1555|0
1704
MSP432UART测试 [复制链接]
MSP432的uart口是直接与调试器连接的:
其实我们可以直接用调试器的usb口当做串口用,使用的就是P1.2和P1.3,并不需要额外接线,非常方便。
直接借用TI官方提供的列子,主程序如下:
int main(void)
        WDT_A->CTL = WDT_A_CTL_PW |             // Stop watchdog timer
                                        WDT_A_CTL_HOLD;
        clk_init();//clk init
        uart_init();//uart init,9600
        while(1)
                send_str((uint8_t *)"uart test...\r\n");
                for(int i=0;i<10000;i++)
复制代码
串口初始化:
void uart_init(void)
    // Configure UART pins
    P1->SEL0 |= BIT2 | BIT3;                // set 2-UART pin as secondary function
    // Configure UART
    EUSCI_A0->CTLW0 |= EUSCI_A_CTLW0_SWRST; // Put eUSCI in reset
    EUSCI_A0->CTLW0 = EUSCI_A_CTLW0_SWRST | // Remain eUSCI in reset
            EUSCI_B_CTLW0_SSEL__SMCLK;      // Configure eUSCI clock source for SMCLK
    // Baud Rate calculation
    // 12000000/(16*9600) = 78.125
    // Fractional portion = 0.125
    // User's Guide Table 21-4: UCBRSx = 0x10
    // UCBRFx = int ( (78.125-78)*16) = 2
    EUSCI_A0->BRW = 78;                     // 12000000/16/9600
    EUSCI_A0->MCTLW = (2 << EUSCI_A_MCTLW_BRF_OFS) |
            EUSCI_A_MCTLW_OS16;
    EUSCI_A0->CTLW0 &= ~EUSCI_A_CTLW0_SWRST; // Initialize eUSCI
    EUSCI_A0->IFG &= ~EUSCI_A_IFG_RXIFG;    // Clear eUSCI RX interrupt flag
    EUSCI_A0->IE |= EUSCI_A_IE_RXIE;        // Enable USCI_A0 RX interrupt
    // Enable global interrupt
    __enable_irq();
    // Enable eUSCIA0 interrupt in NVIC module
    NVIC->ISER[0] = 1 << ((EUSCIA0_IRQn) & 31);
复制代码
字符串发送函数:
void send_str(uint8_t *str)
        while(*str!='\0')
        // Check if the TX buffer is empty first
        while(!(EUSCI_A0->IFG & EUSCI_A_IFG_TXIFG));
        // Echo the received character back
        EUSCI_A0->TXBUF = *str;
                        str++;
复制代码
测试结果:
串口测试ok
