4835|2
253
STM32L151读取W25Q16的ID错误,请帮忙看看是什么原因 [复制链接]
使用STM32L151的SPI2读取W25Q16的ID错误,返回总是0xFFFF,请帮忙看看代码是什么原因。代码参考的是正点原子的。
void SPI2_Init(void)
  SPI_InitTypeDef  SPI_InitStructure;
  GPIO_InitTypeDef GPIO_InitStructure;
    ////SPI Set PB13,14,15 as Output push-pull - SCK, MISO and MOSI
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI2,ENABLE);
    /* 使能SPI引脚相关的时钟 */
   RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB,ENABLE);
    /*指令IO的复用功能*/
     GPIO_PinAFConfig(GPIOB, GPIO_PinSource13,GPIO_AF_SPI2);
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource14,GPIO_AF_SPI2);
  GPIO_PinAFConfig(GPIOB, GPIO_PinSource15,GPIO_AF_SPI2);
    /*  SCK、MOSI、MISO */
  GPIO_InitStructure.GPIO_Pin =   GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
  GPIO_InitStructure.GPIO_Mode =  GPIO_Mode_AF;  //复用
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //推挽
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_40MHz;
  GPIO_Init(GPIOB,&GPIO_InitStructure);
        /* SPI2 configuration */
        SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
        SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
        SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
        SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
        SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
        SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
        SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2;
        SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
        SPI_InitStructure.SPI_CRCPolynomial = 7;
        SPI_Init(SPI2, &SPI_InitStructure);
        /* Enable SPI2  */
        SPI_Cmd(SPI2, ENABLE);
        SPI2_ReadWriteByte(0xff);
//SPIx 读写一个字节
//TxData:要写入的字节
//返回值:读取到的字节
uint8_t SPI2_ReadWriteByte(uint8_t TxData)
uint8_t retry=0;
while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_TXE) == RESET) //检查指定的SPI标志位设置与否:发送缓存空标志位
  retry++;
  if(retry>200)return 0;
SPI_I2S_SendData(SPI2, TxData); //通过外设SPIx发送一个数据
retry=0;
while (SPI_I2S_GetFlagStatus(SPI2, SPI_I2S_FLAG_RXNE) == RESET) //检查指定的SPI标志位设置与否:接受缓存非空标志位
  retry++;
return SPI_I2S_ReceiveData(SPI2); //返回通过SPIx最近接收的数据
//读取芯片ID
//返回值如下:
//0XEF13,表示芯片型号为W25Q80
//0XEF14,表示芯片型号为W25Q16
//0XEF15,表示芯片型号为W25Q32
//0XEF16,表示芯片型号为W25Q64
//0XEF17,表示芯片型号为W25Q128
uint16_t W25QXX_ReadID(void)
uint16_t Temp = 0;
GPIO_ResetBits(GPIOB,GPIO_Pin_12);
SPI2_ReadWriteByte(0x90);//发送读取ID命令
SPI2_ReadWriteByte(0x00);
Temp|=SPI2_ReadWriteByte(0x00)<<8;
Temp|=SPI2_ReadWriteByte(0x00);
GPIO_SetBits(GPIOB,GPIO_Pin_12);
return Temp;
此帖出自stm32/stm8论坛
你这个问题我也遇到过,最后在上电后读ID前加一条唤醒指令解决了SFLASH_RELEASE_POWER_DOWN 0xAB                     //释放掉电   详情 回复 发表于 2020-5-9 08:30
点赞 关注(1)
4008
io口电压对吗?
此帖出自stm32/stm8论坛
327
此帖出自stm32/stm8论坛
个人签名模电临时工
