library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity t is
port(key0,key1,key2,key3,key4,key5,key6,key7,key8,key9 : in std_logic;
clk : in std_logic;
key : out integer range 0 to 9);
end;
architecture bhv of t is
begin
process(key0,key1,key2,key3,key4,key5,key6,key7,key8,key9,clk) --检测按键
begin
if clk 'event and clk='1' then
if key0 'event and key0='1' then key<=0;
elsif key1 'event and key1='1' then key<=1;
elsif key2 'event and key2='1' then key<=2;
elsif key3 'event and key3='1' then key<=3;
elsif key4 'event and key4='1' then key<=4;
elsif key5 'event and key5='1' then key<=5;
elsif key6 'event and key6='1' then key<=6;
elsif key7 'event and key7='1' then key<=7;
elsif key8 'event and key8='1' then key<=8;
elsif key9 'event and key9='1' then key<=9;
end if;
end if;
end process ;
end;
用quartus II 6.0 编译时显示错误
Error (10001): Verilog HDL or VHDL error at t.vhd(16): can't infer register for key[0] because its behavior depends on the edges of multiple distinct clocks
Error (10001): Verilog HDL or VHDL error at t.vhd(16): can't infer register for key[0] because it does not hold its value outside the clock edge
Error (10001): Verilog HDL or VHDL error at t.vhd(16): can't infer register for key[1] because its behavior depends on the edges of multiple distinct clocks
Error (10001): Verilog HDL or VHDL error at t.vhd(16): can't infer register for key[1] because it does not hold its value outside the clock edge
Error (10001): Verilog HDL or VHDL error at t.vhd(16): can't infer register for key[2] because its behavior depends on the edges of multiple distinct clocks
Error (10001): Verilog HDL or VHDL error at t.vhd(16): can't infer register for key[2] because it does not hold its value outside the clock edge
Error (10001): Verilog HDL or VHDL error at t.vhd(16): can't infer register for key[3] because its behavior depends on the edges of multiple distinct clocks
Error (10001): Verilog HDL or VHDL error at t.vhd(16): can't infer register for key[3] because it does not hold its value outside the clock edge
Error (10001): Verilog HDL or VHDL error at t.vhd(16): couldn't implement registers for assignments on this clock edge
Error (10001): Verilog HDL or VHDL error at t.vhd(17): couldn't implement registers for assignments on this clock edge
Error (10001): Verilog HDL or VHDL error at t.vhd(18): couldn't implement registers for assignments on this clock edge
Error (10001): Verilog HDL or VHDL error at t.vhd(19): couldn't implement registers for assignments on this clock edge
Error (10001): Verilog HDL or VHDL error at t.vhd(20): couldn't implement registers for assignments on this clock edge
Error (10001): Verilog HDL or VHDL error at t.vhd(21): couldn't implement registers for assignments on this clock edge
Error (10001): Verilog HDL or VHDL error at t.vhd(22): couldn't implement registers for assignments on this clock edge
Error (10001): Verilog HDL or VHDL error at t.vhd(23): couldn't implement registers for assignments on this clock edge
Error (10001): Verilog HDL or VHDL error at t.vhd(24): couldn't implement registers for assignments on this clock edge
Error (10001): Verilog HDL or VHDL error at t.vhd(25): couldn't implement registers for assignments on this clock edge
Error: Can't elaborate top-level user hierarchy
Error: Quartus II Analysis & Synthesis was unsuccessful. 19 errors, 0 warnings
Error: Processing ended: Sat Sep 12 12:44:50 2009
Error: Elapsed time: 00:00:02
Error: Quartus II Full Compilation was unsuccessful. 19 errors, 0 warnings
有两个错误
第一个,key输出应该是std_logic_vector(9 downto 0),integer只能作为信号量和变量
第二个,如果要检测按键的边沿应该用2个process,第一个process中temp0 <= key0 ......
第二个process中 if (temp = ‘0’ and key0 = '1') then key(0) <= '0'
这样就可以检测按键的边沿了
library ieee;
entity keyscan if
port(
nrst : in std_logic;
clk : in std_logic;
keyin : in std_logic_vector(9 downto 0);
keyout : out std_logic_vector(9 downto 0)
end keyscan;
architecture behav of keyscan if
signal keytemp : std_logic_vector(9 downto 0);
begin
process(nrst,clk)
begin
if nrst = '0' then
keytemp <= (others => '0');
elsif rising_edge(clk) then
keytemp <= keyin;
end if;
end process;
process(nrst,clk)
begin
if nrst = '0' then
keyout <= (others => '0');
if (keytemp(0) = '0' and keyin(0) = '1') then
keyout(0) <= '1';
elsif (keytemp(1) = '0' and keyin(1) = '1') then
keyout(1) <= '1';
elsif (keytemp(2) = '0' and keyin(2) = '1') then
keyout(2) <= '1';
elsif (keytemp(3) = '0' and keyin(3) = '1') then
keyout(3) <= '1';
elsif (keytemp(4) = '0' and keyin(4) = '1') then
keyout(4) <= '1';
elsif (keytemp(5) = '0' and keyin(5) = '1') then
keyout(5) <= '1';
elsif (keytemp(6) = '0' and keyin(6) = '1') then
keyout(6) <= '1';
elsif (keytemp(7) = '0' and keyin(7) = '1') then
keyout(7) <= '1';
elsif (keytemp(8) = '0' and keyin(8) = '1') then
keyout(8) <= '1';
elsif (keytemp(9) = '0' and keyin(9) = '1') then
keyout(9) <= '1';
end if;
end if;
end process;
end behav;
