unused ......
Extract wince image throught USB ......
OEMMultiBINNotify: Download BIN file information:
[0]: Base Address=0x8c200000  Length=0x1b90310
OEMVerifyMemory: StartAddr: 0x8c200000, Length:0x1b90310
*** Downloading UNKNOWN image type ***
dwImageStart : 0x8c200000
dwImageLength: 0x1b90310
LaunchAddr   : 0x8c201000
rom_offset=0x0.
Run eboot, JumpAddr = 0x30038000
从这里开始是EBoot启动了,这里出现了NK.bin镜像起始地址(dwImageStart)和大小(dwImageLength)以及启动地址(dwLaunchAddr),但是再eboot中能直接使用这个数据么?一边下载的NK.bin是先暂存在ram中的,那这个暂存的RAM地址是怎样确定的?如果知道这个暂存的RAM地址,那就可以去读取NK.bin的参数了!
eboot中有详细的代码啊,
下载后会解析的。
找到nk.bin文件的标志,以及offset等,然后开始确定,这个地址在代码中计算出来的。
eboot功能比较完善了,万一发现坏快就会寻找下一块的。
引用楼主 iwillbeback008 的帖子:
在DNW环境下用VIVI下载NBoot和EBoot以及NK.bin,那如何在Eboot中读取出NK.bin的镜像存储的起始地址(dwImageStart)和大小(dwImageLength)以及启动地址(dwLaunchAddr)?
dwLaunchAddr也是计算出来的。并不固定。有汇编代码的。
up
up
OEMVerifyMemory: StartAddr: 0x8c200000, Length:0x1b90310  <----------你用UltraEdit打开nk.bin,16进制形式查看,第8个字节开始就能看到这两个数值了
*** Downloading UNKNOWN image type ***         <-------------很奇怪,为什么会有这样的信息?当然实际上结果没出问题。
LaunchAddr  : 0x8c201000   <---------wince在dwImageStart开始后都会jump到0x1000,你换其他平台看也会发现这个值就是前面那个Start+0x1000。
rom_offset=0x0.
从这里开始是EBoot启动了,  <---------这里怎么会是eboot启动呢?你的eboot是不是改过了?下载完nk,烧录到flash后,一般是直接跳转了执行nk启动系统了。
“一边下载的NK.bin是先暂存在ram中的,那这个暂存的RAM地址是怎样确定的?”
存在sdram的这个地址是确定的,就是dwImageStart : 0x8c200000。而且每次重新启动,eboot加载nk时,也是防在这同一个位置的。
对,我的EBoot就是要修改的。目的是,能在DNW环境下,用USB下载NK.bin镜像,然后由NBoot遇到eboo去把镜像烧录到Flash或是由NBoot直接启动已有的镜像。
(*^__^*) 嘻嘻……
shuiyan前辈这么厉害,咋就不回答我的问题呢?
(*^__^*) 嘻嘻……
那在EBOOT中如何读写SDRAM,有相关现出的函数可以调用么?
怎懑没有人回答了?
在EBOOT中如何读写SDRAM,有相关现出的函数可以调用么?还是要自己写函数?
eboot读写sdram就是直接对地址进行操作即可。比如
x = addr; //addr是一个地址,这样就是从sdram读
addr = x+1; //addr是一个地址,这样就是向sdram写
引用 16 楼 shuiyan 的回复:
我的Eboot启动时已经开启了MMU,那这个地址addr也就是虚拟地址咯?
比如我要读取物理地址为0x30000000(对应虚拟地址为0x8C000000)开始的SDRAM的数据,那就要写成:
x = 0x8C00 0000;
对不?这个格式我觉得很别扭啊
是的,就是虚拟地址。
上面描述错了,应该是将地址当成指针
x = (unsigned int) *(addr);
那如果这样,我利用memcpy()函数,把读取SDRAM的写成如下形式可以吧?
DWORD Address;
DWORD Buffer;
Address = 0x8c200000;
memcpy(&Buffer,(LPBYTE)(Address+7),4);        //镜像起始地址
