6801|15
waveOutClose的疑惑 [复制链接]
为了解决playSound函数装载大文件速度慢和不支持MP3的播放,我自己写一个模拟PlaySound的函数来播放音频文件。
我使用了常规的双缓冲,用一个callback函数不停的装载数据,播放很流畅,但是如果在播放过程中停止播放在waveOutClose的时候出现33的错误(任然有buffer没有清空),尝试了几次都不行,请大家帮我看看是什么问题,谢谢!!
void CALLBACK waveOutProcCallback( HWAVEOUT hwo2, UINT uMsg, DWORD dwInstance, DWORD dwParam1, DWORD dwParam2 )
        HRESULT mr;
        LPWAVEHDR pWaveHeader = NULL;
//系统自动识别是哪一个WAVEHDR播放完毕
        pWaveHeader = (LPWAVEHDR)dwParam1;
        switch(uMsg)
        case WOM_CLOSE:
                break;
        case WOM_OPEN:
                break;
        case WOM_DONE:
//播放完后须调用此函数
                waveOutUnprepareHeader( hwo2, pWaveHeader, sizeof(WAVEHDR) );
                EnterCriticalSection(&g_csReadyQueue);
                if(g_qReadyQueue.empty())
                        LeaveCriticalSection(&g_csReadyQueue);
                else
                        g_pPlayBuf = g_qReadyQueue.front();
                        g_qReadyQueue.pop();
//装填新的buffer
                        pWaveHeader->lpData = (char *)g_pPlayBuf;
//把使用过的buffer放回Unready Queue
                        EnterCriticalSection(&g_csUnreadyQueue);
                        g_qUnreadyQueue.push(g_pPlayBuf);
                        LeaveCriticalSection(&g_csUnreadyQueue);
                        mr = waveOutPrepareHeader(hwo2, pWaveHeader, sizeof(WAVEHDR));
                        mr = waveOutWrite(hwo2, pWaveHeader, sizeof(WAVEHDR));
                break;
        default:
                break;
DWORD WINAPI PlayThread(LPVOID lpParam)
        DWORD dwWait;
        HRESULT mr;
//分配两个结构体双缓冲
        WAVEHDR hdr1;
    WAVEHDR hdr2;
        int count = 0;
        RETAILMSG(1, (TEXT("PlayThread Begin!\r\n")));
//打开设备,使用回调函数处理双缓冲播放
        mr =  waveOutOpen(&hwo, WAVE_MAPPER, g_pwfx, (DWORD)waveOutProcCallback, NULL, CALLBACK_FUNCTION );
        MRCHECK1(mr, waveOutOpen, ERROR_OPEN);
        while(!g_bStopThread)
            //只执行一次,初始化开始两个buffer
            if(0 == count)
                        //从一个Unready队列中提取buffer赋值给WAVEHDR hdr1,WAVEHDR hdr2
                                continue;
                        memset(&hdr1, 0, sizeof(hdr1));
                        hdr1.dwBufferLength = BUF_SIZE;  //BUF_SIZE = 0x8000
                        1.lpData = (char *) g_pPlayBuf;
                        hdr1.dwFlags = 0;
                        hdr1.dwLoops = 0;
                                continue;
                        memset(&hdr2, 0, sizeof(hdr2));
                        hdr2.dwBufferLength = BUF_SIZE;
                        hdr2.lpData = (char *) g_pPlayBuf;
                        hdr2.dwFlags = 0;
                        hdr2.dwLoops = 0;
                        mr = waveOutPrepareHeader(hwo, &hdr1, sizeof(hdr1));
                        MRCHECK1(mr, waveOutPrepareHeader,ERROR_PLAY);
                        mr = waveOutPrepareHeader(hwo, &hdr2, sizeof(hdr2));
                        MRCHECK1(mr, waveOutPrepareHeader, ERROR_PLAY);
                        mr = waveOutWrite(hwo, &hdr1, sizeof(hdr1));
                        MRCHECK1(mr, waveOutWrite, ERROR_PLAY);
                        mr = waveOutWrite(hwo, &hdr2, sizeof(hdr2));
                        count++;
        RETAILMSG(1, (TEXT("PlayThread End!\r\n")));
ERROR_PLAY:
        mr = waveOutReset(hwo);
        MRCHECK1(mr, waveOutReset, ERROR_OPEN);
        //Sleep(800);
        free(hdr1.lpData);
        MRCHECK1(mr, waveOutPrepareHeader, ERROR_OPEN);
        free(hdr2.lpData);
    mr = waveOutClose(hwo);
    MRCHECK1(mr, waveOutClose, ERROR_OPEN);
ERROR_OPEN:
    delete [] g_pPlayBuf;
    delete [] g_pwfx;
ERROR_READ:
    return 0;
最近在做音视频处理,也出现了这个问题,谢谢lesho,shiyang_x  详情 回复 发表于 2009-12-22 11:54
各位windows编程达人呢?给点意见赛,100分,说点啥我都是给分的哎
向你学习,呵呵……这一块还不是很懂,正在学习中……
我也是第一次做这个,代码肯定有缺陷,希望高人指点一二
代码有点乱,没调整好!其实很简单,就是一个播放的线程,一个回调函数处理一个WAVEHDR结构体播放完毕的消息。
如果播放中间中止,g_bStopThread变为TRUE;跳出循环,收拾内存,关闭设备。就是在mr = waveOutClose(hwo); 的时候出错,如果加上Sleep(800);就没问题,不过会出现后缀音(不能立刻停止)。
关注中,遇到了类似的问题!快些解决呀!
看了一代码,应该是两个线程没有做好同步工作.waveOutReset过程中应该可以调到waveOutProcCallback WOM_DONE中,所以在WOM_DONE的处理过程中你应该判断是否是已经RESET了,如果RESET,就不要再往里写数据了,之后又把数据delete,sleep(800)后播放出杂音应该就是这的问题了,估计这个也应该是CLOSE失败的原因。
我不是高手。。但是做过关于音频的应用和驱动。。粗略的看了下。。我觉得首先是先填满两个buffer.然后就开始waveoutwrite一个。因为一开始第一个buffer write完后就可以进入你的那个回调再所有的过程都集中在回调里面。
还有就是你的hwo2是什么意思。。不是就一个hwo吗?
我想你试试在最后close之前再reset一次看看。。。reset是清空缓存。。。。
网上有个叫filter的小程序。。很是经典。。。如果是想专门弄好这一块就可以下下来看看。。。
感谢unsway123:
1. 如果填满两个buffer,然后就开始waveoutwrite一个,就算进入回调还是只能是一个buffer装载数据,write数据啊,第二个始终在那里没有播放吧。所以另外一个waveoutwrite也要执行。
2. hwo就是hwo2,因为回调函数自己可以判断出hwo,hwo和hwo2只是变量命名而已。
3. 我在close之前reset了,没用,代码如下:
waveOutReset(hwo);
//Sleep(800);
waveOutClose(hwo);
Sleep(800)之后就可以了。
那可能是说,音频缓冲区里的数据没有被播放完,
清空缓冲区之后才能正常关闭?
reset能清空缓冲区吗?
引用 7 楼 rzsheng 的回复:
Sleep(800)之后就可以了。
清空缓冲区之后才能正常关闭?
reset能清空缓冲区吗?
这就是我想问的,如果按照代码判断,reset和unprepare两个函数都不能真正清空buffer,所以close的时候出错,延迟800毫秒貌似可以全部放完了,但是会有一点尾音,就是结尾不干净的那种声音。
引用 10 楼 shiyang_x 的回复:
看完很有启发,我试试看,顺道问一下,怎么判断是否已经reset了?光根据返回值好像不好判断吧。。。
问题解决了!!果然如shiyang_x兄所言!!拜谢!!
学习一下!
感谢大家,我也遇到这个问题。
