1854|0
2015
TMS320F28335 串口 SCI [复制链接]
TMS320F28335的串口有三个串口,SCIA,SCIB和SCIC,GPIO的管脚对应如下:
SCIA对应GPIO28/29和GPIO35/36两组可选,SCIB有四组管脚可以选择,分别是GPIO9/11,GPIO14/15,GPIO18/19,GPIO22/23,SCIC对应的是GPIO62/63。
首先需要定义管脚。
void InitSciaGpio()    //初始化GPIO管脚
   EALLOW;
//根据硬件设计决定采用GPIO28/29和GPIO35/36中的哪一组。这里以35/36为例
//定义管脚为上拉
    GpioCtrlRegs.GPBPUD.bit.GPIO36 = 0;
    GpioCtrlRegs.GPBPUD.bit.GPIO35 = 0;
//定义管脚为异步输入
    GpioCtrlRegs.GPBQSEL1.bit.GPIO36 = 3;
//配置管脚为SCI功能管脚
    GpioCtrlRegs.GPBMUX1.bit.GPIO36 = 1;
    GpioCtrlRegs.GPBMUX1.bit.GPIO35 = 1;
    EDIS;
SCIB和SCIC的配置差不多。
下来就要定义波特率等等了。例子是9600bps,1,8,n,1.
void scia_init()
    SciaRegs.SCICCR.all =0x0007;   // 1 stop bit, No loopback
                                   // No parity,8 char bits,
                                   // async mode, idle-line protocol
    SciaRegs.SCICTL1.all =0x0003; // enable TX, RX, internal SCICLK,
                                   // Disable RX ERR, SLEEP, TXWAKE
    SciaRegs.SCICTL2.bit.TXINTENA =1; //发送中断使能
    SciaRegs.SCICTL2.bit.RXBKINTENA =1;//接收中断使能
    SciaRegs.SCIHBAUD    =0x0001; // 9600 baud @LSPCLK = 37.5MHz.
    SciaRegs.SCILBAUD    =0x00E7;
    SciaRegs.SCICTL1.all =0x0023; // Relinquish SCI from Reset
接着进行中断的配置
   EALLOW;    // This is needed to write to EALLOW protected registers
   PieVectTable.SCIRXINTA = &sciaRxIsr;
   PieVectTable.SCITXINTA = &sciaTxIsr;
   PieVectTable.SCIRXINTB = &scibRxIsr;
   PieVectTable.SCITXINTB = &scibTxIsr;
   EDIS;   // This is needed to disable write to EALLOW protected registers
上面是将SCIA和SCIB的中断服务程序连到PIE的中断表中,发生中断就会跑到你的ISR去了
下面就是开中断了。
   PieCtrlRegs.PIECTRL.bit.ENPIE = 1;   // Enable the PIE block
   PieCtrlRegs.PIEIER9.bit.INTx1=1;     // PIE Group 9, int1
   PieCtrlRegs.PIEIER9.bit.INTx2=1;     // PIE Group 9, INT2
   PieCtrlRegs.PIEIER9.bit.INTx3=1;     // PIE Group 9, INT3
   PieCtrlRegs.PIEIER9.bit.INTx4=1;     // PIE Group 9, INT4
   IER = 0x100;    // Enable CPU INT
   EINT;
。。。。串口OK了
