2578|2
關於nrg既做主機又作從機的問題? [复制链接]
1.是不是同時工作在掃描和廣告的模式下?
2.兩個的功能是不是同時可以并行處理,不需要分場合?還是單雙工,只能同時工作在主機模式下?
我的使用場景如下:
1.作爲主機輪流讀取4個藍牙溫濕度傳感器
2.作爲從機,通過小程序來進行數據的收發,小程序的套路大概已經瞭解。有可以指點一二的不?
本帖最后由 littleshrimp 于 2020-3-31 07:45 编辑 [attach]467401[/attach]   3.9 BLE simultaneously master, slave scenario The BlueNRG-1, BlueNRG-2 BLE stack supports multiple roles simultaneously. This allows the same device to act as master on one or more connections (up to eight connections are supported), and to act as a slave on another connection. The following pseudo code describes how a BLE stack device can be initialized to support central and peripheral roles simultaneously:   详情 回复 发表于 2020-3-31 06:57
9716
24
dm00294449-bluenrg1-bluenrg2-ble-stack-v2x-programming-guidelines-stmicroelectronics.pdf (1.06 MB, 下载次数: 13)
个人签名虾扯蛋,蛋扯虾,虾扯蛋扯虾
谢谢了!这个大概明白了
